Fully loaded touring on a "vintage" XL ?
Bikes: 92 Bridgestone xo-2 Turner Sultan
Quoted: 47 Post(s)
Not sure what the definition for vintage is, but wonder if it is a good idea to go out fully loaded with a 200 pound rider on one of the classic touring bikes on an XL frame such as the;
Fuji IV,Miyata 1000,Specialized expedition,Centurion Pro Tour,Univega Gran Turismo,Schwinn Voyageur SP ?
Or is this just asking for trouble ?
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I'm 180
Quoted: 47 Post(s)
Quoted: 286 Post(s)
Liked 100 Times
You're going to get answers on both sides of this divide, but nothing definitive. The answer to the question of whether a good vintage tourer is capable is an unqualified "Yes!" Once you get into more subjective things like flex (and yes, someone is liable to pull out studies or supportive data, but what I've seen is basically anecdotal), you'll have a range of answers.
The most important questions are fit and feel. What fits you best? What puts a smile on your face and makes you feel like you're 7 years old again?
Any of those bikes you cited should get you where you want to go. I don't know the failure rate due to metal fatigue on old frames but that might be a distant concern. You want it to fit you, or tailor it to fit, no matter what.
Quoted: 930 Post(s)
Liked 1,291 Times
Steel frames don't come anywhere near their yield strength during use so, barring crash damage or severe rust, metal fatigue is a complete non-issue. Aluminum or titanium frames are where you have to worry about this. Those bikes are all great, and highly coveted tourers. The only issue you might have is that most come with 27" wheels, limiting tire choice unless you convert to 700c.
difficult to answer a hypothetical question concerning subjective ride feel of a an unknown bike of unknown age ridden on unknown terrain.
Quoted: 47 Post(s)
I'm currently riding a 1992 Bridgestone XO2, with front and rear racks and Butterfly handlebars. I love it but the bike is a little on the small side for me, so I was looking at some alternatives. I'm 62 and live in the Blue Ridge mountains so having a triple chainring is a necessity on any bike i ride.
Quoted: 47 Post(s)
My next tour will be a hub and spoke in Northern Wales, but on a rented bike. Probably the next I will do Stateside on one of my bikes will be the gap.
Quoted: 47 Post(s)
I'm also curious about the Nishiki touring bikes. It looks like there are several models listed is touring bikes, but does anybody know the pecking order in terms of best to worst?
Depending on where you go, things have changed so much you run the risk of damaging a wheel and having a difficult time replacing it at a LBS...
Quoted: 47 Post(s)
Quoted: 930 Post(s)
Liked 1,291 Times
Not that difficult. You can get reasonably priced 27" freewheel-compatible wheel sets shipped pretty much anywhere within a day or so. For most bikes you could even substitute 700c wheels if the brakes will reach.
Price is what usually is a hint..
I Have not been in a Nishiki Bike Dealer's shop ,
in 21 years.
Sunshine
Quoted: 10959 Post(s)
Liked 7,487 Times
it rides just fine loaded up and me + gear for sure weighs more than you + gear.
taller bikes will flex more, but I don't notice anything annoying lile ghost shifting or scraping chainrings due to frame twisting when I'm out of the saddle.
with that said, it's a mix of modern and vintage components which is why i trust it. Cartridge bottom bracket, handbuilt 36h 700c wheels, and 3x9 gearing are the major changes.
good wheels make the most difference. Weak wheels are no fun.
For a handful of years I had an '80 Schwinn voyageur 11.8 that was fun to ride, but flexed. That was more of a sport touring bile though.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
You should be fine on any of those bikes. I'm 67 (until next week) and have always ridden tall frames, 25" on my early tours and a 62cm Bridgestone RB-T most recently. Flex can be an issue so take your loaded panniers along for the test ride.
1981 Trek 720
I am on the completely opposite extreme: I weight 138 pounds and ride a 19.5 inch 1981 Trek 720. I had it reworked as a triple and rode it fully loaded-about 38 pounds in 4 panniers- around Lake Michigan last summer and Lake Erie this summer - on 25 mm tires at 110 psi - contrary to all talk about wider tires at lower pressures. I had the time of my life- no problems- other than being on the lookout for bike stores with a presta pump. I just don't have the arm strength to push more than 70 psi into my tires. The bike handles beautifully. However, I don't know if the frame and wheels could handle your weight plus the packs and baggage. Perhaps someone on the board can speak to that. But I would not trade this bike for a Surly LHT and feel fortunate to have landed into this old Trek.
Liked 2,446 Times
By "flex" I meant the tendency for some loaded touring bikes to develop a disconcerting shimmy or wobble on fast descents, the ones on which you do not want such a distraction. My first experience with it was on a 25" Batavus with handlebar bag and rear panniers, the second on a 25.5" Trek 710 with the same bag setup and the third on the 62cm RB-T with four panniers plus HB bag. I was handily under 200 pounds at those times and touring load was 30-50 pounds. I don't hear other tourists complain about this but I can't believe I'm the only person to have experienced it.
Quoted: 47 Post(s)
Quoted: 286 Post(s)
Liked 100 Times
Not an issue with my Trek 720
No wobble at all descending with 4 panniers, probably 35 lbs + rider @ 180 lbs.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Try ditching the bar bag. True some bikes do just have shimmy at high speed, but myself and many others have found bar bags(the heavier the worse) to cause it on bikes that otherwise wouldn’t have a problem. A lot of weight on top of a rear rack will also make the bike more prone to shimmy.
Firm but gentle
Liked 2,446 Times
