Two rim brake calipers on front wheel
Old 09-20-22, 05:27 AM
JISO
Bikes: Piazza-Rossin Pista, Vitus 979, Trouyez Randonneuse, Alan Competizione, Ikea Sladda
Quoted: 21 Post(s)
Tempted to try this out. It can be done with a set of aero rim brakes that mount to the fork rear, such as TRP T925. Mount the front one to the rear of the fork and the rear one to the front of the fork.
Anyone ever done this? Would the additional forces damage the fork?
JISO is offline
Old 09-20-22, 05:42 AM
RB1-luvr
I don't know.
RB1-luvr's Avatar
Quoted: 317 Post(s)
Liked 853 Times in 446 Posts
your idea reminded of this.
RB1-luvr is offline
Likes For RB1-luvr:
Old 09-20-22, 05:57 AM
JISO
Quoted: 21 Post(s)
Ha, tempted to add a coaster brake
JISO is offline
Old 09-20-22, 05:59 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Most brakes are effective enough to launch the rider OTB at full effort. And forks generally survive that.
Double brakes will not increase the force on the fork.
Well, maybe a TINY bit, by locking the wheel a tad faster.
I wouldn’t worry about THAT part of the scenario.
Tandem riders sometimes use double brake setups. But usually rim + hub brake combinations.
dabac is offline
Likes For dabac:
Old 09-20-22, 06:15 AM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
IMO there's no stress related reason why you shouldn't do this.
However, there may be a simple reason why you couldn't ------- How do you plan to mount two brakes back to back through the one hole?
FB
Chain-L site
FBinNY is offline
Likes For FBinNY:
Old 09-20-22, 07:35 AM
JISO
Quoted: 21 Post(s)
You mount the caliper going to the rear of the fork onto the longer recessed nut and attach the nut to the front caliper's bolt.
For T925 you have to swap the bolts to do this
JISO is offline
Old 09-20-22, 08:40 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4210 Post(s)
Liked 3,878 Times in 2,315 Posts
One of the really nice features of having only one caliper per lever and having a caliper on each wheel is one can modulate the braking forces and better control their bike is varying conditions. So in my world having two calipers on one wheel would mean that each has its own lever, pretty much eliminating the ability to have the other wheel have its caliper on its own lever and still be able to modulate that brake.
I have thousands of miles on tandems and have the rear hub brake (sometimes called a drag brake) controlled by a bar end "shift lever". Fine for setting an amount of brake application but it rots for any real modulation. Early on my first tandem used a brake lever with both ft and rr calipers controlled by it, two cables entered the lever. With the different cable lengths and different "power" that a ft and rr brake have getting the balance between the two cables was impossible. Oh, one could set up the balance to work OK at slow speeds but than it would be poor at higher speeds.
Are you having stopping problems with the usual single caliper on each wheel? I wonder what problem you are trying to solve. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 09-20-22, 09:03 AM
JISO
Quoted: 21 Post(s)
Correct, one lever for each caliper, both on the front wheel. Should result in more braking power than F + R due to mechanical advantage
JISO is offline
Old 09-20-22, 09:09 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Braking power is always limited by the available traction. Think about that.
cxwrench is offline
Likes For cxwrench:
Old 09-20-22, 09:17 AM
daywood
Quoted: 62 Post(s)
Liked 255 Times in 96 Posts
My vintage tandem came without the rear drag brake setup so I experimented for a while using two rear calipers with a brake cable splitter/doubler from the lever. I’d have to say that experiment failed. I found I got better braking, and certainly better brake “feel,” from one caliper. I found my experiments with brake shoes more fruitful for improving brake performance. Conversely, I’ve always found it pretty easy to achieve as much brake performance as I need on the front with a single caliper of any kind. So, other than achieving a unique look (which I can’t discount), I think you’ll find two up front aren’t necessary.
daywood is offline
Old 09-20-22, 09:25 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
You'll need something like this
​​​​​​https://www.thebikesmiths.com/produc...RoCdikQAvD_BwE
dedhed is offline
Old 09-20-22, 09:29 AM
JISO
Quoted: 21 Post(s)
Good point, yes I think traction will be the limiting factor here especially with a 23mm in the front
JISO is offline
Old 09-20-22, 10:21 AM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
and quite possible loss of control with over braking on the front, speaking as person who has gone over the handle bars with kookstop salmon pads on universal 88 brakes
also you lose the ability to brake and control from the rear brake.
put is this way....do you see any pro's road or mountain using a set up like this? if there were an overall advantage you would
IMHO no value add, along with fussy implementation not advised
squirtdad is offline
Likes For squirtdad:
Old 09-20-22, 10:32 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Scratch up the brake track with coarse emery cloth and one brake will put you over the bars.
