Sram Red black front derrailleur vs. regular front derrailleur
Does Sram solve the front derrailleur issue with the black edition? the chain rubb issue
Bikes: 2007 Trek Madone 5.9 (Shimano DA), 2008 Kuota Khan (SRAM Red), 2009 Giant OCR2 ( Shimano 105 ), Lynsky R340 ( SRAM Rival )
I have 2 bikes with SRAM Red, first gen, both work flawlessly, not sure what issue there is...
Bikes: 2011 Specialized Tarmac SL3, 2013 Sram Red
The new red has fixed all FD issues I'm told. If your buying previous years Red, just use a Force FD. I have all Red with a Force FD.
Quoted: 14 Post(s)
Liked 13 Times
You can use the new 2012 SRAM Red Yaw FD with the older Red shifter. The older shifter has a trim position which is not needed with the new Yaw FD but it does no harm either.
The 2011 and previous Red FDs with Ti cages do not shift as well as Force and some special Red FDs that came equipped with steel cages. The problem was flex due to the Ti cage. The 2012 Yaw FD fixes this, and shifts even better than the earlier steel caged versions.
Basically: Yaw>Force>TiRed
Yes, I have and use all three.
Bikes: Look 585
Quoted: 25 Post(s)
I'm using a 2012 SRAM Red Yaw FD with the older Red shifters works great.
No chain rub in any gear combo but the best part is it shifts so much better up front!
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
bbqpork
Road Cycling
26
02-25-15 04:05 PM
Dancing Skeleton
Road Cycling
21
11-14-12 09:15 PM
