Are Presta valve caps uncool or what?
Looking at a lot of bike photos recently and I noticed that a lot of them don't have valve caps on. Is it because they fell off or got lost or purposely being left off? I leave mine on thinking that they would help keep the air in my tires in case the needle is loose or something.
Just wondering if its cool factor to leave it off???
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
The caps are a shield against dirt getting into the internals, they won't keep the air from leaking out if the valve isn't tight, hence the name "dust caps".
Jon
Jon
Quoted: 4559 Post(s)
Liked 2,802 Times
Yup, valve caps are uncool.
Which is why I use them.
And to keep my valve stem nut company, so it's not uncool alone.
Besides, they look better with my argyle socks, black knee warmers and navy blue shorts.
Likes For canklecat:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
I too like them, and never go without. Some of mine are anodized aluminum, in colors that match the bike... Very Cool!
Sure, but what about the weight? Not to mention the wind resistance.
Knurled Knut is great, though. Keeps short valve stems from sinking inside the wheel when connecting the pump to a flat tire.
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
Likes For MarcusT:
Quoted: 1068 Post(s)
Liked 785 Times
Knurled-knuts on every stem tightened up to black piece of Gorilla Tape on rim
Green valve cap front, orange valve cap rear, Propel is White/Black and Roubaix Expert is Red
Looks fine to me.
Looks fine to me.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Ì've never used them simply because they don't do anything. Never had a dirt problem in my tubes' internals either.
minimalist cyclist
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,641 Times
To me the presta valve caps just don't look aerodynamic and are unnecessary since there is already a screw to tighten the valve. I also like the lock ring holding the valve firm against the rim.
I have some bikes with schrader valves, and on those I do prefer some type of cap. For some reason, a bare schrader valve doesn't look right. I use these truck type caps that gives somewhat of a presta look.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
More aero and less weight without them, no benefit with them, so what's the question?
I'll put them on unless I dropped one in the grass or forgot, and then I don't sweat it. It's probably not cool looking to have one valve cap and one bare ... but I'd have a lot of not-cool to address long before getting to that point.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Only uncool for poseurs.
Likes For JohnDThompson:
Quoted: 601 Post(s)
Liked 779 Times
Quoted: 601 Post(s)
Liked 779 Times
Quoted: 1364 Post(s)
Liked 1,677 Times
I keep presta to schrader adapters on mine, even though I have no need to do so. All my pumps handle schrader valves directly. But even so when I go to top off my tires I unscrew the adapter, unscrew the presta valve nut, re-screw the adapter, pump, unscrew the adapter, screw down the presta nut, an finally re-screw the adapter back on.
I find this unnecessarily complicated process provides me with the perfect balance of convenience and obsessive/compulsive disorder satiation. Additional valve caps for the schrader adapters seem excessive to me; and keeping the presta valves open under the schrader adapters so that they can be used like regular schrader valves seems unsecure to me, even though many people do just that with no adverse consequences.
It is one of the very few OCD things I do.
Likes For BobbyG:
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
But really, who cares about a valve cap? They seem to be very prone to falling off, which I would wager counts for the majority of capless valves. I always put the cap on if I have it, but have broke a couple too tight, and others have fell off...
well hello there
Quoted: 503 Post(s)
Liked 336 Times
It's unnecessary.
And for me just boils down to another thing to deal with when I'm trying to very quickly fix a flat and get back on the road.
Quoted: 2323 Post(s)
Liked 4,988 Times
I never use them. I see no benefit. I mainly use latex tubes but no matter what air up daily before my ride. They just get in the way. Even on my winter bikes that see weeks and weeks of riding in gunk I've never had a problem.
And just to illustrate the point!
Steel is real...and comfy.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Valve caps and jam nuts are simply not needed. It isn't about cool or uncool. There just isn't any benefit.
Not only is there no benefit but using either or both increases time required to fix a flat.
Some people chronically overtighten jam nuts, pulling the tube up through the hole in the rim causing a flat.
Presta valves which push all the way down into the rim are too short. Tubes with longer valves is the answer.
Fumbling with jam nuts and valve caps on the road is just a waste of time.
-Tim-
-Tim-
Liked 4,988 Times
Farmer tan
They're absolutely necessary on the rolled up spare tube to keep it from puncturing the tube in storage.
Toss it after installing the tube. Unless you keep the box too...
Likes For f4rrest:
I use them only on my brand new spares in my saddle bags.
