Tire/rim size confusion
Bikes: Giant RS950
Hi guys,
First off sorry if this isn't the right section!
But let me get to it. I recently moved to a new city for college. I don't have a car and my road bike is all I have to move around (so having it working very important to me).
I'm 6'4 and about 195lbs. I run 700x23c tires and recently I've been getting pinch flats like crazy!
I understand that a pinch flat is possible due to incorrect pressure in the tire, but this has been left me stranded more than once and it's getting on my nerves.
Basically I want to know if my weight is incorrect for my tires. I've been thinking about blowing like $100 for Continental Gatorskin tires (and honestly I don't want to, college student!).
Would getting these tires help me not get pinch flats or is simply because the air in the tires escapes? In that case is it because of my weight? Can I get a thicker tire and keep the same rim?
Any advice?
Thanks guys
EDIT: Maybe it will help if it adds what tires I have now. I have Vittoria Rubino Pro Slicks.
Any advice?
Thanks guys
Bikes: 2012 BMC SLR01, 2012 Yeti ASR5, 2013 Trek Crockett
What pressure are you inflating your tires to? Vittorias recommended tire pressure for someone with your weight is 125 to 135 psi with the front tire about 5 psi lower than the rear.
Pinch flats are usually from too little air pressure. I would try increasing the air pressure. If you are already at the max rated pressure for your tire you may want to think about getting wider tires. With wider tires you can run lower pressures. An added benefit of lower pressures are a more comfortable ride. If you have a typical road bike you probably could run 25's with no problems or maybe even a 28 if there is room.
Switching tire models probably wont fix your pinch flat problem. Its all about finding out what pressure you can run while minimizing pinch flats.
Quoted: 659 Post(s)
Liked 7 Times
Doubtful that Gatorskins would be any more immune to pinch flats. As mentioned, these are the result of insufficient tire pressure for the load on the tire and the road conditions (potholes, etc.). Skinny, 23mm, tires with a heavy load on them require very high tire pressure and will need to have the pressure checked frequently (preferably daily) since air slowly diffuses through rubber tubes and with the high pressure and small volume of skinny tires there can be significant losses in a day or two.
I'd keep using your current tires but keep them inflated to at least the maximum pressure listed on the sidewall (and this pressure should have a wide safety margin so going a bit higher is usually fine too). Once your current tires wear out you might consider getting some wider ones. 25mm or 28mm will be fine with your current rims, but make sure there's enough clearance for them where your tires go through the brake arms and parts of the bike frame.
Bikes: Giant RS950
Thanks for your replies.
It makes sense that my tires have too little pressure, I mean I alone weigh 190ish, and then I have my backpack on me..
I think I need wider tires then. My tires say they have a max psi of 120 as it is, I'm kinda scared to go over that.
I could try inflating them to the max psi and seeing how I do with that.
But I do think that the tires are getting old.
When is a good time to get them changed? I mean the tires are completely bald already.
Do you think my best bet is to just get a pump and pressure gauge then and keep the tires topped off every like 2 days?
Thanks again.
Thanks again.
Wider tires are the way to go ... check to see if you can fit 25mm or 28mm tires.
You can run much lower pressures and will not get pinch flats from your rims.
Bikes: Giant RS950
How can I find out what sizes my rim can support?
Will going from 23, to say, a 25 or 28 be a huge difference in speed? Are there any tires you guys recommend that are thicker but won't drag me down too much?
Thanks
Bikes: 2012 GT Transeo 3 2014 Cannondale CAAD 10 105
Quoted: 26 Post(s)
the issue isn't just what size your rims can support. It's what size fit through the important narrow points: brakes/frame
In all likeliness, 28c is the widest your rim will be able to go, but your frame might only be able to take 25c.
Bikes: Giant RS950
Well then the next question then is how can I know what size tire my frame can support?
I bought the bike used, it's pretty old, I know nothing about it really.
Quoted: 26 Post(s)
the only realistic way is to measure at the typical narrow points and take that measurement and physically measure a tire.
not all tires are equal even among the same size.
Just measure the minimum width of the front fork and the rear chain stay to determine the maximum tire size.
Most bikes allow plenty of room for wider tires, however a few racing bikes limit you sizes.
Bikes: Giant RS950
You current rim will support 23/25/28mm tires. The key factor is will your brake caliper and frame allow clearance.
I'm sure in the other areas it has enough clearance though.
You need to look at what part of your frame has the least clearance. It will differ depending on the frame.
On my old road bike I couldn't use Continental 25's in the front because the top of the tire would slightly rub the top of the fork. On my cyclocross bike I am limited by the clearance by the right chainstay.
Also don't forget to check your brakes. There is a limit to how wide a tire will fit between the pads without deflating the tire a little bit.
