Waxing Chain Just Trend or usefull?
#76
Hello,
I'm currently thinking to wax my new bike (arroves in one month). Currently I only use Lube on all of my bikes, but I have heard, that waxing is better than lubing, because of the consumption of chains. It waxing really good or is it just a new trend and don't have any advantages? What are your experiences with waxing your chain and would you recommend it? And what chain wax do you use?
#77
Quoted: 7653 Post(s)
Liked 3,482 Times
The whole deal with Flat Earth is that it is a Lie.
I tried being a Flat Earther and the Earth didn't get flat. I still had to ride hills. So screw that.
Likes For Maelochs:
#78
Quoted: 4420 Post(s)
Liked 4,873 Times
Tests have shown that chains do actually last longer with wax, mainly because they stay cleaner as you have observed. At least in dry conditions. Wax tends not to perform so well in the wet.
#80
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Another chain waxing thread. How adorable.
Likes For Lombard:
#81
Sock Puppet
Liked 863 Times
If you don't care about that, why lube your chain at all? Just run it dry!
#82
Liked 3,482 Times
#83
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
In my experience, they actually do last quite a bit longer, under the conditions I ride at least. Anything other than wax under these conditions, the "filth" you mention becomes a grinding paste, and I was constantly replacing chain rings, cassettes and chains until I switched over to wax.
#84
Liked 3,445 Times
#85
Quoted: 4227 Post(s)
Liked 2,488 Times
#86
Time is money (I could be working and making money). Waxing is time consuming. My time is worth much more money than even the most expensive top level groupset. The cost of worn part replacement is simply not a concern compared to wasted time. For a $10k+ bike with a top end drivetrain, I get it. It's psychological, even if it makes no sense from a time/money calculation perspective. Any cheaper bike and it's a hard no.
I suppose I could pay someone else to wax my chain and come out ahead. They'd have to come to my house though because if I had to take my bike to a shop and pick it up later, there's that time wasted again.
In conclusion: no.
In conclusion: no.
Likes For Yan:
#87
Liked 3,482 Times
Likes For Maelochs:
#88
Sock Puppet
Liked 863 Times
I suppose I could pay someone else to wax my chain and come out ahead. They'd have to come to my house though because if I had to take my bike to a shop and pick it up later, there that time wasted again.
In conclusion: no.
In conclusion: no.
#89
Quoted: 3514 Post(s)
Liked 2,927 Times
#90
Liked 3,445 Times
Mine have at least tripled. More importantly, it has reduced wear on my cassettes and chainrings.
I recognize I ride under more extreme conditions than average, but it has made a huge difference. If it made no difference, I wouldn't bother.
Likes For Polaris OBark:
#91
Quoted: 1461 Post(s)
Liked 1,486 Times
In conclusion: no.
In conclusion: no.
The process basically is however long it takes to disconnect and remove a chain, and then put it back on. With quick links, this takes about 30 seconds. The rest of the process involves a chain sitting in a pot while it heats up and/or hanging on a hook drying.
#92
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
The Zero Friction lubricant tests with no contamination still showed wax lubes greatly reduced wear over non-wax lubes.
#93
Liked 4,873 Times
Well I did say "mainly", maybe I should have said "partly". One thing that is clear from those tests is that a dirty drivetrain greatly accelerates wear.
#94
Liked 3,482 Times
Actual scientific testing---serious testing, not the anecdotal BS most internet users seem to think is "science"---indicates clearly that waxed chains last longer than unwaxed chains--and save a tiny bit of power as well.
The question is whether the trade-off for the very slightly more involved process is justified by the better performance and extend drive train length. That is entirely a personal matter, not subject to science---it is a matter of opinion. It is a matter of personal preference. Even speaking as a chain-waxer, I would say the benefits are so minimal that wet-lube, drip-wax, and cooked wax are all valid choices.
However, the facts have been amply demonstrated---the cleanest way to lubricate one's bike chain is wax and the longest-lasting chain 9and thus also drive train parts, by some not-yet-determined degree) and also the least power-robbing chain is one which has been properly waxed.
#95
Liked 4,873 Times
I really don't understand this take. I spend about the same amount of time with hot wax as I did with wiping/re-applying wet-lube.
I also know a shop who offers a chain waxing service on rotation. They sell you 3 new, freshly waxed chains and you post them back after each use.
#96
Sock Puppet
Liked 863 Times
I did. "Tests show blah, blah, blah". No, I have yet to hear from anybody here that they can get north of 10K miles using hot wax. I get anywhere between 8-10K miles out of my chains using oil based lubes. Furthermore, can you go 500 miles between hot waxings and get that kind of mileage?
#97
Sock Puppet
Liked 863 Times
i have to dispute this as well. Back when I used wax lubes, I was lucky to get 2-3K miles out of my chains. Now thst I use oil based lubes, I get 8-10K miles.
#98
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
My observations of my own own bikes using wax-based drip lube, compared with my previous use of oil-based lubes, support this conclusion. I'm not a scientist, and I do not have a laboratory.
Likes For Eric F:
#99
Liked 3,445 Times
With completely pristine, on-road conditions, the difference is probably negligible.
Under the conditions I ride (dry moon-dust, sand, grit), a non-wax lubricant quickly becomes a highly destructive grinding paste. There may be some formulations that minimize this, such as the ones that are designed to leave a dried teflon coating, but for those that I have tried, they still get dirty, and are much more of a PITA to work with (not to mention more toxic).
#100
Liked 3,445 Times
