Clipless pedals for a skinny 10 year old?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
We're thinking of getting a tandem and would like my son to have clipless pedals for that. I got him some shoes, threw on some cleats, dialed down the spring tension on my SPD-SL pedals, and had him try to step into them. As best as I could see, he had them lined up correctly, but even standing with his entire 58lb on the pedal, they would not engage. Anything else I can do before I go to plan B (which is SPD mountain bike pedals)?
It's like riding a bicycle
Quoted: 668 Post(s)
Liked 529 Times
WD 40 everything, make sure it it clean.
I know worn cleats can engage more easily, not sure I would recommend wire brushing the cleats to round edges.
BTW cool that you are getting your little one into this at such a young age.
Likes For Pop N Wood:
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
Get the SPD pedals
My grandson was about the same weight when we put him in SPD pedals. No problem getting in or out on the tandem. Sounds like you are really set on getting him in the road pedals. I think you would find the SPD pedals easier for him to use and an added plus is that they are easier to walk in.
Likes For Pridedog:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
The pedals are well maintained, just took them off my own bike and put on his to try clipping in and out, and I used an old pair of cleats I keep as a spare set, but didn't use any WD40. I'll try that.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
He is 10 and on a tandem...running shoes would be more than fine. But if you want him to want clipless, then why not SPD? A quality sole and SPD will be more than stiff enough for a 10 year old.
SPD will be easier to walk in, stiffer than needed, and easier to engage.
As for youth triathlons- I've been to a 3 of them now and SPD will not hold a 10yo back in any way compared to SPD-SL. There are a good dozen things that are more important for success at that age. Kids can easily ride and excel in running shoes at that age(and older).
Quoted: 1088 Post(s)
Liked 1,025 Times
Agree with the above, my 8 and 10yo due velodrome racing, a lot of the kids their age that go clipless the coaches recommend road and the parents do it, since it does mean better cleat retention when riding. But most kids in the age range don't have the leg strength to yank their cleat out of the pedal, mtb shoes are safer to walk in and the pedals are harder to get in and out of, especially when crashed. A few of us bought our kids spd instead. When they're more like 15 I'll go road cleats with them but till then I think everything about spd is better for young knees and general safety.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Anyway, thanks for the comments. We went ahead and tried the SPDs and he had a much better time getting in and out. At least as the stoker on a tandem he can take his sweet time clipping in and out, but he does understand he will probably fall over on his own some day.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Don't dismiss Crank Brothers pedals as an option. They can be made really easy to enter and exit.
Likes For downhillmaster:
Quoted: 576 Post(s)
Liked 1,003 Times
Has OP tried the SH56 cleats? They are made for easier entry and exit; for beginners.
Sunshine
Liked 7,491 Times
Well, we haven't put him on a tandem yet. I have experience as a pilot and a stoker myself. His biggest complaint on his own bike right now is that his feet slip off the pedals and they spin around and hit his shin, which I imagine will only happen more often when someone else is in control of when to pedal.
It seems like a cadence above 75 is where many kid's feet start disconnecting a bit on flat pedals. I see it with my youngest(10) and a lot of inexperienced teens I ride with frequently each year when they first start out.
When my youngest jumps on her bike connected to a trainer and gets up to 90rpm with little resistance, its comical. Her feet are coming off at the top of the stroke each time. She only has interest in sitting there for 15min at most and isn't serious about cycling so its not like the form matters much.
Hopefully the clipless system helps keep your son's feet connected better and he can learn to deal with spinning faster than his coordination would otherwise typically handle at this point.
...or just pedal slower.
Likes For mstateglfr:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
If the problem with flats is slipping off the pedals, give him some pedals and shoes that don’t suck..
Likes For Kapusta:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Try theses.
MKS Half Mini Steel Toe Clips Classic Chrome Japan Made Pedal Clip Fixed Gear 4560369003570 | eBay
Fred "The Real Fred"
Likes For 10 Wheels:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Quoted: 1109 Post(s)
Liked 1,200 Times
If you can find them, try Speedplay Frogs (the two bolt/MTB pedal). My small wife was having great difficulty with SPD and the Frogs were much easier for her. This was when we were riding the tandem and really, the stoker does need to be clipped in (IMHO). Now that we're not using the tandem any more and she just rides her own bikes, she just uses grippy flat pedals and is perfectly happy. But she kept getting knocked off the pedals on the tandem.
Likes For Camilo:
