Coil suspension fork maintenance
Old 07-04-11, 03:08 AM
Most guides on the internet are about forks which work using air pressure however i have a coil suspension fork - Rockshox Tora (some old model) and i don't have it's manual. You can see the fork in attachments.
In all fork maintainance videos i see that there is a foam ring under the wiper seals however there isn't one in mine. Then how i should lubricate the stanchions? Just put some lube underneath the wiper seal where the foam rings were supposed to be? And what kind of lube i should use?
Is there anything else i should do for my fork maintenance other than that?
Also why is that my lockout isn't a lockout anymore - it still gives a stiff ride however the suspension works a bit? Maybe it has something to do with riding on rough roads with lockout enabled?
Sorry for asking so many questions
File Type: jpg
File Type: jpg
1337 is offline
Old 07-04-11, 04:02 AM
jimc101
Quoted: 453 Post(s)
Liked 104 Times in 87 Posts
Read the user service manual, follow the service instructions https://www.sram.com/service/rockshox/7,105
jimc101 is offline
Old 07-07-11, 11:10 AM
well i just found that this fork isn't actually rockshox tora. It is 2009 suntour XCM V2 HLO 26'. I checked out the manual and it doesn't tell anything about fork maintenance.
1337 is offline
captronk
General Cycling Discussion
7
09-25-15 05:56 PM
Telly
Bicycle Mechanics
16
11-14-13 08:58 PM
Imperton
Bicycle Mechanics
1
04-11-13 06:45 PM
griggsaks
Mountain Biking
9
11-20-11 11:11 AM
rudis123
Bicycle Mechanics
2
12-06-10 08:00 PM
