52T vs 70T (pic)
#76
Quoted: 20810 Post(s)
Liked 9,456 Times
Exactly. He keeps talking about how little the "randos" know, but he's approaching this as if spinning out is the one thing holding him back as opposed to, you know, the exponential power requirements to force your way through the air at increasing speeds.
#77
Liked 9,456 Times
A fun app is "Bike Calculator". There are a few different ones, but they are all similar.
Bike Calculator
Ok, so for some sample data:
220 lb rider (100 kilos)
20 lb bicycle
tubular wheels
Aerobars
70 degrees F
500 ft
0 grade
0 headwind
20 MPH --> 143 Watts (1.43 watts / kilo)
25 MPH --> 252 Watts (2.52 watts / kilo)
30 MPH --> 408 Watts (4.08 watts / kilo)
35 MPH --> 623 Watts (6.23 watts / kilo)
40 MPH --> 905 Watts (9.05 watts / kilo)
45 MPH --> 1265 Watts (12.65 watts / kilo)
50 MPH --> 1711 Watts (17.11 watts / kilo)
Now, let's try the same with the same parameters, Clinchers/Drops.
20 MPH --> 183 Watts (1.83 watts / kilo)
25 MPH --> 322 Watts (3.22 watts / kilo)
30 MPH --> 523 Watts (5.23 watts / kilo)
35 MPH --> 799 Watts (7.99 watts / kilo)
40 MPH --> 1162 Watts (11.62 watts / kilo)
45 MPH --> 1625 Watts (16.25 watts / kilo)
50 MPH --> 2200 Watts (22.00 watts / kilo)
WHEW!!!
Note the huge power differences when comparing speed with aerobars/tubulars vs drops/clinchers.
Bike Calculator
20 lb bicycle
tubular wheels
Aerobars
70 degrees F
500 ft
0 grade
0 headwind
WHEW!!!
#78
Quoted: 169 Post(s)
Liked 84 Times
I see a lot of the same people make snarky comments here quite often. I've seen their type on group rides, picking apart every thing wrong a first time riders bike or equipment. The sad part was that many of the first timers would not return.
#80
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Hey, I'm interested to see the final build and result.<br /><br />I see a lot of the same people make snarky comments here quite often. I've seen their type on group rides, picking apart every thing wrong a first time riders bike or equipment. The sad part was that many of the first timers would not return.
If the boasting didnt exist, the pushback also wouldnt exist.
2 way street and whatnot.
Totally different scenario from your comment about 1st time riders on a group ride.
#81
Sunshine
Liked 7,491 Times
I also respect people who understand what they are trying to do more than people who ignorantly go into something without a full understanding. Oh, and I respect people who dont mock others while living within their delusion.
#82
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I'm actually psyched to see what he can do with this. I just think he unnecessarily set himself up for "failure" by ridiculously asserting that 50 mph is a no-brainer (unless he's on a recumbent). He'd be setting a world record if it's not faired, and he'd be very close to a 33 year old world record if it's faired.
I have doubts he'll get it rolling starting in 70x11, but it's an interesting experiment, and if it doesn't work, he'll just have to add a lower "starting" gear. That should be a relatively easy mechanical fix.
Just to be clear--I wouldn't consider it a "failure" if he doesn't hit 50 mph. Saying he is going to do that for sure is the only truly silly thing he has done.
#84
Quoted: 3376 Post(s)
Liked 5,518 Times
Well, he is obviously in the mountains, and we know he damned well didn't climb there, so I figured he just wanted to get the most out of his descent.
#85
Quoted: 7652 Post(s)
Liked 3,478 Times
Most of us are. The rest, aren't in this thread.
With that sort of leaping ability you ought to consider a career in track and field.
After I read your comment, I went back to the start of the thread. Nobody said anything snarky until @DrIsotope noticed the guy was planning a 70x11 singlespeed---and that struck Dr. Isotope as ridiculous (considering that the gearing goes way beyond human capacity, some might suggest a smaller chain ring for greater utility.) Then the OP tried to explain that he was stronger than Superman, while insinuating that the rest of us were underweight wimps. All good fun so far.
As for how any of us treat new riders at a group ride ... sorry about your problems. Next time you go to a group ride, bring some thick skin and some confidence.
Or maybe ... you feel guilty because the guys you ride with picked on some new rider and you didn't stand up for him or her?
In any case .... you might not have noticed, but this is a website, not a group ride. And the OP has plenty of posts and plenty of experience. Also, the OP seems well able to defend himself.
Dr. Isotope called the idea of a 70x11 singlespeed "nonsense" because he did the math and figured out that to ride to 50 mph on a conventional bike would take more power that Sir Chris Hoy could put out, and would break all existing speed records by a considerable margin--sort of if I came here looking for good running shoes, claiming i was going to run a one-minute mile.
