Rode my 1st recumbent trike today!
Guy across the streets G/F has one and brought it over, not sure of the brand but it appears very well built and engineered, not cheap at all. It had an 8 speed internal gear hub with was pretty slick. I really enjoyed riding it until I came to my first high speed turn and unexpectedly got the thing up on two wheels. If my hip arthritis gets worse I might consider one but I'd have to have it fitted as the one I rode actually made my hip hurt MORE than my bike. It was a windy day and I'd just done a few laps on my bike when I tried the bent. Best thing about it? headwinds are not felt nearly as much. Maintaining speed into the wind is a breeze (excuse the pun).. I did not try to climb any big hills though and worry it might not be well suited for that.. Anyway it was really fun and if could no longer ride a bicycle, I would get a recumbent in a heartbeat. Don't knock it till you try it!
Bikes: 2013 Haro FL Comp 29er MTB.
Quoted: 1470 Post(s)
Liked 45 Times
Fast forward a few years and a few bikes and I had several road bikes and two MTBs and still had the Revive. Three of my friends that rode in our C group had bents, two Cat trikes and some low rider two wheeler. Long story short I loved the Cat trikes and someday I might have to have one. And while the two wheeler was fast on the flats and real fast downhill it was a pain on long climbing hills. You start shifting as soon as the hill starts, at least I did, and thankfully it had a bunch of gears because you cannot stand to get over that last steep part of the hill.
I can see the temptation and they can be a blast to ride. I have no clue how they do in the dirt as a gravel bike or MTB or even if they can be used that way.
'Bents are a lot of fun. To climb mountains, you have to shift down, be patient, and spin. That said, I have ridden my TiRush in the Rockies on 11,000+ foot passes.
The trikes are even more fun, but they are heavier, which you definitely notice when climbing.
Conquer Cancer rider
Bikes: Fun bike, city bike, Bike Friday, Brompton (also fun bikes)
Quoted: 18 Post(s)
The spouse just acquired a high-end recumbent trike, and I tried it, very briefly. (It would have been easier if I could actually have reached the pedals). He also got the two wheel on a curve experience, and says you really have to lean into the corners to stay on the machine. Machine is orange with a big flappy orange flag, and he wears orange (or day-glo yellow) when he rides it. But you are still really low to the ground.
Me: I'll stick to two wheels at the regular bicycle height from the ground.
Zero gallons to the mile
Quoted: 1572 Post(s)
Liked 643 Times
I'm betting that you're taller than she is. A shorter crank might fit you better too. I can just tolerate a 170 mm crank on my diamond frame beater but 165 mm is the sweet spot for me on my recumbents.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
My wife rides an ICE Sprint 26 recumbent trike that I have ridden on many occasions on days when she doesn't ride. While certainly not as fast as my road bike, riding that thing is a complete blast. It's as much fun as riding a go-cart. I love the way they corner and the fact that if you suddenly stop, you aren't going to hit the ground because you couldn't unclip in time. One day, I plan on getting one for myself but that will be when I can no longer ride the road bike.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I get my recumbent bicycles up on two wheels every time that I ride!
Getting a recumbent tricycle up on two wheels is not uncommon. It's entirely possible to flip a trike, too, but much less common.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
My experience is that headwinds are less burdensome on a 'bent, but still no fun.
Bikes: Gary Fisher Hi-Fi Deluxe, Giant Stance, Cannondale Synapse, Diamondback 8sp IGH, 1989 Merckx
Quoted: 51 Post(s)
"Tadpole" (two wheels in front) trikes are less likely to turn over when cornering.
Joe
Joe
Quoted: 523 Post(s)
Liked 230 Times
Not necessarily. All tadpole trikes are not equal when it comes to handling. The one ridden by the OP is a Terratrike Rover TerraTrike It is a high-seat entry level trike. The COG is higher than on most tadpole trikes. I could easily lift a front wheel going into a turn on my Greenspeed GTO trike with the seat at 45, degrees and the bottom of the seat 9" off the ground but find that same maneuver difficult on my Catrike 700 with the seat angle at 27 degrees and the same height off the ground for the seat bottom.
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I bought an ICE sprint about 2 years ago and am well on the way to 1,000 miles on it. Although I don't ride it on the street (wife's orders) and it won't replace my other bikes, it is a real blast for long leisurely (relative term) rides on the local trails. It's one of the few things that allow an old guy to impress pre-teen kids.
Quoted: 51 Post(s)
VegasTriker:
The overturn problem is always about the CG (center of gravity) moving outside the triangle defined by the contact patches of the wheels.
The higher the CG, the less turn (lateral) acceleration is required for the 'effective' CG to move outside the triangle and raise a wheel.
The difference between two-in-front (tadpole) three wheeler and one-in-the-front three wheeler concerns the fore/aft loading of the wheels under braking and/or when going downhill.
If you are turning sharply and/or braking while turning, the one-in-front configuration is much more likely to overturn; same thing for turning while going downhill.
Many folks, and I know a few, have no problems with one-in-front trikes. But, they tend to be those of us who use their one-in-front three wheelers for going to the market, Starbucks, etcetera.
I would never buy a one-in-front trike.
I was responsible for and managed (1969-70) the testing of the Honda three-wheeled "ATC90." --- Intitially named "US90."
I told them not to build it because it was unstable. 'They', however, did build it (and got rid of me) and subsequently killed 1400+ riders and put 9,000+ others in wheelchairs or perpetual bed.
I'd love to have a "tadpole" e-Three wheeler for when I get older (I am 74).
It would be a low one (CG).
Joe
Joe
Liked 45 Times
Explain Patient? The one I tried was just very slow and spinning was easier but not any faster. But then I am not used to riding a bent.
I just got back from the Smokey Mountain Recumbent Rally in Tennessee. There were 95 registered cyclists, and of that number, I think 90 of them were on trikes. Trikes are generally heavier than 2-wheelers, and have the extra wheel's worth of rolling resistance; so they tend to be slower climbing hills than most 2-wheeled recumbents, and much slower than a good roadie. The main advantage, to my way of thinking, is that they can go extremely slow without falling over. Of the 90 or so trikes at the rally, maybe 2 or three were capable of even remotely matching my normal speeds.
It's pretty common for new bent riders (or test riders) to pedal slowly in a too-tall gear, which can make the hips and knees hurt.
