Updating Hyper Spinner Bike that i got for $20
Hey all,
I recently picked up a new 20inch hyper spinner bike for $20 thinking i could use some parts, but i didnt end up needing any. So i took all the heavy parts off (kickstand, brakes, gyro setup) It is actually a nice riding bike and i will use it on days that i dont want to use my expensive one...
So on that note, i dont like the 1 piece cranks, the threaded forks (which are heavy), and maybe new handle bars....by no means am i looking to spend a lot, just wondering if it is even worth changing these things out??
Any help or input would be great!
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Beauty is in the eye of the beholder as they say. You would never get your money back on a bike like this, but if you like it and you have the extra parts why not? What's important is you get out there and ride.
To switch to threadless forks won't be easy. First you will need a 1'' threadless head set and they are pretty hard to find, and when you do find one they are often pretty expensive. Some used cranks won't be hard to find. You will need a threadless stem as well.
I recently got a 20 Hyper Spinner (Black/Green) bike off a friend for my 6 year old grandson. But its missing the Seat & the Seat Post. Could you please maybe help me with informing me of what size of Seat Post these bikes require??
Thank You!
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 345 Post(s)
Liked 186 Times
I honestly don't know as there are various sizes. But 25.4mm is the most common and I would guess they would be using that size. Normally I'd direct you to their website but it seems to be down. https://hyperbicycles.com/
Hack
Quoted: 345 Post(s)
Liked 186 Times
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
Lots of 1" threadless headsets from the BMX racing companies, kids' racing bikes use them. If you're going to use the existing fork threadless though, I don't think you're gaining anything. Probably be pretty expensive - and it's still going to be the same bike. Any 3 piece crank and BB for American BB should work if you want to change that out.
1 in JIS 29.85 29.9mm Bore Diameter
1 in Pro 30.05 30.1mm
1 in BMX 32.6 32.7mm
A lot of Jr and Expert bikes (the kid bikes you speak of) use "Road bike" 1" because it is lighter. https://www.bmxguru.com/products/cru...-headset-black for instance this one clearly says 30.2mm inner diameter and will not fit a 32.6mm old school bmx. Like I said it isn't that 32.6mm 1" thread less headsets don't exist but they are getting hard to find. If you know of one please by all means post a link for the OP and help them out.
Hack
Quoted: 345 Post(s)
Liked 186 Times
There's actually 3 different sizes for 1" head sets.
https://www.walmart.ca/en/ip/20-hype.../6000197682593
I doubt it would use that old standard, probably JIS. In any case, the old school 1" threaded headsets are still readily available - or adapters to go to the smaller headsets.
Porkchop has a bunch of this stuff:
Pork Chop BMX Headset 1" Threaded 32.7mm cup
Pork Chop Headset Adapter Cups
Or here's a guy that shows how to mix and match headset bits to put a 1 1/8 threadless fork into the old school 1" threaded. Will work with some combos.
How To Convert 1inch Threaded To 1 1/8 Threadless
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
So - OP has a new bike, not old school.
Also if you read that thread you will see that trick doesn't always work.But it is a option if the OP wants to try it. The few bmx's that I have come across where the steering is always tight and feels janky but maybe with the right combo he can get some good results.
Hack
Quoted: 345 Post(s)
Liked 186 Times
That's a threaded headset and not thread-less.
The reducing adapter cups I linked would let him run the JIS 1" threadless if it was the 32.7mm size, but I would wager it uses the JIS 1" size.
