Checking a Glue Job
Bikes: Giant TCR and Giant TCX
Checking a Glue Job
How do you check if a tubular glue job is adequate? I just glued my first set of tubulars and all seems well and good, but I'm nervous to corner hard on them since I did the job myself. It wasn't hard and nothing seemed to go wrong, but I just don't know!
I read somewhere that you can deflate the tire and give it a little tug all the way around and, if it doesn't lift up, then everything is good to go. I did this and everything seems good.
Thoughts?
James
Thoughts?
James
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Thoughts?
James
Thoughts?
James
Also to help with flats use Stan's No Tubes latex based sealant. This stuff only adds a few grams of weight but will save you a lot of time and frustrations with flats. All tubulars have a removable valve stem, so remove it and pour one ounce of Stan's in, replace stem, turn stem to 8 oclock position and pump air in. Follow the directions because it may be different from what I'm telling you because I can't remember for sure how it was done.
Quoted: 31 Post(s)
Liked 10 Times
Others have reported that the efficacy of tube sealants is inversely proportional to tire pressure. I would not recommend such sealants for narrow profile racing tubulars that are inflated to 100+ psi, based on my experience.
BTW, there are still tubulars sold without removeable valve stems.
Liked 253 Times
I never used any goo in Tubulars because they weren't out yet when I was riding on them. I know Slime is worthless in high pressure tires, but I did hear from a few tubular users that Stans was great stuff as is the sealant that Tufu uses, see: https://www.tufonorthamerica.com/accessories.php But I have no personal experience, though I haven't heard any complaints about those sealants.
But unless you have a fast sudden major blowout that blows goo all over your bike, a small pin hole which is what most flats consist of will not spray goo all over you bike because the good sealants seal so fast a lot of times you don't even know you had a puncture! I tried using Slime and that stuff wouldn't blow out of the tire hole, it blew out of the tube making a mess inside the rim, but that crap won't seal instantly and won't seal above 70psi so it's useless in road tires.
SBinNY says that there are some tubulars sold without removable valve stems, so if you want to look into sealants make sure the tubs you get have removable stems. I thought all tubs came that way today, but obviously not.
