Brompton build - the movie
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
Brompton recently manufactured their 1000000th frame. They've released a youtube of the subsequent prep and build.
1) The one you buy isn't done this way. It goes down an assembly line.
2) If you've done this kind of work, you'll realize the fork/stem, bottom bracket, brakes and bars are "like we did it in the 1980s" (NTTAWWT). The Brompton design dates from the 1980s.
3) Grease. Torque wrench.
4) Headlamp, but no rear lamp/reflector.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I looked with interest on them connecting the split shift cable at 14:06. I consider that split cable an awful solution and, after enough many struggles of my own, the split cable got banned from my Brompton. However, the short nose, thin tip pliers they use there are interesting. I never saw such pliers before.
Quoted: 137 Post(s)
Liked 51 Times
[Those pliers are used by textile mechanics, called needle pliers because one changes out bad needles on machines with them. you sometimes have 40 needles an inch so tips need to be very thin ..
OTE=2_i;22820975]I looked with interest on them connecting the split shift cable at 14:06. I consider that split cable an awful solution and, after enough many struggles of my own, the split cable got banned from my Brompton. However, the short nose, thin tip pliers they use there are interesting. I never saw such pliers before.[/QUOTE]
Quoted: 840 Post(s)
Liked 336 Times
Can you provide a link to such pliers, by any chance? The only thing I found in this direction was bookbinder's pliers.
