Are you an ambidextrous or right hand only downtuber?
Quoted: 1163 Post(s)
Liked 442 Times
Had my 1980's steed out the other day. What a relief to not worry about my high tech Dura Ace 9 speed triple STI's (I did miss the Flightdeck however).
Really fun drivetrain with Ultegra 6503 triple up front and Deore LX mid-cage rear, with tight 13-23 old uniglide 7 speed cluster. Mavic index downtube levers are nice and chunky and index just fine with Shimano, they even have built in "trim" for the REAR.
This drivetrain is so intuitive, I experience mucho pleasure and my mind is at rest and I enjoy the ride instead of pondering "when's the best time to shift?".
But I'm writing this because it dawned on me: I shift front and rear derailleurs with only my right hand. Using my left hand to shift the front derailleur is rarely necessary. I had the idea of posting this observation here since others might share their personal preferences to be either ambidextrous in their down tube shifting patterns.
I'm left handed by the way. Its just that after all these years my brain became hard wired to do all my shifting with my right hand.
My old habits are SO hardwired, that even with my sexy STI equipped bike, the first thing I do when I crest a hill and the terrain starts levelling out, it to feel around the downtube for a lever (that's not there of course) .
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
I'm also patterned to using my right hand on DT shifters, probably because front brake lever is on the left (edit, I remember doing ambidextrous shifting back in the day, not sure when the change took place)
You Know!? For Kids!
I guess I am bi. Shift right with right, left with left, AFAIK, but will check next time I ride.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
The Legitimiser
Bikes: Gazelle Trim Trophy, EG Bates Track Bike, HR Bates Cantiflex bike, Nigel Dean fixed gear conversion, Raleigh Royal, Falcon Westminster.
Liked 5 Times
Hmmm. I don't know. I'll watch myself, next time out.
I am ambidextrous, that's why my two favorite bikes have bar end shifters. But on the bikes that have downtube and stem shifters I generally use my right hand. And I write with my left hand. Yeah I know, I'm weird.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I generally shift each lever with the respective hand. However, my half-step and 1.5-step gearing patterns sometimes make it expedient to dump the chain from large to small chainring whilst upshifting by one or two rear cogs, and this is nicely done with a single motion of one hand moving both levers forward simultaneously.
Right hand on the right, left on left!
I rarely use my FD actually, usually only on those 4hour plus rides when the hills start getting to ya, other wise the chain pretty much stays on the big ring all the time (unless I've got an unusually big hill to climb of course).
cyqlist: whats going on with that set-up.. never saw such a thing? Whats that part in the middle behind the shifters?
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
One of the advantages of down-tube shifters is that either can be operated with either hand.
- Wil
- Wil
Bikes: Mobiky, PBW, Jim Redcay, old Chicago Schwinns
When using that arrangement I would normally shift two or three of the shifters at once, always with the right hand only.
But nowadays I am off derailleurs completely and only shift hub gears, one shifter to a bike (but still only with the right hand).
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
Right on right, left on left. It never occurred to me to do it any other way - maybe it should have!
I'm left-handed, but most of my shifting is RD shifting with the right hand.
Not only that, but my right hand is used to shifting "smart" since RD friction shifting seems to need subtle adjustments and trims. Left-hand FD shifting with my double setup is just a "dumb" lever-up, lever-down move.
Being left-handed, I'm accustomed to training my hands to use things the right-handed way.
Unique Vintage Steel
Shift both with right hand. Mainly because I'm left handed and much more confortable riding one-handed with the left hand on the bar. I typically even signal turns with my right hand only. Last time I was out for a ride with the club one rider thought I was English because of it.
Quoted: 113 Post(s)
Liked 16 Times
i shift both with my right, on my commute I got so used to it.. or sometime I would shift up a cog in the front and back at the same time and I could use one hand to simultaneously twist the levers, or say I was hitting a grade and I want to drop to the small ring cause I am maxed out in the back but I don't want to spin out I can shift to a smaller cog in the back and smaller in the front by usuing one hand to twist the levers in opposite directions (that was my touring bike) which now has barcons and every once in a while I still reach for the downtube.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Bikes: Kvale, Peugeot, Cervelo, Bridgestone
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,284 Times
Wow, it never even occurred to me to use my right hand to shift the FD! I'm gonna have to try that.
(Obviously I use my right hand for RD & left hand for FD...but since I've only been using downtube shifters for a couple of weeks, I don't think I have to worry about "breaking habits".)
Fo Cereal?!
Bikes: Guerciotti
More or less depends on my speed. If I'm clipping at anything faster than 15 mph, or if I'm on the bike path with a bunch of walkers, I'll only use my right, otherwise, I use both my left and right.
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Originally Posted by m3smth
wow, I'm the only one who uses only their left hand. I feel so out of place.
ambitextrous,I use my left hand on the left mostly,though I'm right handed. At times I'll cross-over a hand approaching a turn using whichever hand is better suited to holding the bar at the time. First time I've thought of it in awhile.
Bottecchia fan
Bikes: 1959 Bottecchia Milano-Sanremo (frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame), 1973 Bottecchia Gran Turismo, 1974 Bottecchia Special, 1977 Bottecchia Special (frame), 1974 Peugeot UO-8
Quoted: 33 Post(s)
Liked 12 Times
I shift with my right hand, fingers for the rear, thumb for the front.
