Dura ace 7800 crank vs ultegra 6700
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
D/A should be lighter and have a better, more refined finish, operationally should be about the same. But if you can get D/A for less buy it I wouldnt hesitate.
Chases Dogs for Sport
I've owned both. With the 6700 derailleur / shifters, the 6700 crankset shifts much better than the 7800 crankset using 7800 components. It's a clear difference -- the best thing about 6700. But it may not be as noticeable if you're mixing and matching components.
7800 front shifting is very good. 6700 front shifting is significantly better.
Better as in stiffer....lighter......? I don't know the answer but my guess is you wont notice the difference either way but I do think the 7800 looks better.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Aluminium Crusader :-)
I'm not sure about the 6700s, but the previous model Ultegra has a thicker axle wall (the end caps aren't interchaneable with DA), and is 'meant' to have more alu in the arms. So, as a bike shop guy once said to me: "Ultegra cranks are stiffer and stronger than Dura-Ace, and everyone in the biz knows it". Having said all that, the 7800s look ten times better, so I'd get those in a heart beat
well hello there
Quoted: 503 Post(s)
Liked 336 Times
7800.
