Front tire rubbing.
Front tire rubbing.
I’m a little confused on this one. Original 27” wheels with new 1 1/4” Paselas and the tire rubs the fork. I never would’ve imagined this would be a problem.
Semper fi
Semper fi
Quoted: 3464 Post(s)
Liked 2,831 Times
earlier road racing spec bikes btw came with eyelets and later by request.
I would spend the $ at Waterford and get a report.
even if it was sold originally with 27" does not mean the factory shipped it that way.
the lug lining and brake gives away much that was not mentioned.
Likes For repechage:
Quoted: 4806 Post(s)
Liked 3,932 Times
Paselas (at least the 700cs I've used) tend to run the actual labeled size so a 1 1/4" 27" tire is gong to be pretty big at the top. If repechage is right 1) good eye! and 2) yeah, the higher end and more "performance" bikes got, the less fork crown clearance. (I'm assuming this bike precedes the now big tire trend.) My Peter Mooney could handle those tires with fenders but only because I requested exactly that.
Looks to me like you have plenty of brake slot to use 700c wheels with what you've got. (Can't see the rear.)
Continental 1 1/8” tire fits fine, must be the bigger Paselas.
Semper fi
Semper fi
Liked 2,831 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Without any doubt, inch-sized Paselas are among the truest to size and thus the widest/tallest 27" tires available.
They are millimeters wider than even some tires labeled as 1-3/8" wide!
1-1/4" is about 32mm.
Michelin World Tour is another huge 27x1-1/4" tire, measured 33mm wide on my touring rims.
My 27x1" Paselas measure a full 26mm wide on touring rims, which is close to what the narrowest 27x1-1/4" tires measure.
Specialized 1-1/4" tires from some years back (oughts) had sizing numbers molded into the sidewall that read "26-630", which was their true size.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If it weren't a special/valuable bike, a big half-round file would probably help.
RUSA #7498
Originally Posted by noglider
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Likes For cb400bill:
Quoted: 3514 Post(s)
Liked 2,927 Times
Very nice!
Liked 3,932 Times
Paselas run considerably larger than Continentals for the most part. The 38c Paselas I ride are radically bigger than my 37c Continental ice tires. (I run both on my fendered bike. Fenders really emphasis differences, especially as things get close.) The Paselas I've measured run pretty close to true.
Most of my tire purchases were a few years ago before manufacturers were sizing tires after mounting them on the new wide rims. That has introduced an additional flavor of variability.
Liked 4,396 Times
Likes For cudak888:
Likes For sloar:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Do the right thing and rebuild the wheels to 700c as a P13 was intended to run with. Those brake pads can move down at least 4mm, which is the difference in radius between 700c and 27" rims as I recall.
Likes For gugie:
Quoted: 604 Post(s)
Liked 1,064 Times
I’d just keep the original wheels, and run the Continentals. Also Continental 1 1/4 tires may clear, I’ve had luck just switching brands, when having clearance issues. Beautiful Bike by the way!
Tim
Tim
Quoted: 189 Post(s)
Liked 473 Times
This is interesting, as it appears that the front would work just fine with a 700c wheel, I’m not sure about the rear. It certainly looks like it was made for a 27” back there.
Liked 1,296 Times
Liked 4,396 Times
Your frame should be same as the one in the foreground. If you have a spare Nuovo Record standard-reach rear caliper, install it in place of the Weinmann, set the pads for a 700C rim, and check it against this.
-Kurt
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
oof, that's a pretty bike.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Awesome bike and I'd just go 700c. My son's paramount from 71 think, has no eyelets and closer clearances. He runs gravel king 35s. It's fairly close but no rub.
I like the idea that the bike left the bike shop with the 27” wheels. Maybe one day I’ll build a set of 700’s with the original hubs, but I’m fine for now.
Semper fi
Semper fi
Likes For sloar:
ambulatory senior
Liked 3,661 Times
Likes For 52telecaster:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I would get out my Dremel and grind off a bit of that crown and run those Paselas.
I have done that with a couple of bikes to run fatter/taller tires.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
