Seat bolt for Waterford?
Hi. I bought this frame (1990s) without a bolt for the seat clamp. What style/size, etc should I buy to replace it?
I have old seat bolts from the 80s and earlier but I don't think they are correct. Any suggestions?
Quoted: 18369 Post(s)
Liked 4,507 Times
Maybe try a local nut & bolt store. With some luck, they'd have an Allen head bolt that will thread into the left and fit down into the right.
At least they would also help you get the sizes right, and maybe a temporary solution.
Quoted: 3806 Post(s)
Liked 6,674 Times
Most of the bikes I've seen with that style of seat clamp use an M6 cap-head bolt:
that's the ticket. does it have a nut on the other side? seems like there would be something more attractive than a nut? or would the nut be recessed/
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
Liked 6,674 Times
No need for a nut. One side of the braze-on looks to be threaded. What I can't see is if the other side is enlarged for a the cap head of the bolt.
I found another thread discussing that this frame takes a 27.4mm NOT a 27.2.
This is disappointing b/c I have a nice Thomson elite that is marked 27.2; I was going to use this Thomson once I figured out the bolt solution.
Can you confirm your '95 1200 series uses a 27.4? My frame is also a 1200 series and approximately early to mid 1990s. thanks.
Liked 4,507 Times
How loose/tight is your seatpost in the frame? Do the ears look bent?
There are quite a few 27.4 seatposts on E-Bay. TPC has a pair of nice looking Dura Ace seatposts, and a few Campy ones are up there too. Also, several zero setback Thompsons.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
If you want to use your current post, use a shim. It works great.
Quoted: 1372 Post(s)
Liked 1,751 Times
I have a spare 27.4 that I removed from my Waterford Precision, in case anyone is still looking. I replaced it with a Campy model and that cost me a buck or two!
I can also check to see if I have a spare seat lug clamp bolt also, if there is an interest.
All 753 tube sets used the 27.4 dia seatpost. Mine is 95. The 531 and 853 bikes use a standard 27.2
Decrepit Member
Originally Posted by Waterford FAQ #20 from old website
Make sure you have the proper post for the frameset. Up until around the 2000 model year, our models 1200 and 2200 road racing frames require a 27.4mm post. A 27.2mm post often fits - so closely that many Waterford 1200's have been delivered with that post. Unfortunately, with heavy riders, frequent seat height changes and otherwise heavy use, tightening the post can become increasingly difficult. If the problem remains uncorrected, the seat binder bolt may break, the seat lug can deform and seat stays can pop apart from the stress!
This is an example of a 1200 seat lug deforming because a 27.2 post was used in a 753 frame, and the resulting seat stay brazed join failure.
yes, I am interested. I really want to get this bike on the road before temps drop....I keep hitting snags that slow me down. Must press forward1
you are likely correct,but the cap sticks out in an ackward way. It seems a frame of this caliber would have used something more elegant. If you look at the post above from Scooper, there is no recessed area at the seat clamp area. So I am wonder if just a regular bolt was what was originally used or something more flat.
Liked 1,751 Times
This.
What if my seatpost slips during rides?
Liked 1,751 Times
I picked up my Waterford, from the local bike shop, today. While there I asked the head mechanic what size the clamp bolt is and he quoted M6. The seat post I have is nothing special but it is the correct size. Will send a pm later today.
