Front derailleur adjustment screws not working
Quoted: 5 Post(s)
I have followed parktool and other guides regarding front derailleur adjustment, however even when cable tension is slack and cage is on lowest chain ring, the chain still rubs against the inner cage, I have fully tuned out the L limit screw which would otherwise bring the cage away from the chain towards the frame. Seems like my cage is just shifted away from the frame.
Really Old Senior Member
What's the rest of the story?
Which inner side?
What did you change?
Which inner side?
Likes For Bill Kapaun:
Blamester
Just the derailleur?
The cranks?
You sure you are turning the right screw.
Likes For blamester:
Quoted: 5 Post(s)
Sorry about the lack of detail but to reiterate, I tried to adjust the limit screws on the front derailleur first adjusting the lower limit screw. I had back out the L screw all the way so that the inner cage would stop rubbing against the chain side closest to the frame. But even after adjusting screw the chain still rubs with no further screw thread to play with. How could I get space between chain and cage for lower limit?
Hope this makes more sense. Additional info: inner cable was slack.
You still don't give any history for this bike.
Did it function properly before or is it a bike you recently acquired with no known history?
IOW- What got you to where you are?
Quoted: 1943 Post(s)
Liked 2,164 Times
If you have removed the cable and it will not move any further, there are a few things you can do. Although it is odd to happen if nothing was changed.
The obvious is loosen the clamp screw and slightly rotate the derailleur. Adjust the H limit screw and make sure that everything shifts fine.
There are a couple of small tweaks, only minor rubbing, I’ve done, if I have changed something and can’t bring the derailleur in enough. I’ve never done these on an already well setup drivetrain.
The easiest is to remove the cage screw at the back of the cage that holds the outer and inner plates together and add a small washer. This is really just a minor tweak and is nice for just a bit of cushion.
I will look and see what the cage is hitting against and have been know to judiciously file that area if it appears that it won’t impact functionality.
If I’m using a FD that needs clamp spacers, I have on one occasion used a thicker than needed on the opposite clamp side and sanded the thickness on the cage side, blending in the middle to move the whole FD closer to the seat tube.
John
John
Likes For 70sSanO:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
If this is an existing derailer, pull the derailer outboard with the cable slack and see if there is debris behind the derailer. Perhaps lubricate the pivot points and work the derailer until it frees up. Worst case, remove the derailer and soak it in mineral spirits.
Stuart Black
Stuart Black
Quoted: 5 Post(s)
Thanks a lot Cyccommute and John will give your solutions ago although I have checked for obstructions and lubed the derailleur. I don’t think I’ve explained properly from the start. I have a Carrara Vengeance 2017 (3 front chainrings) it was rubbing before and shoring wasn’t so smooth. I’ve only adjusted the barrel adjuster, pinch bolt and derailleur height. Without any wire tension and L screw fully out the cage is still too far out when selected to the smallest chainring thus causing chain rub with the inner cage. It seems to me the positioning of the cage is in a better position for the middle chainring rather than the smallest as it’s positioned more away from the frame. What do you guys think could help?
Likes For Crankycrank:
Liked 4,217 Times
Stuart Black
Stuart Black
Liked 4,217 Times
You can see the problem with the bottom swing. It can’t go inboard as far because it is trapped against the clamp.
If you have the top swing, you probably need a narrower bottom bracket.
Stuart Black
Stuart Black
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Did I miss when you stated where the chain is on the rear cogs when you have the rub?
Never try to teach a pig to sing...
Liked 2,164 Times
First step is to put the chain on the middle chainring and a cog in the middle of the cassette and see how close it is to 90 degrees to the axle/hub. It doesn’t have to be a exact but it will give you and idea of the chainline.
Hopefully the chain will look like it is angled out at the cassette and you need to move the chain to a lower cog to square it up.
From the little I could find on your bike I think it has a SRAM square taper crank. Before you remove it try and figure out how much further out it has to sit to not rub on the lowest cassette cog in the small chainring. You are basically getting a bottom bracket with a wider spindle. But too wide and the derailleur may not reach the outer ring.
The one caveat of all this has to do with a bent frame. Now since it is aluminum, you can’t (shouldn’t try to) bend it back. But that could be a reason why you are getting chain run. If it is bent, it is up to you whether you want to pursue a wider bottom bracket spindle.
John
John
