Hydraulic Disc Brakes
New Bike
I am considering buying a new Trek bicycle with hydraulic disc brakes (Shimano 105 group set). To transport my bike, I take the
wheels off and put everything in the car trunk.I was told that when the wheels with the brake rotors are off the bike and if the brake
control levers are depressed, the hydraulic pistons will expand and prevent the wheels from being reinstalled. The brakes will need
to be bled to reinstall the wheels.
Is this correct?
Is this correct?
Liked 2,979 Times
That is correct to assume.
-Oh Hey!
-Oh Hey!
Quoted: 4227 Post(s)
Liked 2,488 Times
New Bike
Is this correct?
Is this correct?
Quoted: 9656 Post(s)
Liked 6,366 Times
Liked 2,979 Times
A folded over cereal box flap with a bread tie works. That bread tie is essential if the bicycle is roof mounted without the front wheel installed.
-Oh Hey!
-Oh Hey!
Quoted: 6972 Post(s)
Liked 10,970 Times
No. All you have to do is insert a plastic tire lever in between the pads and push them back into place. Alternatively, just don’t pull on the bloody brake levers while the wheels are off the bike. Or use the plastic inserts that any shop will give you for free.
Likes For Koyote:
Liked 2,979 Times
if there's enough of a gap to pry both sides open & each piston is equally extended out.
-Oh Hey!
-Oh Hey!
Quoted: 20810 Post(s)
Liked 9,456 Times
New Bike
Is this correct?
Is this correct?
As mentioned by others, Shimano has orange spacers that you can stick between the pads. Shimano also has yellow lever lock thingies that slide in under the levers and keeps both the brakes and the shifters from being actuated. I take long road trips regularly and I use both, though I could probably get away with just the lever block thingies.
I took a screen shot of a video with the lever block - they came with my levers when I built up my bike and I would expect that the shop that you buy from would have a box of 'em laying around if you ask.
Likes For WhyFi:
Liked 9,456 Times
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
As people have said, you can use the travel block that any shop can give you. Most shops will give you them for free. I have 5-6 in my car and another 10+ in my garage.
Also, all you may need to do is push the pads back, no bleed needed.
Liked 10,970 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
This has always worked for me. Even putting a 56cm frame and both wheels in the confines of a Honda Civic in the dark I have yet to inadvertently bump one of the levers. Additionally when I do need to trunk my bikes instead of using a rack, I prefer it to be my disc brake bike over one of them that I have to wrest a tire through rim brakes.
Likes For Chuck M:
Liked 2,979 Times
Liked 9,456 Times
I can't say that I've ever seen a piston that didn't back off enough to slide in a thin blade when the lever was released. Or, if nothing else, you could just remove one screw and remove the pads to give yourself plenty of room between the pistons.
Liked 2,979 Times
given how many economical quick solutions there are for preventing an issue, their is no reason for disregarding taking the precautions in preventing problems.
-Oh Hey!
-Oh Hey!
Liked 9,456 Times
Sure, but there's also no reason for boogieman scare tactics and letting someone believe that they may need a bleed job because their lever got depressed. It's silly.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 271 Post(s)
Liked 447 Times
Someone's trying to scare you.
Liked 2,979 Times
IMO; It's a scare tactic if the operator doesn't know what to feel for during the use of the brakes.
-Oh Hey!
-Oh Hey!
Liked 9,456 Times
Liked 10,970 Times
Liked 2,979 Times
Liked 2,979 Times
Liked 9,456 Times
B) pistons aren't going to be overly extended unless the pads are removed
I think it's fair to assume that there's no compelling reason to continue here, so I'll bow out.
Likes For WhyFi:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
...I was told that when the wheels with the brake rotors are off the bike and if the brake
Is this correct?
Is this correct?
Likes For Random11:
