Xtracycle custom wheelset suggestions and other build questions.
Bikes: [IMG]https://i531.photobucket.com/albums/dd359/89ScottG/TourdeScottsdalePic.jpg[/IMG]
I am building an Xtracycle from scratch. I'm using a 2004(?) TREK 4500 frame. I personally weigh 250 pounds and will use this for of course cargo, but also out of curiosity, I'd like to try some loaded tours with it. So strength and touring performance combined is what I seek in a wheelset.
Any suggestions for wheel builders at a "reasonably" priced product to meet my needs? I purchased a wheelset from BWW in the past and have been very pleased, but Pat doesn't have the hubs to accommodate a high spoke 26" rim.
Some technical questions: The bike originally had an 8 speed cassette which I still have, and the spacing was 130 (I think?) but spacing becomes a moot point with the Xtracycle frame kit I'm assuming? I already ordered a Shimano Deore XT FC-M770 Mountain Bike Crankset (180s) which is deemed 9 speed. I have read this crankset to be fine if used for either 8 or 9, but correct me if I'm wrong. To be easy though, by going custom build with my wheelset, I'd just assume make it a 9 and buy a new cassette.
I guess I could just use a little assistance and advise in navigating the planning and organizational side of this build. The frame, rigid fork, and Xtracycle parts are at the powder coaters now, so the slate is pretty much clean and open for suggestions . . . aside from color at this point.
Link to crankset I've purchased.
Aaron's in Seattle has done the reasonable thing.. 48 spoke Shimano Tandem hub with shorter axle
Salsa Gordo, a good rim pick,
add a thread on to 6 bolt disc adapter, thinned down to align with ISO caliper..
for stopping the rig, rider, and load ..
Long-tail, i'd think a hydraulic disc a better choice, given the distance between hand lever and caliper.
My fork has disc tabs on it, so now would be the time to work this out. I'll definitely inquire about it. I've never had disc brakes, so this is a new area for me.
Really Old Senior Member
IF the bike has 26" wheels, your spacing would be 135MM.
I converted my 2008 Globe from 8 speed to 9 and had no issues with the cheap, ALTUS crank set for function.
Since the wheelbase is increased, more of YOUR weight will be on the front.
Maybe a 36 spoke wheel would be sufficient, depending on how much weight you plan on putting on the rear.
The Clydesdale forum has quite a few "wheels for heavy riders" threads.
