whats your favorite bearing grease?
Old 11-04-07, 10:11 AM
sniks
JuNKie! bike junkie!
sniks's Avatar
astroglide is not a bearing grease an either is K-Y.
so other than those?
www.cranks505.com
sniks is offline
Old 11-04-07, 10:13 AM
vee_dub
McNightrider
Currently using Philwood and i picked up a tub of campagnolo grease the other day. I havent try it yet....
vee_dub is offline
Old 11-04-07, 11:08 AM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
Philwood bearing grease will do you fine. Only thing I hate about it is the nasty green colour that sometimes splooges out of loose ball stuff in a heavy downpour.
operator is offline
Old 11-04-07, 12:25 PM
jerrymcdougal
jerrymcdougal's Avatar
Bikes: 86' Davidson Impulse, 83' Windsor Professional
I like Phil Grease too. It does have a pretty strong smell though.
jerrymcdougal is offline
Old 11-04-07, 01:00 PM
sniks
sniks's Avatar
where did you find it(campy grease) can't seem to find it on the interweb
www.cranks505.com
sniks is offline
Old 11-04-07, 01:08 PM
vee_dub
McNightrider
NOS in my LBS down in sydney. U cant believe how old it is..it call campagnolo super grease.
https://www.bikepro.com/products/lubricants/campy.html
vee_dub is offline
Old 11-04-07, 01:12 PM
Versa2nr
I'm whats for dinner
Versa2nr's Avatar
Bikes: 06 Specialized Rockhopper Comp
Quaker State high speed bearing grease in the tub.
its cheap
doesnt wash out very easily,
and if it will work for bearings on a car it should work like a champ on the bike as well.
Versa2nr is offline
Old 11-04-07, 01:29 PM
vee_dub
McNightrider
its cheap
From what I heard and understand High speed automotive bearing grease is too thick for bikes bearings. Cause we dont spin as fast as cars (may be just me) so we dont need such thick grease. Lighter grease the faster the wheel spins....i went to a velodrome in sydney, an old track racer enlighted me...that use machine oil and one less balls, will give u a fastest track wheels ever. The disadvantage is that u have to repack ur wheels before every race.
vee_dub is offline
Old 11-04-07, 01:31 PM
shapelike
Don't smoke, Mike.
shapelike's Avatar
Bikes: Devinci Tosca, IRO Rob Roy
Bull semen.
shapelike is offline
Old 11-04-07, 01:34 PM
nobrainer440
I play in the street.
nobrainer440's Avatar
Bikes: 2005 Allez Triple, 1971 Schwinn Varsity Fixed Gear Conversion
I love the smell of that grease. No joke.
nobrainer440 is offline
Old 11-04-07, 01:41 PM
vasracer
vasracer
Bikes: Leader LD-735TR, Mercier Kilo tt, 3Rensho pursuit(not complete)
It depends, if it's a high end part I'll use Phil wood. If it's a lower end part i'll either use finish line or parks, All 3 are good but Phil wood is more resistant to the elements and has a high heat point.
vasracer is offline
Old 11-04-07, 02:23 PM
acoldspoon
fixed or bent
acoldspoon's Avatar
Bikes: 1989 Panasonic Track 4000, 2000 Burley Django (bike show prototype), 1980's Serotta Custom Criterium
I've always been a big Phil Wood fan. I use the oil and the grease. I trust the stuff and it has never let me down.
I also ordered some of this for sh*ts and giggles. It seems like it will compare nicely, but we'll have to see.
https://cgi.ebay.com/Waterproof-Bicyc...QQcmdZViewItem
acoldspoon is offline
Old 11-04-07, 02:35 PM
fix:
vernal stylostixis
fix:'s Avatar
i use pedro's. that ebay listing above is pretty interesting.
fix: is offline
Old 11-04-07, 02:36 PM
roadgator
raodmaster shaman
i like phill wood, but will use lithium grease or car bearing grease if it's all i have on hand.
roadgator is offline
Old 11-04-07, 02:38 PM
fix:
vernal stylostixis
fix:'s Avatar
jobst brandt:
"Automotive wheel bearing grease is an excellent lubricant for all the bearings in a bicycle."
fix: is offline
Old 11-04-07, 02:45 PM
roadgator
raodmaster shaman
i read that post.
