Chain broke on vintage Bianchi Hybrid
Bikes: Suteki Mixte, Bianchi Hybrid Mixte, Liv Alight 2
So I rescued a vintage Bianchi hybrid last year. I had it tuned up and gone over by a bike mechanic... asked for her to check it out and see if there was anything that I should be concerned about. She replaced the brakes and tires, good lube etc. She didn’t mention that there was anything else wrong and commented that it looked like it was in great shape and someone must have just parked it in their garage fir years.
So I took it out for a ride and while I was going up a bit of a hill and was also shifting, the chain broke.
So my question is whether the chain broke because of my weight (over 300 lbs :-O ), or was the chain likely weakened due to age?
im trying to decide if I got the chain replaced, would I have the same issue.
FWIW, I have a newish Giant hybrid that I’ve ridden several times up that same hill with no issues.
Thanks in advance for your input.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Old chains break sometimes. I doubt that it is your weight. I don't know how an inspection would indicate that the chain would break. Chains for the older bikes are cheap, put a new one on and see what happens.
Likes For cyclist2000:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Doesn't matter how work the chain is, at 300lb, forcing your way up a hill while shifting gears under load will f*ck at least something up.
Drip, Drip.
Liked 193 Times
I've seen a friends derailleur hangar snap clean in half shifting down multiple gears while pedalling full force out of the saddle up a relatively steep hill. Don't be that guy.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Just put a new chain on it and forget about it
Likes For Germany_chris:
Thanks for the input. I do need to improve my shifting skills but sometimes it’s hard to plan ahead especially when you’re out of shape.
I’ll put a new chain on it.
I have ridden my newer bike several times since then with no issues... a) because now I expect the hill and b) I just think the newer bike “ works better” (newer chain, shifters etc)
Thanks again!
Thanks again!
