Help me find my Bike
I'm looking for a bike to add to my walking and bus taking routine. I'm 5 feet even, so I need an extra small frame, and I can't spend much more then $150, so used is probably the best way to go. I'll be using it for around the town biking; no offload, and I need multiple gears. I also need the handle bars to be in an upright position. I know that's a tough order, but if you have any suggestions, I'd be grateful.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
Here is a frame size calculator so you can figure out the size you need. It needs your height and your leg size. https://www.ebicycles.com/bicycle-tools/frame-sizer
What you are probably looking for is a hybrid bike or even a lightly used solid-frame mountain bike(no suspension). With smooth tires, a mountain bike becomes an able street bike. You may also be able to find a used bike with an Internal Geared Hub, like the classic 3 speed.
And in general avoid shoddy bicycles like you might find at Walmart: Next, GMC Denali, Genesis, Kent, Roadmaster, Huffy, Mongoose, Hyper are some of the names to watch out for and avoid. Schwinns may be great or bad. Brands like Trek, Giant, Specialized, Cannondale, Surly, Scott are respectable brands and should hold up. Raleighs, and Free Spirits can be okay too.
Good luck. Feel free to ask more questions. The more we know about your situation, like how you want to use a bike, recreation riding, utility riding, commuting, etc, the more we can help.
"He who serves all, best serves himself" Jack London
In the right lane
Go to a bike co-op and see what they have. Problem with many Craigslist bikes is that many need additional work to make them road ready.
At your price point, I'd be looking at an older mountain bike with rigid fork. 26 inch wheels. Nothing fancy but the best bang for the buck.
Sophomoric Member
I don't know... This bike doesn't look too bad:
https://www.walmart.com/ip/700c-Schwi...Q%26A+Exchange
I do like the idea of getting a used bike--if circa81 knows enough about bikes to select a decent one. Also, at her height, pickings might be slim for used bikes. But I do think the Walmart bike is adequate for her needs, and will come with a warranty. It's going to be difficult to find a small size used bike in the OP's price range.
"Think Outside the Cage"
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
If you want to explore the co-op route, there is a sticky at the top of this (LCF) forum that is essentially a directory of them.
If you end up considering something from the big box stores like Wal-Mart, look at ones that have 24" wheels. Bottom of the barrel parts, heavy as a boat anchor, but if (and that is a big IF) the assembler knew what they were doing, it should be functional until you can get something better. Also, avoid rear shock models at all costs.
Community guidelines
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
How many gears? Raleigh Colts and Space Riders would work. Both are designed for shorter riders. They only come with 3 speeds. Durable as all get out. Kind of hard to find, but would fit in your price range. I second heading to a co-op or finding a friend that knows bikes and is willing to help you look.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Sophomoric Member
My nephew has a bike that is probably perfect for me. I'm gonna check it out soon; I'll tell you guys what happens soon. Thanks.
Bikes: Origami Crane
If a gently used folding bike becomes available in that price range, consider it even if you never intend to fold it. Upright riding position and naturally smaller frame sizes come with the territory.
Quite agree that those of us between 5'0" and 5'1" can look at the upper sizes of children's bikes for a fit, too.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
I'm 5'3", and I used to ride a 70's kids 5-speed that I converted to an "upright" bike by swapping out the handlebars. It was $10 on kijiji.
It had super polished 24" steel wheels though, and the braking performance in wet weather was basically nil. I ended up giving it away and finding a bike that I trusted to stop within a couple hundred metres. If you plan on riding in the rain or snow, be wary of steel wheels.
Where did you Leave it? <old joke>
I cannot remotely predict what you will find. where have you looked?
got a bike Co Op that reconditions used bikes ?
at least then it wont still need more money sunk in right away on the unseeable bike, in poor condition.
once I calculate the insurance and purchase and operating expenses of an auto .
I have justified and spent more than that to Upgrade the front wheel on my Brompton
to include a hub dynamo light set.
folding bikes make multi mode transportation easier .
I'm your height (5'1" but I'm older now so shorter...) and I got you!
