Fuji SST seatpost options?
Quoted: 15 Post(s)
Hi, does anybody other than Fuji makes the aero seatposts that fit the 2014 SST bikes or does one have to order this part directly from Fuji only?
Thanks!
Thanks!
Bonafide N00bs
Bikes: 2015 Cannondale Quick CX 4, 2014 Fuji Sportif 1.3C Disc, 2012 Fuji SST 2.0 Ultegra Di2
Quoted: 43 Post(s)
Is it Fuji or Oval you'd have to order from? I know Fuji, Oval, Kestrel, etc are all under ASI, but if you were looking for the exact seatpost, that would be under the specs. Not sure how easy/difficult it would be to order one.
What's wrong with your seatpost if I may ask? I have an SST too with the same. post.
Quoted: 15 Post(s)
OnyxTiger - I am not sure what my options are really, I'll check with LBS and see if they can make any recommendations. Nothing wrong with the seatpost on the bike, I just want to experiment with lowering it another 1/4" (by getting a spare seatpost I could cut the a small 1/4-1/2" section off) to fit me better as it's currently in the lowest setting and my legs are fully extended when the pedal is in the 6:00 position.
If you measured the size and shape of the Oval that would be a good start. work from dimensions
That is how things get Made.. Dimensioned CAD these days ..
