Centurion Serial Number Database
#2351
Hi everyone. This is an incredible resource, thanks to everyone who made it possible.
I've decided as my cold-weather quarantine project to rehab my wife's Centurion Lemans. She purchased it in college (~2009); it's been sitting unused in a shed for the past 3. The extent of my geared bike experience is on a 10-speed townie. The rest of is single speed and fixed. Great time to learn how gears work.
Serial number is N4H7115. Based on the formula here, I think this equates to 1984 production, maybe March?
Based on the 1984 Centurion catalog on Sheldon Brown it looks like most components are original, or at least same brand/style replacements. It does have a Specialized stem, which I believe to be an S-2 Road. The saddle and pedals are clearly replacements from when she bought it.
I cleaned it up today to see what I'm working with. At a minimum it'll probably need new chainrings (worn), freewheel cluster (worn), seatpost (rusted to hell), pedals (prob try to go original), and seat.
Cheers!
Cheers!
#2352
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 235 Post(s)
Liked 178 Times
Thank-you very much for taking the time and effort to obtain the serial number, date codes and extra photos, even though it wasn't an attractive deal and a real Frankenbike.. The S/N is consistent with February 1982 manufacture by Fairly of Taiwan. They were a known contractor for WSI but this may be the earliest case I've seen. I was having trouble deciding if the rear dropouts were stamped or forged but now that we have a better photo, they appear to be 3D stamped dropouts. I wish you better luck with your next potential transaction.
I would suggest that the serial number reads as F2J24735, as opposed to F2024735. The first number 2, after the F, for the year of frame manufacture 1982 and the J meaning some point within that year.
The "J" probably does not mean February.
In 1981 Fairly serial numbers had a letter after the first digit, the number for the year.
In 1983 within the Fairly serial number the letter for the time period was replaced by two digits for the month within the year of frame manufacture.
The length of the 1983 serial number remained at eight characters, so the number of characters for the sequence number was reduced.
#2353
Another Super Le Mans
Got another Super Le Mans, mid 70s a different type of serial number IE02063, not sure of date codes on components. Also not familiar with the crankset, appears to be "RE Sprint" dont know if that's an SR model or what, any information would be appreciated, thanks
#2354
Searching for answers...
Bikes: 1985 Univega Competizione-Pro White; 1981 Schwinn Super Le Tour - Black Sable; 1987 Bianchi Limited-Metallic Celeste; 1972 Nishiki Professional - Green; 2015 Giant Defy Advanced 1
Quoted: 5 Post(s)
75-76 Centurion Super Le Mans
Hey gashepherd, I just picked up a very, very similar super le mans but slightly larger 23" frame. I dated my components as ranging from 1972-75. Front Cyclone derailleur date code of OF, rear Cyclone GT derailleur date code PF, Diacompe center pull brakes dated 0375, fork stamped Tange 5E and seat post marked 75.9 (took me 3 days to free it) Frame SN is TE29459. If the E represents a '5', we'd have 1975 frames. I'm guessing (pending T-Mar confirmation) I've got a late 1975-early 76 Super Le Mans. And yours will probably be very close in age based on similar SN. Main difference I see is that mine has downtube shifters vs your bar-ends. I hope this helps and adds to the T-Mar's database.
SR seat post date code?
Frame SN
Frame SN
#2355
Bikes: Wilier Cento10Ndr, Giant Anthem 2, 1985 Gefsco, 1979 Gios Torino Super Record, 1983 Peugeot PFN10, Terry Dolan built Reynolds 753 Cougar for Malcolm Elliott
Quoted: 22 Post(s)
Liked 33 Times
Thanks T-Mar. Had no idea European models would be different from US. Too bad European centurion catalogues seem nowhere to be find online.
How did you know there are no water bottle bosses, are you able to see the pictures I tried to post? Anyways, will try to share once I’ve reached 10 posts.
I’ve suspected that the lack of bottle bosses and the fact that the shifters are located on the steering wheel rather than the down tube would indicate a lower level model, at least seeing the specs in the US catalogues.
I don’t understand why it would be more premium to have the shifters on the down tube though, much more hassle to change gears IMO.
#2356
WGB
Bikes: Panasonic PT-4500
Quoted: 1783 Post(s)
Liked 2,305 Times
Will add photos tomorrow.
Got a Centurion Omega at a local auction for $50 Cdn. Very poor photos in low light. Arguably the worst paint job I've ever seen. By that I mean the actual paint is not bonded to the metal and just flakes off with a thumbnail. Bizarrely, the name "Centurion" (or what remains of the name) was put on with stick-on letters (was paint that expensive??). Adding entry a) for T-Mar who needs serial numbers for his investigations b) to record the hideous paint job for posterity.
