Upgrade to front drum brake?
No Motor Vehicles
I might hire a shop to build a front wheel around a Sturmey drum brake hub with dynamo. The goal is less maintenance and better wet-weather stopping than calipers.
Anyone done this? Any reason not to? Is a 70mm drum adequate? Is a 90mm drum overkill? I never want to endo. Can the OEM steel fork handle the torque from the reaction arm?
The bike is a Chicago-built Schwinn Suburban 5 speed. Been commuting on it for 3 years. The single-pivot caliper brakes are just OK with perfect maintenance and perfect weather. They go downhill from there, as it were.
The bike's nice otherwise. It's comfy and upright but you can still stand up on it when it's time to crush it. The OEM saddle's awesome. The OEM derailer was not good; some cheap SunRace on there now is 10x better. Basically Schwinn got the ergonomics right, built a strong frame that has held up, and paired it with hot garbage for the drivetrain and brakes. You can see why there's mixed enthusiasm for these bikes.
I love the low-maintenance hub gears and hub brakes on Dutch bikes and English roadsters. But I don't $1500 love them, which is what they tend to cost in the new world.
Bikes: Ridgeback Steel Tourer,Recumbent SWB,Steel Road,,Raleigh Twenty,Elephant Bike,Pashley Pronto TNT.
Quoted: 21 Post(s)
Liked 5 Times
I find the 70mm very nice.Brake linings only last about 50,000 miles.The other option is the hub with the same brake and built in dynamo hub.Can you try this hub on a different bike before you buy?
No Motor Vehicles
"Only" 50,000 miles? That would last me 25 years, that sounds great.
I haven't tried a Sturmey drum. They're rare in the US. It cannot be worse than the brake it's replacing, the stock '70s Schwinn sidepull caliper with a warped brake bolt which has never worked well.
Two weeks ago a driver right-hooked me. Everyone's fine, it wasn't a hard hit. With better brakes I might have missed them entirely.
The shop recommended a 700 size (ISO 622) wheel build instead of the Schwinn oddball 27" (ISO 630) size. A 700 wheel would bolt right up to any number of lighter bikes. Rim brakes are dead to me, so most new bikes are too. With a drum brake that bolts right up, all those bikes become an option.
I'll get the dynamo hub version for sure. There's no point in building a wheel without one.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Well my XL-FDD is HALF way to 50,000 miles in 7 years. LOL The cam interface is the only thing wearing.
The RS bearing had 4 crushed up balls at 17,000 miles. Cleaned it up, put in a new sealed bearing and carried on. It can NOT lock the wheel up and I don't want it to either. Still, I was using it for 12,000 miles with a POOR caliper on the rear. My lights are always ON. What drag?? It has done 45 mph easily.
My bike is 80 lbs on a light day and 120 on tour where I did 8,100 miles. I seem to be the only one doing this with a drum brake. LOL
I have SA-RD3 drum on another bike and had a FAST SA XL-RD5 for 3 years also. They were better at locking the wheel.
Plus I went from a steel rim to Alu on the front of a CCM. The caliper now works far WORSE in dry conditions. WTF
Likes For GamblerGORD53:
I have drum brake hubs still in service for over 30 years,
the Company that makes them changed hands in that time period..
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I had an X-FDD on my commuting bike. The 70mm drum brake was great. Easy to modulate and works nicely in all weather. I think I have close to 30,000 miles on it with no issues other than having to replace one of the bearings. Occasionally the cam doesn't release well after braking, but just a tiny bit of high temp grease cures that. I had it mounted on a Raleigh Supercourse with original fork and had no concerns. I paired it with a drum brake IGH 5 speed in the back.
Jedi Master
I have a bike with an SA X-RD3 rear and an X-FDD front. Nothing like the mileage of the others on here, but I've been happy with the setup.
Quoted: 626 Post(s)
Liked 701 Times
I have dual 90mm Sturmeys on my velo. It weighs 70 lbs, so with me in it, and my usual commuting gear, they are stopping ~260 lbs, often from about 50 mph. They work great, and I've been told they will last a long time, but I just got it (it's 5 years old) so I don't know too much about the actual longevity.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
The Fork on my Disc Brake equipped Bi- Fri does not taper.. or have any bend... and its a 20" wheel..
The Thorn Bikes , SJS in UK, wont make a raked fork with disc mounts, their touring frames have V brake bosses..
German Tout Terrain fattened up a left blade for their disc forks,
drum brakes are not as severe as disc brakes on forks.. locking up, for 'stoppies' , which others see as a shortcoming..