Now I'm riding an 18" Diamondback Voyager I - the guy's model - (circa 1998 or 1999) designed to look like a beach cruiser but with the gears I need and the upright handlebars and even though it's supposed to be way way too big for me, it adjusted perfectly with the seat and the handlebars and all and I could ride it all day long. The beach cruiser fit for my size would be a 15 to 18" frame, but the mtb frame says smaller, much, although this one works great and I don't know if it's because it's designed to look like a cruiser but it's really a hardtail mtb...or what. But it works. It's a bit heavy at 28 lbs. but you know what? It's easier and more fun to ride than any of the higher end road or hybrids I tried before. I am not actually riding that much since I have had some depression and PTSd going on so the poor thing is sitting in my hallway getting me a different form of ex-Catholic guilt but I can't make myself get rid of it for the fact that it has been the only bike I even rode comfortably everywhere - in the rain and on some ice and up nasty Seattle hills and over curbs and sidewalks and so forth.
The price? I got it free from someone's side of the road pile of moving castoffs. All that was wrong with it was the tires didn't have any air in them. It was even straight-rimmed and lubed well enough to put in some air and go, and it's a really good bike for my size. It sells for around $150 used they tell me, and online they've been as low as $50 though I don't know the condition. This is in great shape though it has a little bitty coupla scratches in the paint here and there. No big. Doesn't look like it's ever been wrecked, and I can't imagine what it would take to do any real damage to anything on this thing other than maybe bending a rim coming off a thirty inch Seattle curb...(I exaggerate. Sorta.). They sold new for $400 or thereabouts, but if you live anywehre near me and want to try it for awhile just to get it out and give it some love so I don't feel quite as guilty, you are welcome to come by and give it a foster home for awhile. I may get back to it someday but probably knowing me not until the Spring now. Or not. But you could try it either way and see if you like the ride, and then get your own or continue fostering mine depending on the way the world goes. Who knows.
I live in Seattle, in the Wallingford neighborhood. Let me know if I can help. Good luck to you! Look for any of the Voyager I, II or III's online - they're great. Like I said, I'm 5'1" with a 27" standover (Japanese descent makes for short legs with normal torso - not so good in fashion terms....) and I'm riding this 18" hardtail mountainbike (supposedly) that looks like a cherry red beach cruiser.....not totally but the frame is a nice swoopy feel....no perfect triangles I mean. They make it in smaller frame sizes and even in a women's 16" or 17" I heard. Good luck.
Sandy
Last edited by 4everhopeful; 09-27-13 at 04:06 PM. Reason: typos. and to mention this is a guy's bike
In the right lane
I am 5'1" but I've gotten shorter at 53 yrs old, probably, and I have like a 27" standover which has always made biking a challenge. Add a back that isn't all that happy and I had a hard time riding for any longer than the two or three days it took me to get over the "ex-Catholic guild-induced joy" of waking up in pain and riding in pain and going to bed in pain, even with a close-to-custom 46.5cmish Women Specific Design Trek 2300 road bike (back when I had money).
Whatever you do, don't assume 53 is a time to slow down. It's a great time for a new beginning
OK, I got my nephew's bike, I don't know the specs, but here's my thoughts so far. First, the size, for the money, anyway, is nearly perfect, but my feet keep rubbing into the front tire when I make most turns. Second, for whatever reason, I can't seem to keep my my bike in a straight line, which is terrible for someone who wants drive around town. Maybe it's because I haven't ridden in 20 years, maybe it's because this is the first bike I've ridden with gears, or I just need more practice. Third, I need to get a new seat, this one's just not comfortable at all. That's all for now.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Sophomoric Member
Or are you just swerving around when you're concentrating on the gears or whatever? Again, focus on going where you want to go. Put the bike in an easy gear and forget about changing gears for a few rides. Then start using the front gears only for the next few rides, since there are only two or three of them. Then add in the rear gears last of all, of which there are seven to ten.
Anytime you practice something new, do it in a location where you don't have to worry about traffic or hitting any walls. I crashed into a stone retaining wall when I was learning how to shift gears. ouch!
I've been riding flat footed and going too slow; thanks for the advice guys
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
Guess I'm a little late, but here's your bike, only $75
https://portland.craigslist.org/mlt/bik/4139990530.html
Casually Deliberate
Sandy
Sandy
Embidd
General Cycling Discussion
8
06-28-16 07:51 PM
kissthegoat
10
06-21-11 07:19 AM