Group set is almost immaculate as I was told owner couldn't get it to shift and didn't know anyone who could "fix it" so it would shift. Steel wheels with zero rust which shocked me as the frame has rust, mostly on the chains stays. Suntour 7 derailleurs with a long cage GT rear and Suntour 7 stem shifters. Brakes are Dia Compe. I pulled the chain guard off the crank set as it just looked too dorky.
Serial is A7105289. I'd rate quality of the frame set as better than a Raleigh Record, a well made bike betrayed by it's paint. Where it not for the cotterless crank set I'd have guessed early '70s but was told it was bought "after 1977". Velobase wasn't working for me but I think repeat think that Suntour made the GT in the late '70s so this might be right for when it was made.
Photos to show general view of bike, then it's components.
Now, sadly photos to show paint and the weird stick on letters which are peeling off.
#2357
Quoted: 22 Post(s)
Liked 33 Times
Centurion Equalizer Frame
Picked up this Equalizer frame, Kusuki Winpista bars and stem, Tange Levin CD headset and a Shimano 105sc BB for $60aud. Once I’ve worked on the frame a little I intend to bring it back to spec. I love the monochrome colouring with the splashes of colour....very late 80s early 90s. The serial number reads M0L01530.
Can any one point me towards the catalogue for this 90’s Equalizer as I can’t find the American version, only the European. Many Thanks.
#2358
Quoted: 4719 Post(s)
Liked 3,034 Times
The Centurion brand was owned by different companies, depending on the country. This why Centurion survived in Europe after it disappeared in the USA. The brand owners in each country were responsible for naming and specifying the models. Consequently, models often varied, sometimes significantly, between markets. Basically, you'd have to find an Australian market catalogue to ensure the right specs. Having said, we've seen two 1990, Australian market Equalizers. Both used a Shimano 600 Ultegra group. Refer to posts #668 and 2010 of this thread.
Likes For T-Mar:
#2359
Quoted: 22 Post(s)
Liked 33 Times
An American catalog isn't going to help. The S/N indicates a 1990 or 1991 model manufactured in 1990. In the USA, Western States Imports discontinued the Centurion brand in late 1989, marketing the 1990 road bicycles under the Diamond Back brand, which had previously been limited to ATB and BMX.
#2360
6h4006
Hi there,
Hoping someone might know what model my bike might be based on these specs (unfortunately I can't upload photos or post a URL as I just made an account.) A seller on Ebay is selling my exact model, if you're willing to type "Centurion Vintage Road Touring Bike From The 70s In Nice Condition" into google. It should pop right up, it's a brownish gold bike.
My serial number is on the lower end of the seat tube — 6H4006 (only six digits).
This database/resource is incredible, thank you T-Mar!
- All alloy
- Apex on crank arm
- Sakae chainwheel
- Suntour components
- Handlebars/stem reads “Sakae - Randnner Japan” in a laurel on the rider’s right and “Road Champion” in a laurel on the left.
- “Guaranteed Built with double butted…” - black square/rectangle label with yellow outline - can’t see the rest of sticker (mine was worn)
- Wheels: Araya 27x1 + 1/4 w/o HP
- Made in Japan engraving
- SR forged engraving
#2361
Quoted: 1590 Post(s)
Liked 2,492 Times
Hi there,
- All alloy
- Apex on crank arm
- Sakae chainwheel
#2362
Liked 3,034 Times
Hi there,
- All alloy
- Apex on crank arm
- Sakae chainwheel
#2363
Quoted: 822 Post(s)
Liked 1,387 Times
This is my recently acquired ($35 on FB Marketplace!) 1988 Centurion LeMans -
(Photo AS FOUND)
SN N7L6304
Tange No. 2 tubing with Tange Mangaloy forks and stays
Shimano Exage Sport cranks w/ 42/52T Biopace rings
Shimano Exage Sport derailleurs w/ downtime shifters
Shimano Exage Sport brakes w/ white hooded aero levers
Shimano hub, 36 spokes, Araya 700C rim (front - the rear is a replacement wheel)
Centurion branded Vetta saddle
Sugino seatpost
(Photo AS FOUND)
SN N7L6304
Sugino seatpost
#2364
Quoted: 157 Post(s)
Liked 17 Times
89 Prestige and R/W Ironman Expert, M Vice expert, Cinelli Equipe
'89 Prestige - Ser # N8S003 - Tange Prestige tubing. Never had as complete bike, built up from frame, nothing stock except Tange bottom bracket (steel).
Red and White Ironman Expert - think it's an' 86 - Ser # N6L639
Bought as complete bike with stock 105 setup, Nitto stem and bars, alloy (SR or Sugino?) seatpost with cast in height scale and steel clamp. Vetta Turbo style nubuck saddle, Wolber rims. Tange 1 tubing. I changed out all components except the headset, as you can probably see.
Will edit with pics and serial for my Miami Vice Expert and Cinelli Equipe
#2365
Liked 3,034 Times
Will edit with pics and serial for my Miami Vice Expert and Cinelli Equipe.