There is no simple way to guarantee what tires will fit. Sizing isn't exactly standard. Some models of tire tend to run larger than the size printed on the size, while other models may be on the narrow size. Also rims come in different widths, and the shape of the tire will differ slightly depending on the rim width.
If you have 28mm clearance I would try 25's so you have little wiggle room in case your wheels ever go out of true. If there is still plenty of room with 25's then consider 28's.
If you still can't figure it out it might be helpful to post some pictures so we can see how much clearance there currently is. You can also take it to a bike shop and they should be able to help you find an appropriate tire.
Bikes: Giant RS950
I'm just getting confused because I'm thinking about measuring between the brake pads instead of the whole caliper.
Here's a picture I just took. Let me know if it helps. If not I'll try something better!
The measurement is in cm by the way not mm!
Now check to see if you have a small release lever to open the brake caliper wider to say 35mm.
Then take a look at this article and it will explain in detail how to choose a tire width for you bike.
https://www.slowtwitch.com/Products/T...idth_4026.html
Bikes: 2011 Cannondale Carbon Synapse (Ultegra 6800 11-spd), 2009 Blue CXC, 1979 Univega Gran Turismo
Here's my perspective on pinch flats. They shouldn't happen. Pinch flats are most often that the tube is improperly placed. I weigh 230-250 lbs (depends what part of riding season it is, and right now I just recovered from ACL reconstruction). I've never had a problem with pinches. I've run 23s, cheap and expensive, 25s, and ridden rushed limestone on road tires... all inflated to around 100 PSI.
What kind of roads are you riding? What kind of wheels? Have you examined the wheels for dents/cracks? I'm riding a set of SR-2 stock Giant (read cheap) wheels...
Maybe I'm just offended that you're considering 190lbs an "extreme weight" for a tire or wheelset. Take this over to the Clyde forum and some people will laugh at you. I usually run Serfas 25s; they're cheap, but they've been great for me (at 240lbs)
Bikes: Giant RS950
You are making good progress here... with a measured 25mm brake caliper clearance.
I think that's as open as my caliper gets though, I moved the lever and it doesn't open or close too drastically.
It's an old bike and that part could be breaking.
Quoted: 659 Post(s)
Liked 7 Times
The distance between the brake pads is irrelevant - that's determined by how wide your rim is and you won't be changing the rim. What counts is how much space there is between your current 23mm wide tires and the parts of the bike that currently come closest to touching the sidewalls or tread of the tire - that could be either parts of the brake arms, the front fork (esp. the bottom of the crown), rear stays, or seat tube. In principle if you're going from 23mm to 25mm you should only need one mm of clearance since increasing the diameter by 2mm will increase the radius by only 1mm. But tires vary in their actual dimensions so I'd look for at least a couple mm clearance of your current tires before going up a size. To go from 23mm to 28mm should only require 2.5mm (1/10") of clearance, but again I'd want a little margin in case the tire you buy is on the large side. If you have about 4mm of clearance with your current 23mm tires then most nominal 28 mm tires should be ok.
Bikes: Giant RS950
Ok I think I get it, thanks prathmann!
I should be fine to get 28s then (hopefully).
Now the question becomes what tire should I get?
I've been looking around and I've seen a few that don't break the bank (I only ride to school and back, no racing, etc.)
CST Caldera, Vittoria Zaffiro II, Vittoria Rubino III are some that I found. Are these any good?
Also is it ok to ride with a 23 on the front and a 28 on the back as well as being completely different tires?
Aside from considering getting wider tires, I would recommend two things:
* More expensive tubes. Seriously, savings from going with cheap tubes are often more than cancelled by their lack of longevity. I often see cheap tubes blow along the seam because they are poorly welded/glued there.
* Brush up on your tube installation techniques. Watch some youtube videos. There is a difference between simply getting the tube into the tire and doing it right. If you don't do it right, chances of a pinch flat are exponentially increased. If you ever blew a tube while installing it (while fixing a flat), you're not doing it correctly.
Bikes: Giant RS950
Any recommended tires that don't break the bank?
You usually can't go wrong with Continental, Michelin, Vittoria. I prefer the ones with threaded valves, they are easier to inflate and it's one less place to damage the tube while installing it.
I would recommend starting with Continental City/Touring tires and tubes.
Bikes: Giant RS950
Check out https://www.biketiresdirect.com/tires-and-tubes-category
I'll check out some tubes and tires.
I just have 1 last question.
Is it ok to run a bigger tire on the back than on the front?
My front tire is fine but it's 700x23, the back tire I'm looking at is 700x28.
Will anything even change?
Thanks again guys
Other than the rear of your bike sitting a few mm higher than it was before, it shouldn't change much. At the proper pressure the wider tire should be more comfortable over bumps.
