6 of 1 half dozen of the other?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
Would any of you care to offer up your opinions if given the choice between the Roval C38 and the new Terra C ?
From what I can gather, I’m not seeing much difference other than the C38’s are a bit narrower. Spec’s I’m seeing say one is 1600 grams while the other is 1610 so nothing to be found there.
Application would be a gravel bike that is used nearly exclusively as a road bike with 32c tubeless tires.
Did find one difference, the C38’s have DT Swiss 350 hubs while the Terra C’s have 370.
Quoted: 6972 Post(s)
Liked 10,970 Times
The Terra C is targeted more at gravel riding, with rims that have 25mm internal diameter and 32mm depth; the C38 seems more for road (or 'all road') riding with rims that have 21mm internal diameter and 38mm depth. Also, the DT 350 hubs are nicer than the 370, which is probably why the C38 costs a little more money.
Short answer: if you're mostly on pavement with a little bit of smooth dirt roads, get the C38; for gravel, get the Terra C. (Too bad you didn't ask this question about a week ago, when the Terra C was on sale.)
Upgrade pick is the Terra CL, which shaves a lot of weight -- mostly from the rims, which is good.
Likes For Koyote:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,041 Times
I’ve got over 12,000 miles on a pair of C38s on my Roubaix and another 12,000 miles on a pair of Terra CLXs on my Creo. There’s no ride difference that I can tell. Both roll great and are smooth. Both are awesome wheelsets.
The difference is in the width. On the C38s I’ve run 28-32mm tubeless tires. All are pretty easy to mount. On the Terra CLXs, mounting a 28mm GP5000TL was nearly impossible. I’ve installed 32, 34 and 38mm tires on the Terra CLXs. It’s like 32mm is the new 28mm with these wheels.
Likes For MattTheHat:
I chose to order custom wheels from BTLOS. Delivery took about 30 days. I went with 25mm internal width hookless rims that require no rim tape. Rim depth can be 29-44mm. I found my 45mm ZIPP 303s wheels to be too deep for some gusty winds, so I went down to only 29mm deep profile. They only weigh 1400 grams and cost under $800. Lower tires pressures are possible with the wide width hookless rim. See the ZIPP tire pressure calculator.
https://btlos.com/ar-clincher-hook-l...arbon-wheelset
Likes For DaveSSS:
Quoted: 3956 Post(s)
Liked 7,307 Times
Likes For tomato coupe:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 465 Post(s)
Liked 547 Times
I have the Terra CLX on my commuter / gravel / touring bike. About a year and no issues with them. I had to go with the DT 350 hubs because I have an Ekar group set.
At first I had Marathon Allroad on there. Now I have 45Nrth Gravdal. Both mounted tubeless. No problems with mounting or inflation, but I do use a 11 CFM compressor.
Quoted: 336 Post(s)
Liked 782 Times
Liked 10,970 Times
I think those hubs are DT Swiss, but they're not 350s. I think the internals are from the 240s or even the 180.
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
Quoted: 465 Post(s)
Liked 547 Times
My mistake. My wheels are the CL. The CLX use a hub from the DT / Specialized product cheapening department. The CL use the 350, thus I could get a set that worked with Ekar.
Liked 10,970 Times
Sorry to be so persnickety about this, but I've been researching those wheels lately...The FedEx person will be delivering my Terra CL wheelset today. Glad to see that you're happy with yours.
Quoted: 465 Post(s)
Liked 547 Times
OK. I looked online and saw the CLX at $1100 https://rovalcomponents.com/products/terra-clx and the CL at $1750 https://rovalcomponents.com/products/terra-cl. I just know that I needed the hub that supported the Campagnolo N3W for the Ekar. If I could have used the CLX I would have. Value engineering / Product Cheapening doesn't always make things lower quality. Sometimes the bean counters make a product better.
I have been enjoying the Commute/Touring/Gravel bike a lot. It was even going on 15 MPH or slower road group rides.
Liked 10,970 Times
I'm happy with the CL, as I like the DTS 350 hubs on my other wheels. Over 13k miles in the past four years and they still run perfectly. You can spend a lot more money for not much more quality.