#2366
Quoted: 81 Post(s)
Liked 221 Times
A gorgeous yellow Centurion Semi Pro recently followed me home. The seller didn't know much about it; it belonged to her recently deceased wife, and the seller thought her wife was the original owner. Here it is in as found condition.
Sorry about the picture quality. I was too eager to start dismantling and cleaning to wait for daylight.
The serial number is "M7L44193" which as I understand suggests that the frame was made by Miki in the summer of 1977.
Everything else about the bike (paint color, graphics, components) suggests it was sold in 1979. Other than the tires and saddle which appear to have been replaced at some point, the only other component that doesn't match the 1979 catalog is the crankset. Catalog says Sugino Super Mighty Victory 42/52 with drilled chainrings, but mine has a SR Royal 42/52 with undrilled chainrings. Based on how original everything else is, I'm betting the SR crankset is original.
The top tube measures 57cm CTC and the seat tube is 58cm CTC.
I can't tell you what a joy it has been to take this bike apart. I felt like I was working on an archeological excavation, unearthing a priceless artifact that's been buried in a pile of grease, dust, and cat hair in a basement for the past 40+ years. Everything is in perfect condition, unmolested by ham-fisted amateur mechanics like myself. It needs new consumables, a proper saddle and lots of cleaning and repacking of bearings, but otherwise it's all there.
I'll share more and better pictures in a more appropriate thread once I finish cleaning and re-assembling everything.
Likes For lonesomesteve:
#2367
Quoted: 157 Post(s)
Liked 17 Times
Good eye! Indeed it is a new 105 headset and I'm sure it's original. Could the group possibly have been available to Centurion in '86? Guess what's more likely is the frame was produced late in the year and wasn' t built up till the next. (?)
#2368
Quoted: 157 Post(s)
Liked 17 Times
#2369
Liked 3,034 Times
In order for the bicycle companies to start building the new models during the last 1/3 of the year, component manufacturers have to produce their new models even before that. It's not unusal to find mid-year component date codes that actually represent the upcoming model year.
Consequently, while New 105 had a 1987 model year debut, it's quite common to find them with mid 1986 date codes on frames that were built in late 1986. It's not unlike the automobile industry, which routinely has the new models out by now. In fact, I understand that a number of automobile manufacturers introduced some their 2022 models as early as this past spring!
Likes For T-Mar:
#2370
Liked 3,034 Times
#2371
Biker
I believe I found an "as sold Centurion Lemans RS" in Albuquerque, NM.
\Centurion Lemans LS
Serial number N7E7428 N (1) format?
1987
Tange 2 Double Butted
Quality from Japan /Designed in USA sticker at base of seat tube
Mangaloy 2001 Fork (Tange).
Brakes and Levers Shimano SLX
RD and FD Shimano Light Action
Shifters downtube - Shimano
Shimano Biopace Chain Rings 52 - 42
(2 x 6) speeds
Pedals MKS – AR8
Araya Gold Anodized Rims, 700 c
Suzue Hubs (Sealed Tech) 7 - B
Freewheel 6 spd 13-26
Seatpost Sugino SP-KC
Vetta Anatomic Seat – Branded Centurion
Bars engraved - Kusuki – Winpista
Black frame with yellow seat and head tubes.
Paint in good condition except for chain stays and some seat tube damage where yellow shows below scratches of black paint.
No rust (its a New Mexican bike)
1987
(2 x 6) speeds
Pedals MKS – AR8
Likes For Peruano:
#2372
Just finished refurbishing this Centurion Ironman. It's got a complete original Shimano 600 groupset on it. A very small 52cm frame. I don't know what year it is. But, I'm guessing 1985. What do you think? (As soon as the sun comes out more pictures to follow).
#2373
Klaatu..Verata..Necktie?
Quoted: 10247 Post(s)
Liked 11,601 Times
Serial Number N5E5264.
1985 Centurion Ironman. Metallic red with metallic titanium head tube. 58cm. Largely original, except for pedals (MKS); brake levers (Shimano BL-R600 aero vs BL-6207 non-aero), and probably shift levers (SL-6208 SIS shifters, vs SL-6207 friction shifters). Original Selle Italia Turbo 'Bernard Hinault' model saddle and Sugino SP-KC seatpost, 6207 hubs laced to Araya gold rims; Nitto bars and stem.
Seller replaced the 6207 single pivot brakes with 7403 Dura Ace dual pivots, but gave me the originals as well.
Here's one of the seller's pictures. I'll post pictures of the final after I'm done with the restoration.
#2374
Twin
Bikes: Centurion Super Lemans
Liked 20 Times
Front derailleur TE, rear derailleur TJ, SN n8d7388
Centurion Super LeMans I picked up at a yard sale today. I guess it's from early 1978?
Sorry no pics because I'm new here.
#2375
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,379 Times
