Moore's laws for lights?
Bikes: Bacchetta Giro, Strada
First we had Moore's laws for CPUs, where number of transistors increased exponentially, then it was hypothesized that it might also apply to razor blades ... but is it beginning to apply to bike lights?
Gentlemen, I present the TrustFire TR-D013 7-LED 3-Mode 3000lm Cool White Bike Light - Black + Silver (6 x 18650), because nothing exceeds like excess!
Ironically, with seven LEDs, it could be the first (Ultra|Trust|Whatever)Fire light that is capable of actually producing its claimed number of lumens, though with its relatively small battery pack (compared to the number of lights) if it can, it can't do it for long.
I'm also disappointed that it only has three modes. With seven LEDs (and not the little ones we've seen many of in the past), they should include some modes that have only one light on at a time, moving back and forth like KITT from Knight Rider or other patterns.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I'll believe claimed lumens when I see it tested. Never heard of TrustFire, but I'll presume they're lying until someone with a light meter tests it.
And even if true...they'll drain that battery inside of an hour.
3000 lumens tends to mean around 30 watts, and six 3000 mAh 18650 cells could produce 30 watts for about 2.25 hours. To get four hours out of it, they'd have to reduce the lumens somewhat or be using significantly more efficient LEDs than normal.
The *Fire knockoff are known for crazy lumen ratings, but given that each LED only needs to put out 429 lumens to reach 3000 total ... it could actually he possible in this case.
That said, to expand on what 10 Wheels said ... for these lights, you should question everything.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Trustfire is pretty well known. I bought one cheap light with two emitters, and my experience is that they seem inefficient. It doesn't put out that much more light than the single emitter headlight that I have, but it kills a battery faster.
3000 lumen on this is actually pretty believeable. The two emitter one I bought claims 5000 lumens which is clearly ridiculous. It puts out maybe 1000, at best, probably closer to 800.
Work: the 8 hours that separates bike rides.
Bike Lights, not the Investment of an Intel and Apple Behind the research and Billions of Dollars in Profits as the Pay off.
Though The Germans and Dutch do seem to keep trying to Make more light with the 6v,3w of the typical Hub dynamo.
the item in the OP I see the Emitter in the back not much more Beam shaping than a flashlight. just a bunch of them in a row..
it is going gizmo on the cheap .
Quoted: 3375 Post(s)
Liked 5,514 Times
Omigawd!
Could they make it any uglier?
I would be embarrassed to be seen with that monstrosity.
LET'S ROLL
This light that I tested in 2013(also from DX) was already claiming 3000 lumens.
Don't know if it actually made that; but I do know that it was bright. Too bad it
broke after a few weeks of use in sub freezing temps:
https://www.youtube.com/watch?v=huyC...IoDLA&index=12
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 14 Post(s)
Liked 13 Times
Bike lights are not why high output LEDs are being developed. The end goal is economical low environmental impact replacements for general purpose incandescent and fluorescent lighting.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
What happened to the 2000lm per LED marketing guys?
This light/USB charger is the worst example of lumen inflation I've ever seen -- they claim 2300 lumens, but the reality is perhaps 10 to 15 lumens.
That said, given that it's often on sale for $5, it's not a bad little "charge up your cell phone battery that happens to work as a little flashlight".
Quoted: 7348 Post(s)
Liked 2,466 Times
For a minute, I thought you said Murphy's Law!
I think the lumen wars are pretty much over. Started to taper off around 1500 real lumens. At 2500 lumens it's pretty much done - plenty of light even if your night vision isn't so good. You can get 3000 lumens in a much smaller package that what the OP posted.
Now we're going to get feature creep. Controls, size, battery efficiency, beam shaping, remote control, mounts, size, etc...
J.
J.
Liked 406 Times
J.
J.
Let's see… 1A current drain, they're using 18650 cells which give between 2.2Ah and 3.4Ah, arranged as three parallel banks of two so 3×3.4Ah at best giving us 7.2V at 10.2Ah, or at worst, 6.6Ah.
At least on paper, they should be capable of the advertised run-time, possibly double that. A lot is going to depend on environmental factors.
Of course now all that is missing, is to have about 50 different flash patterns all controlled by one button that cycles through each and every mode. (So when you stop, you spend a good 10 minutes just pressing the button repeatedly to turn it off only to start cursing when you miss the "off" mode.)
Some of that going on, but the major players that are reputable companies are now being very careful to be accurate. Go over to the Light Shootout on mtbr.com and see. Used to be they all quoted theoretical now it's pretty much actual. That word hasn't spread to most of the Chinese suppliers yet, however.
J.
J.
One amp at 8.4 volts is 8.4 watts. 3000 lumens/8.4 watts = 357 lumens/watt, which is significantly higher than the theoretical limit for a white LED, and significantly more efficient than any light of any sort in the real world.
Either 8.4 volts, 1 amp or 3000 lumens is a lie ... they can't all be true simultaneously.
Let's look at this another way ...
I don't doubt the 3000 lumens sounds fishy. Speaking of fish, you could probably cook one on the heatsink.
As for plugging in an ammeter ... that would require that somebody actually buy this monstrosity. But 1 amp on high is probably too low, unless the lumens is really more like 1000 rather than 3000.
As for 3000 lumens, that's only 430 lumens/emitter and is doable, so for the first time in one of these knockoffs, it might be accurate.
But given that modern LEDs tend to not do much better than 100 lumens/watt, that means it wouldn't be drawing 8.4 watts, but 30 watts, and so the run time at that power level could be around two hours, but not much more. And yeah, it would put out a lot of heat, though it would probably be OK if you were actually riding.
Mine (Niterider) is suppose to be press and hold. But of course that function is not always easy to get to because if you hesitate too long you'll just cycle to the next mode. Why do manufactures have to make things so complicated? Is a simple on/off switch something that bizarre?
I had a tail light that had something like 10 modes… this was before me going the DIY route. Turning the bloody thing off was an effort in frustration as invariably whilst trying to cycle through the "other" modes quickly, you'd hit the button one too many times and miss the "off" setting, so you'd have to cycle back through the modes again.
Usually it took about 3 attempts to turn it off. One morning I lost it when it detached from the rear basket. Good riddence.
My current lighting set-up has one switch and two modes: on and off.
8.4 volts is certainly right for a fully charged 2s battery.
Certainly, the much smaller ones (with just one or two emitters) that draw about 10 watts but are much smaller will get too hot if you're stopped, but they're just warm if you're riding.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I am a double edged safety razor user. My razors have but one blade, and it is far superior to my archived quad bladed unit. That being said, for city / road use, my Cygolite 360 will probably stay in use until the battery no longer takes a charge, then I might upgrade, to more lumens slightly, not that I really need it, though.
As a resident computer nerd...Moore's law doesn't apply here. The law states the number of transistors in an integrated circuit doubles every two years. (An LED is a single transistor.) There's greater chance for geometric improvement (as opposed to the exponential improvement in Moore's law) is on the energy side of the circuit. Better batteries and more energy efficient LED's are a promising path. New anodes, like Lithium Air or Lithium Sulfur, and more efficient LED's are coming. The warmth you feel when you touch your light housing is wasted energy, producing heat instead of lumens.
