Crank Puller Tool Mismatch?
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
I am trying to remove the Sakae crank from a Schwinn World Sport (1987). The size of my puller seems right, but the threads on the puller won't catch. Are there different threads for the same size crank? I am using a Sunlite Series I Crank Puller.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
A Sakae crank should use a standard 22mm puller thread. Are the threads in the arm damaged?
Quoted: 1438 Post(s)
Liked 1,092 Times
See if it fits the threads on the other side, they should be the same. Perhaps, as JohnDThompson suggests, the threads have been stripped. If so, the crank can be removed with Jacobs chuck wedges, #3 size IIRC.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
It's always hard to advise when you can't put your eyes and hands on something, but here goes:
First, have you removed the crank bolts? They would interfere with screwing the extractor in. If you have nutted spindles, they again may interfere with your tool. As stated above, your threads may be a bit messed up. Have you tried both sides? It's unlikely that the threads would be messed up on both.
Post some pictures when you have a chance.
Quoted: 212 Post(s)
Liked 111 Times
On closer inspection, it is the crank puller that is damaged, with a flattened thread. Problem solved! Thanks for the input, guys.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
you might be able to repair that damaged thread with a fine small triangle file, work it slowly
Likes For JoeTBM:
Quoted: 980 Post(s)
Liked 580 Times
Likes For sweeks:
SE Wis
Quoted: 2740 Post(s)
Liked 3,385 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Even better: a Metric Thread File !
aged to perfection
Quoted: 829 Post(s)
Liked 1,240 Times
Suggest you just replace that puller tool. It's steel. you'll be re-forming the extractor threads of any crank arm on which it is used.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Quoted: 980 Post(s)
Liked 580 Times
Not if the threads are repaired with the metric thread file referenced above. It's hardened steel and does a nice job on steel threads. I've repaired spark plug threads that would subsequently thread into an aluminum head with fingers only. No damage to the female threads.
Quoted: 212 Post(s)
Liked 111 Times
It was easy enough to send it back and get a good one. But thanks for all the ideas.
