What did you do for your Hybrid today
#826
Trekker
Bikes: Trek Domane SL6, Trek FXS6, Trek X-Claiber9
Quoted: 107 Post(s)
After a long 10 day Florida “winter” I got out on the trail on the Surly, it finally got into the 70s, what a great day. Rode a nice 60 plus miles on the Pinellas Trail, and ended my Beer & Taco day at Hooters. Gotta love Florida weather !
Cyclemeter - Cycle - Jan 21, 2018 at 8:31 AM
Love the local breweries too !
#828
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
Ergon grips, Origin8 drop ends, and I think Profile Design ends. Generic foam grips tape on the drops and some old MTB slide-on grips for the other bar ends. Plenty of room still for 2 headlights as well.
(The red tape was for mounting some Sunlite mirrors, which I've since removed. After looking at this pic, I finally removed the red tape as well.
#829
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Jimmie, thank you for the photo -- real nice! It helps that the bar is a true flat bar -- riser bars are often pretty limiting in the grip area because of where the drop (or riser, depending on your perspective) is positioned near the center.
You're running my favorite of the EF51s -- the silver versions. I have one pair in 3x7 that's all black, one silver in 3x7, and one silver in 3x8. This type of shifter lever helps mitigate the drop bar issue because all of the shifter is out in front of the bar instead of underneath it like MTB-style shifter levers traditionally have been.
#830
Quoted: 14 Post(s)
Guys, gotta help me out here… I bought another bottle holder for my Trek. But I noticed that there is even space for something on the bottom side of the frame (red arrows on pic). It's actually the same screws as for bottle holders, but I can't imagine why you would put one there (doesn't even fit I think). So anyone a clue what this is for?
#831
Proud hobo biker
Quoted: 202 Post(s)
Another bottle cage. You could also mount a pump
#832
Quoted: 1002 Post(s)
Liked 237 Times
Or one of those cargo racks made for bottle cage mounts if it's not too wide. See post 828 above for an example.
Also I think a bottle cage would fit there between the frame and the tire. Especially if he used a slightly shorter bottle.
#833
Proud hobo biker
Quoted: 202 Post(s)
My bike, BTW. And you're right; the Outpost Cage would be perfect there for carrying extra cargo. (Or a growler, which is all mine ever carries).
#835
Quoted: 1581 Post(s)
Liked 1,189 Times
Assuming I use Project 2010 Sirrus Comp for another season (likely), considering the following:
1. New cables all round -- necessary
2. Replace cassette (SRAM 1070 12-28) and chain (SRAM 1070) -- necessary
3. Brake blocks (Kool Stop) -- necessary
4. New chainset. Have my eye on Praxis sub-compact (Zayante 48-32). 48 ring for SRAM Apex hard to get, and I feel like a change.
5. Compass 32 (Stampede Pass) Extralight tires.
Just thinking at this point. Would drop all-up weight from 19.4 lbs to around 18.5 (with pedals) -- kinda fun.
Likes For badger1:
#836
Liked 762 Times
Vintage Touring Bike Restoration - BIKEPACKING.com
What model is your Trek?
#837
#838
Liked 1,189 Times
Thanks!
It's been a really good bike these past years. The frameset, really. This model year was a bit of a freak with the Sirrus: the Comp/Expert/Pro had this Columbus-tubed E5 main frame (smoothed welds) w/carbon stays + carbon fork. Extremely light, comfortable, and with a geometry that just happened to suit me perfectly.
#839
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Thanks!
Wow, I didn't realise your frame was so special.
Unless you want disc brakes, there probably isn't much reason to get a new bike/frame.
#841
Liked 1,189 Times
BTW, I'm sure you know but ... your Toughroad frame is itself, imo, special. I'm admittedly a Giant fan (my other bike), but a lot of people don't realize that that SLR aluminum is extremely light, extremely strong, quite resiliant (comfortable), and ... especially, fabricated quite literally by Giant from raw aluminum ore to tubeset, as are all its aluminum frames.
Giant has its own smelting facility, and thus controls literally every aspect of its tubesets. It is the only manufacturer that can claim that. Devinci (here in Canada) had a similar control over its high-end aluminum frames, but the raw alloy was manufactured by a Canadian third-party facility.
#842
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
Got a few miles in on the Surly, fun day fur sure, sun wasn’t out much, still got a 60 plus mile ride though.
Cyclemeter - Cycle - Feb 3, 2018 at 10:01 AM
#843
Trekker
Quoted: 107 Post(s)
Nice Scooty! We got snow last night. Can't wait for Spring.
#844
Liked 310 Times
God your beers look fantastic.
#845
#846
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
It could also be used to carry extra water when traversing long stretches with limited access to fresh water. When your primary bottle is empty, you can stop and swap them around or refill from the spares.
I also have a bottle opener that mounts on the wall which happens to have the hole spacing the same as the bottle cage screws on a bike. It's too awkward to use on the inside of the diamond, but on the bottom it is perfect.
#847
Quoted: 356 Post(s)
I found out riding a 50 pound bike that you don’t use the 48t front gear AT ALL, so I decided to change it out to a more forgiving 42t. I ended up buying a 42t chainring for a Shimano m770 crankset even though I have a m551 crankset, it does fit and work well, but it doesn’t mount flush because my crankset is a little different. No big deal, it’s just ascetics, so I adjusted the derailleur mount height, and took it for a little ride, and I think this smaller chainring will be much more useful. Now I will be running a 42/36/24 up front, at least when on the rare occasion that I have a nice tail wind and long run, I will be able to use my big gear.
#848
Trekker
Quoted: 107 Post(s)
#849
Liked 310 Times
#850
Quoted: 356 Post(s)
I couldn’t believe I had a photo of the crankset with the 48 set up, it was the day I bought the bike. If you’re wondering if the derailleur it mounted to high, it’s as low as it will go, if I mounted it any lower the inner derailleur cage would rub on the center 36t chainring. It shifts just fine though, the Dynasis system from Shimano works pretty well.