Bill Kapaun is offline
Old 09-20-22, 01:16 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Or (and probably usually for the front brake) the dynamics of stopping and not going over the bars. In the rain is the one place where two calipers in front could be really good as the rear would wipe the rim for the front.
79pmooney is offline
Old 09-20-22, 03:30 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
I'm not sure that I've had a bike that had enough brakes to lock (skid) the front wheel on dry pavement, and I'm not sure why that would be a performance goal to chase.
Pretty much all of my bikes, though, have enough brakes to lift the back wheel, at which point 'more' front brake just means that you can launch yourself OTB just that much harder.
One front brake should be sufficient for this, if it's not; you've got your setup wrong
Ironfish653 is offline
Likes For Ironfish653:
Old 09-20-22, 03:37 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
The only time I've seen this done with any "success" was on a bike set up for a rider with one severely deformed hand. That hand was unable to operate a brake lever so his other hand had to do both. It worked in a manner of speaking but certainly wasn't ideal.
HillRider is offline
Old 09-20-22, 04:45 PM
FBinNY
Actually front wheel braking isn't usually limited by traction. Instead, what matters is the "tip vs slide" calculation.
Essentially, What matters is the slope of the line from the front wheel's point of contact on the pavement (where braking forces happen) and the center of gravity of the rider and bicycle. For practical purposes consider the braking force to be along that line, and producing both a vertical and horizontal vector. As long as the vertical vector is less than the rider (and bike's,) weight, gravity will keep the bike down. As brake force is increased, that vertical component increases, until eventually it's large enough to lever the rider upward.
Note that this is a cascade phenomenon, because as the rider lifts, the line of action changes in a way more favorable to further tipping unless the brake is released (or eased off). Overall, safe and effective front braking is about skilled modulation and keeping the CofG lower and farther back from the front wheel, which is why it's virtually impossible to have an endo on a recumbent or tandem.
There are two other key factors ------ While, tire traction is usually adequate to achieve a tip condition in most cases, slippery conditions may become a limiting factor. There's also a dynamic factor, which I liken to shifting cargo in trucks, Inexperienced riders in a panic stop often relax their arms such that as the bike slows they slide forward, in such a way to change the vectors in a way favorable to tipping. This may explain endos that it theory shouldn't have happened.
So to the OP - if you can stop hard enough to lift the rear wheel, you've got all the brake thee bike can tolerate. OTOH - if you cannot reach the tipping point, then more brake, wisely moderated, MAY help.
FB
Chain-L site
FBinNY is offline
Likes For FBinNY:
Old 09-21-22, 12:28 PM
KerryIrons
Quoted: 506 Post(s)
Liked 639 Times in 357 Posts
Nope. Unless you have crappy brakes now, you should be able to cause an endo with a single front brake. Shifting your weight to the rear allows you to get braking from the rear brake as well.
KerryIrons is offline
Old 09-21-22, 10:36 PM
oldbobcat
oldbobcat's Avatar
Quoted: 514 Post(s)
Liked 450 Times in 338 Posts
When I lent my wife's Trek FX with linear-pull brakes to my daughter's ex-boyfriend, the first thing he did at the bottom of our hill was squeeze a handful of front brake and somersault over the handlebar. We spent the afternoon in urgent care waiting for the doctor to stitch the cut in his chin. So my first question is, what do you want to do this for?
oldbobcat is offline
Likes For oldbobcat:
Old 09-22-22, 12:38 AM
JISO
Quoted: 21 Post(s)
Haha great story
Operationally it looks like it's a no-go. Setup needs a non-standard serrated washer through the recessed nut. There's also the issues mentioned above. Might still be useful for a tourer where faceplanting is less likely
JISO is offline
Likes For JISO:
Old 09-22-22, 03:14 AM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Quoted: 222 Post(s)
Liked 123 Times in 91 Posts
I've only seen dual front brakes on trikes, usually racing trikes, like Longstaffs.
Jax Rhapsody is offline
Likes For Jax Rhapsody:
