Di2 Junction box mount
The type that attaches to your steerer. Any suggestions between these 2 types? And, for a 6 degree stem, would it be better to buy a 7 degree mount if I want to mount it just below the stem?
https://www.aliexpress.com/item/Four...AbTest=ae803_5
https://www.aliexpress.com/item/28-6...85c5b5d31aeb-0
Quoted: 4717 Post(s)
Liked 1,882 Times
this one should work fine.
https://it.aliexpress.com/item/Fouri...e4d1331144d9-8
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I use a Fouriers. Works great. Depending on your stem geometry, you may need a spacer between the mount and the stem anyway.
I would get a 7 degree mount, but neither of the ones you posted, unless you have a 31.8mm steerer tube.
Chose those as my new Canyon has that odd 1 1/4 steerer. That's 31.8 I think.
https://www.canyon.com/en-in/gear/co...laenge=90%20mm
Liked 406 Times
This is the stem. It clearly says 1 1/4. Then again, I'm not too great on all these specs.
Gravel Rocks
Quoted: 3242 Post(s)
Liked 2,088 Times
I’m just puzzled that ya’ll find that the stem adapter looks better than the rubber band thing Shimano provides.
To each his own I guess.
Wondering if I should just stick that box underneath the stem with double side tape. Probably the cleanest solution? I've got a square profile stem too.
It weird shimano didnt figure out a neater solution to this. The box with the band sticks out like a sore thumb, but the bracket is no better.
think they have most of this years bikes have it built into the frame at least the few bikes I took out for a test ride and many more in the store had them built into the frame
Finally decided to just stick the mount under the stem. So, would you guys suggest Sugru or Blu Tac. Would Blu tac hold?
Quoted: 275 Post(s)
It's some sort of composite material. I assume it's not parallel because it would then interfere with those stems that people "slam". My stem just so happens to have a decent up angle on it so there's more space. The stem the bike came with was quite the opposite and you could barely see a space between them.
Quoted: 20810 Post(s)
Liked 9,456 Times