They are right. There is nothing particularly special or demanding about bike bearings in terms of bearing design, and therefore they don't require exotic lubrication. Commodity level bearing grease works just fine, but over kill wont hurt, so maybe ill give that EP stuff a try sometime.
Old 11-04-07, 05:04 PM
BrooklynMachine
Works
BrooklynMachine's Avatar
Bikes: You won't believe what's in our stable.
It's not very popular, but Rock n roll super web grease is the modern day equivalent to the old campy stuff.
It's not so much a "paste" like Phil/Park/Pedro (all of which we use regularly and are fine products), but is really like a super stringy cheese that webs off over ball bearing surfaces instead of getting pushed out of the way as they roll. It's what comes stock on high end 90%fill industrial bearing and the Enduro brand bearings we use on all of our mountainbikes main suspension pivots (and those red hubs we got a while back). Our needle bearings get our own formulations.
Just our 2cents, as we have a lot of different lube options here at the shop:
(and these are just the ones we use on our personal bikes!)
BrooklynMachine is offline
Old 11-04-07, 05:09 PM
anomaly
Bikes: 1972 Paramount Track, 1972 Paramount P13 Road, 1972 Paramount Tandem, 1986 Paramount Road, Merckx MXL, Gunnar Cross Hairs, Samson Illusion NJS, KHS Aero Track, Titus Racer X 29er, Tom Palermo Custom Touring
Liked 4 Times in 2 Posts
As long as it isn't gear oil from a diff that hasn't been changed in 100,000 miles and the vehicle has been offroaded, I love the smell =)
(note when I changed it on my old 4 runner the oil was grey and so thick that when you ran your finger under the stream it pulled it down very noticeably)
On topic:
I use Phils
anomaly is offline
Old 11-04-07, 05:11 PM
anomaly
I also use whatever Teflon lube for my chain
anomaly is offline
Old 11-04-07, 05:24 PM
blickblocks
blickblocks's Avatar
It's not too pricy, might give it a try. My mechanic friend gave me a dallop of Park Tool grease in a brake cable bag, and the stuff seems extremely thick for bearing lubrication. Is the Phil grease any more viscous?
https://blicksbags.com/
blickblocks is offline
Old 11-04-07, 05:30 PM
rodri9o
moar wine!!!
rodri9o's Avatar
Bikes: Brigdestone RB-2 : Gunnar Roadie : Masi Gran Corsa : Gunnar Crosshairs : Specialized Stumpjumper (overseas)
I go and bum stuff like that off the bike shop I worked in.
Whatever they have for use I use...red stuff, green stuff...the honey stuff...whatever.
As long as it is clean and serviced frequently enough, you could probably get away with using olive oil.
rodri9o is offline
Old 11-04-07, 05:38 PM
piwonka
park ranger
Bikes: recumbents
i use some synthetic water proof grease...as in automotive and boat trailer wheel bearing grease. it's green, it's kinda thick, it stinks and if i use it on my seatpost the post will slip...so i use some old park grease on the seatpost.
track racers that take a bearing out and use machine oil don't have to repack before every race i don't think. they take (and leave off) the dust caps off and just squirt some oil in there...not the same as actually packing bearings.
piwonka is offline
Old 11-04-07, 05:57 PM
Landgolier
THIS SPACE FOR RENT
I can't find the thread, but someone figured out a while back that Phil's is actually boat trailer wheel bearing grease. I still buy Phil's, though, because nothing else comes in the convenient toothpaste tubes.
Landgolier is offline
Old 11-04-07, 05:58 PM
colnago57
Lucas red n tacky, works great, even in sh&#ty prairie winters.
colnago57 is offline
Old 11-04-07, 07:15 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times in 13 Posts
I'm using Park Pro Lube and some "White Lightning" lithium grease that comes in a spray can. The spray is easy to use but messy. It's got one of those long red tubes to stick on the cap of the sprayer; I can spray hub bearings easily this way.
My dad gave me some old marine bearing grease he used on his boat trailer but I've not touched it yet.
bbattle is offline
