How high can I safely go on tire pressure? 26x1.5 tires
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
I replaced my old 26x2.1 knobbies with 26x1.5 smooth-tread tires for better road riding. The tires say max 65 PSI. Is it okay to go a little higher than that for a little less rolling resistance? Or should I just stick to the 60-65 PSI range?
I run Tioga City Slickers in that size on my fenderbeast. They are also rated at 65 PSI but I run them at 75-80 PSI with no problems and they sure do roll a lot faster.
One interesting note is that the single flat I did get with these tires was when I was running them at 65 PSI.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I use Nashbar Streetwise 26x1.25 tires on my MTB commuter. They're rated for 90psi but I always pump them up to 100psi.
read what is on the sidewall of the tire?
well you ask safety .. over 65 psi, you are past the recommended safe
range, you are on your own..
Bikes: 2007 Specialized Rockhopper Disc; Trek 7.5 FX
kenda kwest - 26x1.5 (or 26x1.25) rated to 100psi. $17.
Well worth looking into these. I found them about a year ago, and love 'em. They even handle dirt/gravel just fine too.
Quoted: 3352 Post(s)
Liked 1,056 Times
The people that make the tire, test the tire, and put their recommended max on the side. You cant go too far from wrong is you follow their numbers.
Quoted: 676 Post(s)
Liked 13 Times
incazzare.
Why put more than the max in? I'd go lower, if possible, for a comfier ride.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Quoted: 676 Post(s)
Liked 13 Times
higher for less rolling resistance.
As with most things I'm sure the max PSI probably has some amount of "safety" factor in there. A manufacturer would never put the absolute maximum failing pressure on a tire.
Which is probably somewhere around double the number printed on the side of the tire...for legal reasons.
Quoted: 5224 Post(s)
Liked 3,585 Times
stick to the MAX or get a road bike ...
Quoted: 3376 Post(s)
Liked 5,528 Times
In my experience you are more likely to have the sides of the rims cracking, than have a problem with the tire.
The larger the tire size, the more pressure it puts against the rim bead AT THE SAME PSI.
when its so hot the tar melts and sticks to your tires that effects rolling resistance..
Rolling along
The perssure indicated on the side of the tire is 1/2 the bursting pressure of the tire.
I run my prii(2) at 42, easily another 10% increase in mpg, same-same, side wall indicated pressure is 1/2 the bursting strength.
But car tires and bike tires are completely different animals. Tread depth isn't all that important on a commuter/hybrid/road bike.
My personal experience is that higher pressure doesn't always mean lower rolling resistance because the tire rather than roll over ripples and small cracks it starts to bounce rather than soak them up in a smooth fashion which can actually slow you down, While to soft can make for more resistance I have find that a harder tire isn't always better.
Tests have actually shown that some wider tires roll better that narrow tires.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Quoted: 676 Post(s)
Liked 13 Times
I don't use a manual pump. I set the regulator on my shop air compressor to what I want in the tire, and let the air pressure equalize.
Actually my regulator gauge is a touch off. I set it at 65, and then after filling I have two different tire gauges that both agree at 60 PSI which is what I have been running.
Quoted: 5793 Post(s)
Liked 2,595 Times
There is a safety margin, so another 10psi probably won't be an issue, but safety margins are a tricly thing. For example tire companies have to allow for thermal expansion of tires inflated in air conditioned homes and ridden out doors in 100 degree weather, which raises pressure by about 10%, then there's an allowance for gauge accuracy so figure another 10%, meaning any decent tire maker needs to allow 20% minimum to be sure all will be OK in the real world. Then he has to allow for tire to tire variation in his manufacturing operation, and for tire/rim fit variation, etc. so he adds more, and eventually ends up rating his tires for far less than they actually hold (on average)
But if you use 10% knowing about the margin, and your tire gauge reads low, and you have thermal expansion, and maybe a not perfect fit on the rim, and happen to have one of the weaker tires... you can see that the margin will be gone and the tire could blow out.
As a professor told me in engineering school some 40+ years ago, safety margins only work if nobody knows what they are. Once people know, they factor them into their plans and if everybody assumes the other guy left a safety margin it's easy to run into a safety deficit.
In any case, you're actually asking the wrong question. You should be asking "will there be a benefit in pushing the pressure above 65psi on my 1.5" tires?"
The answer to that is depends on your weight. Here's a link to a chart showing lowest net rolling resistance for tires based on load, width and pressure. This isn't rocket science, so there's a bit of allowance to be factored based on pavement, but it's a good place to start.
FB
Chain-L site
FB
Chain-L site
Quoted: 676 Post(s)
Liked 13 Times
That chart says I should run 40 psi in my front tire and 58 psi in my rear tire based on total weight of me and bike of about 100 KG and 40/60 weight distro. Interesting.
Thanks for the article. I'll probably verify my bike's weight distro with my bathroom scale sometime soon.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
Running higher than recommended pressure is more than a safety issue (you are probably not in immediate danger but you are on your own) it also affect tire performance and longevity. I run my road tires at or just slightly over the max recommended pressure, but that's personal preference.
Liked 2,595 Times
FB
Chain-L site
FB
Chain-L site
https://www.adventurecycling.org/res...SIRX_Heine.pdf
Constant tinkerer
Seriously, how much do you guys weigh? I run my 700x28 tires at about 80psi/F 95psi/R. When figuring out inflation pressure I shoot for the highest possible pressure before comfort starts to suffer. On my mountain bikes, I shoot for the lowest possible pressure before I have to worry about getting pinch flats and damaging my rims. On 26x2.35 tires, that's about 20psi/F 25psi/R.
