Touring on a cyclocross bicycle
One of the main differences between cyclocross bicycles and other long distance bicycles is that the bottom brackets are higher off the ground and the chain-stays are shorter in a cyclocross frame.
What this leads to - and I've heard this in a consistent basis - is that the cyclocrosses are better for short, high maneuver biking but are not really good for endurance rides like gravel-grinders/road bikes are.
For those who did long touring with cyclocross bikes, what were your experiences? Do they contradict (entirely or somewhat) the common wisdom listed above?
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Hmm...
I used to have a '97 Bianchi Volpe, which was Bianchi's (rather lame) attempt at a CX bike. I commuted with it every day, 17 miles each way. Its turned out to be a nice-handling and comfortable bike. I can't tell you what the BB height was, but I'm thinking that the Volpe was a better all-road-all-rounder than a straight-up CX for sure. I only carried a rear rack with a gym bag bungied to it, so for being loaded I can't say how it handled. Overall, it was a fast bike and had quick handling, but it did not look like the chainstays were overly short.
This isnt much, but I hope it helps you.
Ive done long touring with a couple of bikes with higher bb's, a cross bike (ish) a Specialized Tricross, similar to the Volpe I believe, as well as a couple of mountain bikes with higher bb's--and I never once thought about how the bb height had any effect, so in my experience, it had no effect whatsoever.
now what IS more important is gearing, a true cross bike will not have gearing low enough for your average tour situation, ie the weight you will carry , and this WILL be a pain in the keester for you.
you won't give a rats patootee about the bb, but there's a very good chance the gearing will have your knees crying uncle and making things hard and uncomfortable for you. (my opinion of course)
if you have a specific bike in mind, let us know.
Quoted: 3459 Post(s)
Liked 1,465 Times
I have never owned a pure cyclocross bike, but my expedition bike has a very high bottom bracket which does not bother me at all. On that bike, my pedals are a bit higher when I am off road, less likely to catch on stuff.
But for on pavement, there is no advantage to a high bottom bracket because you are usually coasting when you go around tight corners when on a bike tour so you are unlikely to scrape your pedal on the pavement with a lower bottom bracket. That said, I however have scrapped my pedals on pavement while cornering on lower-bottom-bracket bikes when riding around home - not touring.
I have three touring bikes, chainstay lengths are 445, 450 and 466mm. I find all work ok, but I use panniers what allow me to adjust my pannier hooks fore and aft.
Quoted: 223 Post(s)
I've gone touring with CX bikes before.
The only major problem I think OP might run into is fitting racks, but bikepacking gear is a thing and works pretty well if you plan on going light anyway. Some bikes like the CAADX have provisions for racks and fenders that more race-oriented bikes usually don't, though you can fit racks like the Axiom Streamliner.
Gearing isn't that big an issue IMHO. It's not that big a deal to get a deralier extender, larger cassette, or smaller chain ring(s) up front.
Pannier weight (distributed low and evenly) tends to have a stabilizing effect on most bikes. It's also just what you are used to - I ride a small-wheeled folder that makes my gravel bike feel like a truck... no problem doing long days on either.
Not a pure race CX bike , but most buy a bike which is basically a touring bike with a little lighter frame tubes.
Commuter bike , hybrid with drop bars , not really a competition cyclocross race bike ..which doesn't even have a bottle boss,
water bottles un needed for a 2 mile lap race that only lasts an hour at most...
Bikes: Tern Link A7 Folding Bike, Marin Gestalt 2019
Quoted: 73 Post(s)
If you can bikepack on a cyclocross, you can tour on one.
Saying that, people tour on Unicycles, so go nuts.
Thanks for the sharings! I probably won't go touring sometime in the near future since I still have a lot of building up to do.
However, at least I am now confident that the observation of cyclocrosses being the better all-around bicycles (when compared with gravel-grinders) is quite accurate.
Liked 1,465 Times
I still am not really sure what a gravel grinder is, but I am assuming that a gravel grinder likely has more room for a wider tire.
Quoted: 137 Post(s)
Liked 81 Times
When I was young and light I did most of my fast touring on steel road bikes, less than 15 lbs load. Endurance was a function of my conditioning not the bike. One bike was a British road bike with lax cross like angles and low bb. One was an Italian road bike with steep angles and high bb. I rode with 28mm tires.
Now that I'm old and fat I have different bikes and posture on the bike but I'd say the Cross Check I have would make a great medium/light load touring bike but is not well suited to heavy rear loads at all. The CrossCheck would have been a much better touring bike than those racing bikes.
I also have a 26" wheeled LHT which can carry a heavy load but is surprisingly nimble with a heavy load.
Quoted: 137 Post(s)
Liked 81 Times
When all is said and done, you can tour with any bicycle... I read the story of a fellow riding a single speed across Australia S to N in the late 1800s.
A single speed! Over 100 years ago!
Get bicycling, and away from your keyboard...
Quoted: 2604 Post(s)
Liked 1,928 Times
FWIW, the year after my TransAm, I met a guy in my town with a (very nice) Surly Crosscheck and panniers. Turns out he'd just got back from his own cross-country trip. IIRC he'd built it up with good, low gears. He had a great trip!
Quoted: 598 Post(s)
Liked 283 Times
Personally I'm not sure if it's safe to tour on a cyclocross bike. For instance, I just finished a week of touring down in Arkansas on mine and couldn't sleep at night, since I was kept up worrying whether my bottom bracket drop was inadequate. Then silly me, I checked the specs online only to find that my cyclocross and a Surly LHT have exactly the same BB drop.
Whew, am I relieved.
Btw, the meth heads didn't get me either, so Squeezie you can't have my Ortliebs just yet. On the other hand I did stumble upon some of the finest pulled pork BBQ I've eaten in a long long time in the middle of nowhere ...Yum
. by robow 77
. by robow 77
Quoted: 52 Post(s)
My ~2010 Bianchi Volpe is a fine touring bike. Room for 35x700c tires plus fenders. Cushy ride. Chainstays are tight but provide adequate heel clearance.
As is often said, any bike is ok. I toured on a mountain bike. Now I have a LHT. What's the difference? Basically the handlebars.