Oh well..
Oh well..
Jedi Master
“Less maintenance” LOL I totally disagree. Also when dealing with a puncture disc brakes are much faster over drum.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Again, if your frame is not designed for disk brakes, any discussion over which system is better is moot.
Likes For Moe Zhoost:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Add in bent rotors and the requirement to immediately swap pads when they run out or risk ruining the rotors as well and they are simply higher maintenance than drum brakes.
They do offer a weight saving and better performance in mountainous terrain because of better cooling but that can be fixed too with some German ingenuity and heatsinks from the trike-crowd at Ginkgo-Teile.
It's kind of a toss up when it comes to punctures. Get some proper tyres and that is virtually a non-issue.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
There is no need to disconnect the shift cable to remove the wheel in order to replace a tire or tube on a Shimano 7 or 8 speed IGH. There is enough slack in the cable assembly to move the wheel out of the axle slots while it remains within the chain and seat stays and to provide plenty of clearance to remove and replace a tire and/or tube.
Bikes: 1982 Trek 720 1991 Trek 950 2003 Co-Motion Primera
Been using 70mm front and rear drum hubs on commuter bike.
Do about 5000 miles a year on them.
Stops consistently in all sorts of weather.
Using Marathon Plus tires; heavy, but bulletproof.
Don't know what size wheels you have.
Keep in mind that the drum hubs have a larger spoke hole circle than other hubs.
Might mean your local shop would have to lace the wheels in a cross-2 pattern
rather than the usual cross-3 in order to avoid odd angles at the rim.
Had to do this with my wheels; they are ISO 584.
Likes For vmizera:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times
I've used one - at the time the bike was a single speed with a rear rim brake, was for winter biking. Loved it. Just built a wheel with a Sturmey 3sp drum brake hub - haven't switched the brake to the drum yet, still using the rim brake, I just switched my Bianchi to Sturmey 3sp.
Likes For Viich:
No Motor Vehicles
OP here. I'm going tomorrow to maybe buy a euro city bike with rollerbrakes and 3-speed IGH. The seller brought it to the US from Germany and now can't ship it back. It's my size, with fenders and real springs under the saddle.
Thank you for the encouragement on the Sturmey drum. I'll still build up a drum brake for the Schwinn. After the right hook, I want two bikes with two solid brakes each, so there's always a backup bike without compromising safety. Neither of my bikes has two good brakes today; each has one decent brake and one brake-shaped object.
Side note, this new bike is also black. I've been toying with the idea of getting a black bike, some black pants, hi-viz top with blue accents and a gold-patterned patch on the shoulder and a walkie-talkie. I would never impersonate anyone, but I can promote myself to Polite Officer. Anything to get motorists' attention.
No Motor Vehicles
Today is new bike day! I bought a Chrisson Vintiago step-through city bike which somehow found its way to the US. It's got Shimano 3-speed hub, IM45 front rollerbrake and C3000 rear rollerbrake. Has a hub dynamo and working front and rear lights. Fancy!
The handlebars are oddly asymmetrical -- not fancy! It's possible this isn't a high-end bike.
The front brake is oddly weak. Could be worn; could be shot; could be that the low end rollerbrakes aren't all that. I have a bigger, new rollerbrake (the IM86) on order. Hope it'll bolt up to the same mounts.
the British company has changed hands, and was bought and relocated since then, the hubs are fine.. still ..
.. now they'd be called the X-FD & X-RD...
Hack
Quoted: 347 Post(s)
Liked 190 Times
As far as the tire change speed, unless a support car mechanic is throwing on a ready wheel, the 15 seconds to disconnect the cable and loosen the reaction arm is negligible in fixing a flat. If I've got a flat, whether I'm running rim brakes or drum, I assume I'm taking 7min or so - I usually remove the tube, sand the area around the hole and glue it, wait 5min for the glue, patch then start to put everything back together.
And I've come across many people on the way home unable to get their disc-equipped wheel back on - presumably because they bumped their brake lever slightly while their wheel was off. I always stop and try to help, sometimes have a tool I can use (if I took a butter knife with my lunch that day), but usually don't.
You can disagree with the crowd on which is less trouble, but it's certainly not a laughter inducing difference.
with 15mm axle nuts there is an abundance of light wrenches for the Fixie street crowd..
I exchanged the nut/bolt on the rear reaction arm , with a pull pin, for the chain stay band.
Thumbscrew/wingnut would work too ..
front just slides out of the fork band that comes with the hub, as you remove the wheel
and the cable end comes out with a barrel end .. un touched...
