Bolt Broken in Bottle Boss
Bikes: 2018 Specialized Epic Comp Carbon, 1989 Cannondale ST-400, forthcoming SaltAir Cycles Gravel Bike :D
Quoted: 11 Post(s)
Hello, all! I'm trying to refurbish an old Cannondale St-400 frame and one of the down tube bottle cage mounts has part of a bolt stuck in it. I've emptied an entire thing of Phil Wood Bio Lube into it and then tried to back it out with an awl and hammer, but nada. Any other ideas before I have to take a power tool to it? The bolt left a convex nubbin inside the boss, which is both stuck and difficult to get purchase on. Here's a completely unhelpful image of the frame in question and a cute dog. Thanks!
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
That should be easy enough to drill out.
A good picture would provide more useful advice, but yes. Center-punch it (an automatic punch works best here) and use a small LH drill bit, working up progressively until you can either fit a small EZ out, or it backs itself out.
Have not put the BB in yet so maybe you can screw the stub in more
until it falls through and out the bottom ..
Rusted so much it broke taking it out? use grease next time.
C'dale uses Riv Nuts? You can drill those out and replace the whole thing..
Quoted: 4205 Post(s)
Liked 3,864 Times
This one of the good reasons to have Rivnuts as bosses. You can remove the Rivnut's lip and punch into the frame the rest of the fitting (hopefully to have it rattle out the BB vent hole, if not then glue's your quite friend). Installing a replacement nis easy enough although I like to augment the pressing with epoxy.
BTW I have seen more then a few of these Rivnuts corrode to a bolt and become useless. besides the galvanic issues, often worsened by the electrolyte or acidic nature of sports drinks, too many shops and home wrenches don't bother to put a drop of oil on their cage bolts before installing. The soft nature of many Rivnuts (being AL) make the chance of cross threading too easy too.
This would be the time to check the remaining bosses for their tight fits into the tubes, repressing as needed. Andy
AndrewRStewart
AndrewRStewart
Quoted: 5224 Post(s)
Liked 3,581 Times
following & hoping for pics
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
- somebody remind me to give wikipedia $5 this year.....
Quoted: 11 Post(s)
Thanks for all the replies!
Some important context that I forgot: there's no appreciable opening in either the head tube or bottom bracket shell to fish things out of if they fall into the frame, which is why I wanted to avoid using drills n' such. The frame came with both the down tube bosses messed up, each in its own unique way. Already fixed the other one, but this one's defied me so far. Drill it is. If you hear something like a jingle bell on the road and you turn around and you see a guy on a Cannondale swearing at his down tube, you know who it is. I'll follow up w/ better pics and progress.
Liked 3,864 Times
AndrewRStewart
AndrewRStewart
Your workbench looks well stocked enough to own a soldering iron? Warm it up, touch it to the boss rim & use some heat to help loosen the threads.
Just remember to centerpunch the stub, first.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
An important reminder: There's no reason not to start by trying to remove the screw. Left-hand drill bits are readily available (singly) from Grainger/McMaster Carr in the USA. If the stub doesn't come out with the drill bit, you can always proceed to a larger bit and take the whole rivnut out.
Liked 3,581 Times
I'm partial to straight fluted screw extractor bits with a proper tap wrench
Quoted: 11 Post(s)
That's an interesting idea - made me think of maybe using the heat gun on it. Also, wish I could say that that was my shop. I work at a shop in SLC, UT and someone had abandoned this frame before I started working there. Fixing it up in my spare time to use as a winter trainer. Trying to do one repair on it before each shift. And before someone mentions it, I work opposite the master mechanics, otherwise I'd just ask them for help
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
Some (BUSHMECHANIC) say 1 screw is enough to for bottle cage, ziptie over stuffed hole
if you butcher that hole with failed extraction, some drill it out further & retap for M6 bolt instead
Quoted: 11 Post(s)
Here're some pics. Brought it home. Literally haven't had the time to do anything else to it. After making a light mount for a dynamo light by drilling out a store-bought mount, I'm feeling much more suave with the drill, so we'll see how that goes. Just have to pick up some left-handed bits when I'm by Ace.
Broken bolt lurking within.
The whole shebang.
The whole shebang.
Quoted: 11 Post(s)
Update: the broken bolt defeated my punch. Broke the tip off it before I could get anything like a recognizable divot made in the top of it. Tried drilling. Broke the bit, which, in hindsight, I should probably have seen coming (it was a 5/64", so not as stout as the punch). Next step? Different punch, maybe?
My Irwin Cobalt left hand drill bits are quite strong and useful for correcting this problem.
Quoted: 3352 Post(s)
Liked 1,056 Times
Combine several suggestions. Use the lightest oil you can find, even cut it with kerosene and let it soak. Tap in slightly, and warm the tube with a heat gun or hair dryer until warm to the touch, but not ruin the paint. Then if that fails center punch and use a left hand drill or an easy out. Above all be patient.
Quoted: 11 Post(s)
Success! After a broken punch, a broken drill bit, and a few trips to the hardware store for ever-smaller tap wrenches, I got it out.
I used a version of this. Had to step up from a 5/64" bit to a 3/32" bit to get a good center hole and then finished with the 5/64" bit. Dumped a bunch of GT-85 into it before trying the extractor. Re-tapped the boss just to be sure that it was still functional (the bit had jumped around a bit when I broke it). Thanks for all the suggestions/tips/tricks and encouragement! All three bottle cage mounts accounted for!
