1967 Brooks Professional - What's with this one?
十人十色
Just bought a 1967 Brooks Professional. Looks hardly ridden but there's something odd about it... or is it just me? The seller tells me he polished the rivets and Proofide'd the leather.
The rivets and badge have been polished, the chrome is excellent, there are no seat bone dents in the leather and it's never been tensioned. But the chocolate-brown, mat finish and the faintness of the model name tooling on the dies are new to me.
Bikes: '39 Hobbs, '58 Marastoni, '73 Italian custom, '75 Wizard, '76 Wilier, '78 Tom Kellogg, '79 Colnago Super, '79 Sachs, '81 Masi Prestige, '82 Cuevas, '83 Picchio Special, '84 Murray-Serotta, '85 Trek 170, '89 Bianchi, '90 Bill Holland, '94 Grandis
Liked 12 Times
It's just you.
十人十色
Okay, so that's 1 for the mat finish to the leather being normal. Thank you, Picchio Special! Your confidence is reassuring.
I only have 1 other, shiny leather, 1976 Professional to compare it to. Otherwise, the 1947 B15 Champion Standard I have is likewise very shiny and they are both what I would imagine my B17 Champion Special and my B17 Flyer will look like in 40 plus years' time.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Possibly cared for indifferently. Possibly has been soaked and remolded. I've seen plenty of variation in the surface appearance with these, and this is within what I'd consider the range of "normal".
Quoted: 113 Post(s)
Liked 16 Times
use some natural shoe polish and buff it with a brush, it'll shine up, then ride it a lot, put a cotton cloth under your butt for extra polishing.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
十人十色
What do you mean by 'remolded'?
十人十色
Thanks, cyclotoine! I have a pair of old cotton chinos I use for that. They look pretty nasty from behind. Shoe polish I wouldn't have thought of.
Quoted: 821 Post(s)
Liked 255 Times
Shoe polish works great, just don't do the "bonehead" move I did. I forgot the cotton cloth and managed to put the excess polish on the rear of a new pair of light tan trousers. Zero style points according to my fashion coordinator!
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Disraeli Gears
There are probably as many treatment/break-in/maintenance regimes for Brooks saddles out there as there are buns to sit on them. One of these, I recall, advocates rubbing the saddle top with steel wool until it turns white all over, then applying some sort of potion or other. Maybe that's what happened to this one.
Vintage French Bike Fan
Bikes: Peugeot UO-8, Peugeot 80's 12 spd
I've seen plenty of older saddles with the faint lettering. That's pretty normal. I don't know about those rivets, though. Even the older ones I recall seeing had been hammered, and these have not. Maybe I just haven't seen enough older ones.
Cheers,
Karl
Cheers,
Karl
Liked 12 Times
Generally, the Team Pro oversized rivets are hand hammered, but the smaller ones are not.
Quoted: 1854 Post(s)
Liked 662 Times
If you want the finish to be restored, first just try basic first aid and gentle use. This thing is 40+ years old after all. I would suggest just saddle soap for gentle first aid, allow it to dry, put it on a bike, and see if it will even hold up your bones, or if it will start to tear quickly. It doesn't LOOK like there are any weak points, but there could be some.
The pressure of a rider and the motion between the rider and the saddle should also tend to smooth out the surface. I have definitely seen that happen to old or wetted saddles I've had. If it doesn't, THEN you have a slightly more unusual situation that might need some more aggressive treatment.
Don't even think about some of these more aggressive treatments until you've tried the easy stuff.
I have seen the imprints fade due to use. Wear, moisture, other weathering, I can't say for sure what the cause is, but leather isn't plastic, and the imprints are not molded.
That saddle looks to be in excellent condition, considering it's 42 years old. I'd be inclined to attempt to use it, and if it doesn't suit you, assign it a place of honor in the collection, and get a newer Pro to ride on.
I had a Pro purchased around 1969, and it had the small rivets. There was an upgrade model at that time, but being a poor high school kid, I didn't buy it. Saddle worked great without the bigger rivets. Even back then, Brooks had some model "churn."
Karl
Stop reading my posts!
Quoted: 1440 Post(s)
Liked 1,058 Times
the rivets on the OP's saddle DO look larger than what I have on a "small-rivet" Pro, yet they are clearly not hand-hammered...I've never seen that variation before.
Given the condition of the bottom of the leather top, and the appearance of the rear badge, I'd guess that this was a very weathered saddle that has been buffed with something like steel wool to give it that velvet or suede-like nap. I wouldn't hold much hope for the leather lasting very long, since it seems distressed (dried out) and any original hide surface has now been "broken open" by the abrasion...but who knows: keep a (light) coating of Proofide on it and see what happens, but be on guard for any ripping at the rivets.
Liked 662 Times
I would beg to differ - with something this old, don't treat the leather with anything other than saddle soap and a damp cloth until you get a chance to ride it and see if it's worth working on. I know Proofide is what Brooks recommended, and something else is what Sheldon recommended, et cetera, but with a worn finish like that and so many years past, I'd proceed very gently. You didn't get it for free, did you?
It might smooth nicely just from butt polishing. That would be optimum - don't take chances on breaking ANYTHING down, and make it look better.
十人十色
Liked 1,058 Times
tens of thousand of miles ridden by a waif with sand-paper shorts? I don't think anybody can tell for certain based on the photos (I know I can't), this is something best judged by feel.
But I look at the photo of the underside and that cantle and rail sure don't show signs of long exposure (and I know what MY Brooks look like after long years of use and CARE, yet there's hardly a speck of rust on this one), nevertheless that leather looks far more dried out (and "weathered") than the old veterans that I'm still riding...so, I guess it's ME, too.
十人十色
Went and had a look at my other Professional, a 1976. I also fitted the 1967 and rode it today. A big improvement on the 1949 B15.
Liked 1,058 Times
just to be a little too anal-retentive: I'm still curious about the size of those rivet heads.
I have a "small rivet Pro" from 1973 whose rivets are 12mm diameter, and a B-17 Champion Special from date unknown with the hand-hammered rivets which range 16-17mm diameter (I would guess typical of a Hammered-rivet Pro as well).
What diameter are the rivets on your Pros (cause they *appear* to be larger than 12mm, to me)?
Karl
Liked 662 Times
十人十色
The rivets measure 12.5mm, as best as I can tell. I measured the most protruding one by pushing the vernier scale down into the leather at the sides of the rivet...
