28 mm on a Cervelo R2
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
Any one put 28 mm tires on their Cervelo R2? will they fit?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Which year? Which tire?
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
2016 rim brake probably gatorskins.
i guess i could just experiment with it but wasn't sure if anyone had tried it.
Quoted: 18883 Post(s)
Liked 10,646 Times
Friends don't let friends ride gatorskins.
Quoted: 7653 Post(s)
Liked 3,481 Times
I have a clone of that model R5 .... and it fits fairly beefy 28s (I think 22-mm inside rims?) and there is enough room I wouldn't worry. best thing, of course, is to measure.
Liked 10,646 Times
I had an R3. It fit 23s, 25s would have rubbed (which means eventually sawed into the frame). This was from a long time ago (7 years?) and newer Cervelos come with 25 mm tires. (I don't think they've been making the R2 that long, though?)
Also no matter the size of the tire itself, the rim you put it on has a lot of say in how wide it actually is in practice.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
That one is limited to 25c, especially with Contis.
Oh and please try better tires.
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times
I've got an R3 in the same model year which I think is pretty much the same as the R2 except for the fork. My wheels (rim brake) are 18mm internal and I run Conti GP4000 in 25. I don't think I could go to 28s.
Bikes: Cervelo S3
Quoted: 38 Post(s)
25 max(actual inflate size when on rim not some garbage written on the side wall of the tyre) without rubbing, don’t listen to these clowns.
