Ticking noise from bike during pedaling
Mechanic/Tourist
Yes, that does generally work, and is a perfectly logical way to isolate the problem. The fact that you had a very unusual problem does not invalidate the test.
I'm slowly starting to isolate the problem.
1) It is related to cadence AND pressure. Very slow cadence does not cause the ticking.
2) It is something mechanical because I am feeling it through the pedals at specific points of the cycle. Specifically, when my left pedal is somewhere near the highest position.
3) I am suspecting something is getting loose from all the bumps I ride over, but I will just look over everything.
Mechanic/Tourist
OK, now we have info that can help. Pressure on the left pedal transmits force through the crank arm to the spindle, which then turns the right crank and drives the chain. The right crank on the other hand applies force directly to the chainwheel/chain, although there is also some downward force applied to the spindle. Therefore the problem is likely the left pedal/crank or left crank/spindle interface. Problems in the BB would not often tend to be restricted to pressure exerted by one crank, although that's still a possibility. It cannot be the chainring bolts. We now need info on what you've tried, particularly if you have followed dsbrantjr's advice: "Remove the pedals, clean male and female threads and the faying (mounting) surfaces, grease threads and reinstall, torqueing firmly." Follow the same process for the left crank arm interface with the spindle. Also check the left pedal to make sure the cage is securely mounted to the main body.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
But if you have another set of pedals laying around or on another bike do a pedal swap and see if the noise goes away before diving into the BB.
Bikes: BiknBrian brand custom 26 inch commuter trekker, Cannondale F600 Single Speeded MTB, Nashbar Cro-Mo CX, some other bikes and parts that could be made into bikes.
Does the left crank arm have pinch bolts or is it a single center bolt?
The non pinch bolt, outboard beaing FSA cranks are junk in my opinion. They use a press fit to hold the crank arm on and a wave washer to try to hold preload. This allows a little but of wiggle under load which shows up as a click as force on the crank shifts from side to side. These non pinch bolt cranks also have a tendency to come loose and once the press fit tolerances change the cranks will never stay tight again.
It is a piss poor design that was devised in order to market carbon fiber cranks since you can't flex carbon and use pinch bolts. In fact Shimano was one of the last players to offer carbon cranks because they knew you couldn't just omit the pinch bolts. They resisted carbon cranks for years until they developed their own way of securing carbon cranksets. I can't remember the details of their design but it solved the single press bolt problem.
I learned all this after having two bikes with FSA cranks develop the same issues. The unfortunate part is that a lot of cheaper bikes use these garbage FSAs to keep costs down. They even use the design on aluminum cranks. Now I just automatically add the cost of a new crankset to any bike sold with a non pinch bolt outboard bearing crankset.
F'ing techno junk. Whatever it takes to sell people the latest and greatest crap. Doesn't have to work, just has to look good and spec well on paper.
Quoted: 1943 Post(s)
Liked 2,164 Times
Plus, if I shift all the way to the highest gear on the 34T ring on the front, I hear the chain rubbing quite loudly.
Side question: is it possible to remove chain rub on all gearings on a compact set up? I find that I am either cross chaining pretty hard on the small ring (high gear) or big ring (low gear). It's a standard 34/50T.
I am a proponent of replacing a 50t on a compact if it is rarely getting used because a 34t is a horrible cruising ring.
John
Hmm. I honestly have no clue how to tell what kind of bolt it has. I just see a bolt that tells me what direction to turn my wrench on the left side
I lubed my pedal threads with grease, but i haven't had a chance to ride because of rain. I am thinking it is the bottom bracket though.
And thanks for the tip John. I definitely find the 50T too big to use on the street. I am probably going to switch to maybe a 46 but for now I'll think of it as strengthening my legs!
Bikes: S-Works Tarmac, Nashbar CX, Trek 2200 trainer bike, Salsa Casseroll commuter, old school FS MTB
Quoted: 31 Post(s)
Edit: depending on how you cross chain you may want to gear down as well, and do CX gearing. It all depends on if it feels generally tall or under geared;
Quoted: 2432 Post(s)
Liked 638 Times
No one posted the big one. Even that link didn't have it. Tighten the rear wheel skewer. 95% of the time with I get a tick with each crank revolution in and out of the saddle I pull over, tighten the skewer a hair and then it's gone.
Mechanic/Tourist
Liked 638 Times
Yes, and yes again. You're absolutely wrong. It happened again to me three days ago. A click on the right side every time the crank was at the 3 o'clock. Pull over, tighten skewer (I had removed the wheel a few days prior), click gone. You're wrong.
Mechanic/Tourist
Well, I di say not likely rather than not possible. Yours is a very out of the norm situation. I would hardly call a q/r caused click "the big one."
Mechanic/Tourist
I guess you're the expert.
Liked 638 Times
I don't claim to be an expert, but you certainly aren't. I'm just going off 30 years of experience from myself and other guys I've been on group rides with over the years who had the same issue. Not only is it common, it's the very first thing you should check because you don't need tools and it takes 10 seconds.
Liked 253 Times
Make sure something weird like laces aren't hitting the crank arm.
Try putting some lube on your cleats and on your pedals springs, if the click is still there after doing that then try swapping the right pedal with a right pedal from a different bike and see if the click remains.
Then see this if the issue is still there: Creaks, Clicks & Clunks...
Fixed my ticking problem
Fixed my ticking problem I know this thread is a couple years old but it helped me so I thought I’d post my results:
I had it in my head that the problem was coming from my crank bearings and I took them apart twice with no luck. After reading this forum I got the idea to check my pedals and sure enough the right pedal bearings were the cause. The sound was amplified by the bike so much that I didn’t think it could be the pedals but when I took it off and pressed against my ear while turning the bearings I heard the faint clicking. Replacing them totally fixed it.
I think what helped me figure it out was reading where someone said that it’s almost never the bearings… And the mechanic at my bike shop said pretty much the same thing… that if it was the bearings it was probably just too loose . As I said it turned out to be the pedals .
hope this helps .
oh, I assume it doesn’t matter but I have a 2015 specialized diverge carbon
hope this helps .
Good to know - Saturday while riding I notice a tick-tick noise every time I pedal on my left foot when I was on a short hill.
On flats I couldn't hear so I tried to have on a higher gear and stand pedal on flats and I hear the noise.
Stopped and checked if left pedal is loose or has some wobbling but it seemed not. Took the opportunity and relieved myself - nothing to do with noise.
After a while even on flats I started hearing without figuring out what it is.
Today I was riding a bit and on hill up I hold the handle very close to the stem and quiet. Have to double check, but it seems coming from the right handle brifter.
Did someone had tick noise from handlebar before?