OP responded, "Hey it's the guy who can't climb mild gradients with a 38t-11t. Even 48t-11t must be nonsense for you." So basically, Dr,. Isotope said, "Physics and human physiology," and the OP responded, "You're a weak wuss."
Kind of hard to see who is actually being mean to whom, there.
Whatever. It is assumed that we are all adults here, or experienced internet users, who don't melt when someone says something other-than-laudatory.
This thread seems to offer excellent entertainment prospects for several weeks to come. Let the posters have their fun. Sooner or later this thread will have to deliver cell phone video of a rider trying to turn that gargantuan chain ring which started the thread, and we shall all be entertained, however fast he goes.
#86
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,040 Times
After following this thread with much interest and with the consumption of no small amount of popcorn I believe I've figured it out. The OP is almost certainly the guy from the Liberty Mutual commercial who likes to customize his bicycle. With all due respect. I should have said with all due respect.
-Matt
-Matt
#87
Quoted: 1814 Post(s)
Liked 923 Times
https://www.youtube.com/watch?v=jpWXpRy_6oI
-Matt
-Matt
With the OP's proposed gearing, the rider would go almost 45' with one rpm,
so you would see his leg go one third of a revolution across the frame.
#88
Tragically Ignorant
Liked 9,098 Times
-Matt
-Matt
I might have paid you money not to post that commercial. Man, I hate Liberty Mutual's "funny" ads.
#89
Quoted: 762 Post(s)
Liked 4,040 Times
#90
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
@tellmethetruth What are your accomplishments (speed wise) so far? Have you pushed 45, or 40 mph on the level? You know, standard bike, no fairings, motors or any other "cheats"? Surely you've not only thought this out throughly, but have attempted similar feats many times previously. Maybe you spun out at 45 and went back to the drawing board.
#91
Tragically Ignorant
Liked 9,098 Times
#92
Quoted: 1002 Post(s)
Liked 237 Times
70T?
Did that come in a box marked 'automotive flywheel'?
https://www.autopartswarehouse.com/e...l?Ntt=Flywheel
#94
Quoted: 18378 Post(s)
Liked 4,512 Times
70T?
I did pick up a really big 1/2" pitch ring that was about 1/4" wide at the local recycler. I assume made for gocarts or something.
There are also a few 60T rings, and a 61T ring with ramps and pins (or there was at one time).
#96
Quoted: 41 Post(s)
^^^ 100% Spot on. ^^^
The reason I jumped to 70t, was because of how easy the 52t felt. I don't want to buy new chainrings every few weeks jumping 2-3 extra teeth. So I bought what I think I can handle, and I work up to that.
I've been cycling all my life as many have, and I think it's natural for me.
The reason I'm converting to single speed is to gain gear efficiency, and because ever since I started cycling, I've only used the highest gears, for climbing, flats, etc.
Most people on here who are shocked about this, and measure up to world records, don't realize that not everyone wants to be a pro cyclist, a world record holder, or famous, and there is always someone better than the best.
I think most people here are stuck in the mindset that cycling is strictly an endurance sport. It is to some degree, but it's not.
#97
Non omnino gravis
Take the power and divide it by the rider's weight to get a figure of 14.7W/kg. This is an utterly exemplary amount of power, as the best Tour cyclist in the world can sustain just under 8W/kg for that duration. If the OP could produce even 2/3 of the effort he is now claiming, he would be one of the most-- if not the most-- powerful cyclist(s) in the world. What he's claiming now is simply implausible.
#98
Quoted: 41 Post(s)
Making some necessary assumptions based on the OP's vaguish nature, but for a cyclist of average height and weight (5'10", 150lbs) in a phenomenally aero position with a 52/11 gear, 65kph (40.4mph) would require a cadence of ~110rpm and a power output of roughly 1,000W. Not outside the realm of possibility until the distance becomes 5km. OP states "just under" so let's round it down to 3 miles even. At 40.4mph, a mile clicks by every 89 seconds, so the above-mentioned power would need to be sustained for 4m27s, give or take.
It's great you can throw some numbers into a cycling calculator, but there's more to it. Did you factor in frame size, leg inseam, muscle mass, VO2, crank arm length, etc? Do you understand the physics of what an extra 5-20 mm crank length, or + avrg 3-6 in length inseam, what kind of difference that makes in watts? Maybe you can weld some metal together, but you should brush up on your physics, anatomy and physiology.
#99
World record in the 4km individual pursuit is 58kph. That's from a standing start on a fixed-gear bike, but even so, someone of your abilities should be able to beat it by a few kph.
#100
Non omnino gravis
Oh my poor friend...don't you know hitting 500 watts by a 5'5" 100ibs, 20% bf, is much different than a 6'5" 245ibs. 9% bf?
