Steel track frame - fork dents/dimpling/crimples?
Hello,
Just found these when I removed the front track (non-drill) brake that was attached to a bike I bought. Presuming these are from the stress of the brake and not something that was done intentionally by frame builders (i.e. crimping to increase spacing? doesn't seem like it with the size of these).
Presuming this fork is not safe to ride after all...
Cheers.
Cheers.
Quoted: 2482 Post(s)
Liked 2,952 Times
The Framebuilders subforum might be a good place to ask.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
They don't look to be symmetrical from the pics. My first thought was a caliper brake getting pushed back hard enough, but without a drilled crown that seems unlikely. Even a "Keirin" brake clamped on should create some symmetry.
I think it's my picture - they are indeed pretty symmetrical (or very, very close to) if I feel the crimps, which is why I felt it was weird. And it was indeed a keirin brake, but it did indeed have rubber padding, so it's still weird as to how it happened...
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
I think they might look asymmetrical because one side might have been clamped down tighter’n the other?
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 134 Times
They make the keirin brake mounts in round and aero depending on the type of fork. My guess is they used an aero clamp on round fork legs...they look round to me.
Yes, this is the conclusion I reached in the end as well. They are standard, round fork blades and the mounts they used were aero... Which is unfortunate.
Quoted: 478 Post(s)
Liked 634 Times
It truly is unfortunate..... but I have a question - why do those dents make that fork unsafe (if indeed they do). That type of dent would make the tube more susceptible to bending in the direction of the crimp, but that is not where most of the force is directed as far as I can imagine..... so is the fork unusable? Or just ugly now?
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Steel frames can break and still be "emergency rideable". Bob Freeman (Bill Davidson's ex-partner) tells the story of seat stays breaking at the seat lug in the middle of a ride, and a toe strap keeping it all together till he got home (riding gingerly). Forks are a different story. If that breaks or collapses, odds are you're going down. Without analyzing the stresses on the fork and perhaps doing tests that may or may not be destructive, anything hinkie on a fork, I'm staying away from it. It might probably be ok to ride, but the risks are magnitudes higher than if a frame joint or tube failed.
Hard no IMO.
Hard no IMO.
Likes For gugie:
Quoted: 68 Post(s)
Liked 134 Times
While we're at it, how about a picture of the frame? Japanese? American? British?
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
isn't the downtube kinked in, at the point of the lug? Lug acting as a "can opener"?
(Who here is old enough to remember can openers?! Gone the way of buggy whips.)
Could be the blades and DT both got munged in the same "event".
Quoted: 1106 Post(s)
Liked 1,326 Times
When I first saw the damage I wondered if the difference in the heights on the two blades was a sign of a collapsing wheel; that possible downtube kink could be from the same event - a collision/crash?
Quoted: 569 Post(s)
Liked 581 Times
Very wise words not universally appreciated. Risk is likelihood times consequence; in this and many other cases while some would view the risk acceptably low, being a fork the consequence of failure is very serious.
Please also note the headtube angle which they were famous for. A very weird frame, all in all.
Hard no IMO.
Hard no IMO.
Having said that, I was interested to try and see where the stresses actually occur, so I took the fork from this cad file and put it in ansys and played around. Please note the disclaimer that I am, and will not, use this to justify riding this and anyone else who finds this thread in the future please note there are a lot of assumptions made in this model. It's purely academic to understand the fork flex/strains/etc.
I tried one big hole in a fork (image 1) which does get strain of up to 1000MPa (and yield point for T6-Al is apparently around 270 [?]). I then tried 2 unform cylinder cut outs which fared much better. Please note, reality is very different especially with dents (+ also I only applied basically simple forced, you cycling and hitting a pot hole at a certain angle is very different, there's also creases/fractures/non-perfect denting as opposed to what I did).
Anyway, I will not be riding this fork - not worth the risk and injury (and especially when it costs £50 to get a new fork).
Likes For jliet:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Gardin may have been known for steep angles, but I don't buy it for a minute that the headtube angle was like that to begin with.
Even in the wide shot, it's clear that the frame has either had a front ender, or it couldn't take the braking forces of the clamp-on brake at one time. Either way, it has kicked the headtube steeper, creating fairly visible points where the bottom of the headlugs have pushed the tubing upwards into the frame - it's a lot more pronounced on the downtube. Also, the top tube is sloping upwards to meet the headlug; another sign of front-end damage.
There's a lot here on this frame and fork that make it more trouble than its worth. Did you buy it recently? Any chance you can get your money back and look for a different frame?
-Kurt
-Kurt
Liked 5,795 Times
Yes, fork failure is definitely not something that will end in a 'safe crash landing' for sure, aha.
-Kurt
-Kurt
Some more lug examples:
The headtube angle is not what worries me the most, and I don't think you're correct on the sloping head tube, though I agree on the bend where the top tube meets the head tube is suspicious. Though, looking at these other examples of ovalised Columbus tubing, the bottom part also seems to have a sort of bend (which does look similar to on my frame when taken from that angle).
Either way, I will not be returning it! Go it for $100 for the whole build, since I wanted the Sugino Super Mighty track crankset 165mm - that alone is worth double what I paid (not even looking at the wheelset). I will take it to a local framebuilder when I can and get an opinion though.
Liked 4,390 Times
Still, agree 100% - that price is definitely is worth it just for the crank; even better with the wheelset. Good score!
Best of luck with it - if that's not heat treated tubing, it may be possible for the framebuilder to cold-set it with very little evidence of the front-ender.
-Kurt
