Ask Scrod
Scrod,
Saddle mounted bottle cages, yay or nay?
I'm going for swag here not so much for utility. So from a swag standpoint, does this have style points?
canis lupus familiaris
Bikes: En plus one
I'm beating around the bush here. I'm just going to give it to you straight. How do I get fixie babe's to swarm? Grow a cool beard? Wear tight pants?
Quoted: 1332 Post(s)
Liked 398 Times
I don't think anyone has ever looked at saddle mounted bottle cages and thought "swag." Except maybe triathletes.
Pirate/Smuggler
Lapped 3x
Swag comes from within. One cannot acquire it. In this sense, you have already failed at looking cool.
Pirate/Smuggler
Quoted: 686 Post(s)
Liked 5 Times
This.
Quoted: 12 Post(s)
Thanks a ton for the help with the Omniums question; installed them with no problems.
Do you happen to know which size the seatpost binder bolt needs to be for a Bare Knuckle/Does retrogression sell them online? (I took a look at the site and couldn't find any)
Your cog is slipping.
You need a 19mm bolt. We don't have any in stock at the moment but some Sugino seatpost binder bolts will be here early next week.
You should be able to get a suitable binder bolt at any bike shop that doesn't totally suck.
Hey Scrod,
What happened to the Alpina track forks you used to sell? I see even the Dolan website only has the UD with brake hole option available.
Señor Member
Bikes: All of them
Quoted: 31 Post(s)
I have an early Aventon Mataro with the original all aluminum fork. I think they all come with the CF/alloy-steerer fork now. I haven't had any problems with mine (yet) but I know a ton of people did. I'm honestly not too concerned, since I only ride mine on the track, and all the failures I've heard about happened on the street. Do they have any sort of preemptive warranty replacement for the newer style fork, or should I wait until I faceplant at the velodrome?
Scrod,
I am rebuilding an old Raleigh Sprite into a fixed gear. I'm feeling confident about everything I'm going to do, except for the bottom bracket. I don't know exactly what year the bike is, so I can't give you specifics. But do you know, if not, know of where I can look for a bottom bracket for the Sprite?
Edit: I live in San Diego, I could always bring it into the shop.
Scrod,
Aside from Phil Wood (which may be more than you want to spend on a conversion), I'm not sure of anyone else making a replacement BB with that threading. If the cups/bearing races themselves are in decent shape, you could always just replace the spindle with whatever length you need for your new crankset.
Quoted: 4236 Post(s)
Liked 2,949 Times
I wonder, would one of those threadless bottom brackets like velo orange (and I'm sure others) sells work? Probably more that he spent on his whole frame though.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
