Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
CAAD12 help
Old 09-10-18, 08:56 PM
LouELou
CAAD12 help
Hello everyone. I am returning to cycling after a long period of inactivity. My friend has a 58cm CAAD he is willing to sell me very cheap. im concerned about the size. i am 5'11" with only a 30" inseam. a 58cm bike is pushing it. My question is, can i make this work for me. i cant afford anything else and wont be able to for quite a while. thank you.
LouELou is offline
Old 09-11-18, 07:37 AM
Brofessor
Brofessor's Avatar
Bikes: Schwinn Circuit 89'
Quoted: 51 Post(s)
I personally don’t care about the stand over height. As long as your leg is not fully extended at the lowest seat adjustment allowed, you shouldn’t have problem height wise. However, top tube length is a bigger concern, because you can only shorten your reach by a few mm using shorter stem. Ask your friend to ride it for a day or two and see if you feel too extended on it. My bet is that your shoulders will ache after that ride because of too much extension.
Brofessor is offline
Old 09-13-18, 06:53 PM
TiHabanero
Quoted: 1745 Post(s)
Liked 1,373 Times in 720 Posts
I have the same overall height and inseam as you. My son rides a 58 Caad10. Set up with the stock stem it is close. I put a 90mm stem on it and the fit is OK. Keep in mind every rider has a different fit, even on the same frame, so don't take this as a guarantee that you will be comfortable on it.
TiHabanero is offline
Old 09-17-18, 04:57 AM
LouELou
Thanks for the tips. I will def keep you posted.
LouELou is offline
Psychocycles
Road Cycling
5
08-20-18 09:12 AM
chiggy
Fitting Your Bike
24
08-17-18 10:20 AM
Robert A
Fitting Your Bike
13
06-18-18 05:27 PM
PixelPaul
Fitting Your Bike
3
12-29-17 05:20 PM
one4smoke
General Cycling Discussion
15
03-29-16 04:55 PM
