Tires for mostly road, but also gravel
Quoted: 50 Post(s)
Hello, I'm looking for tires for my CX/road/gravel bike (something like 3in1, yep).
I ride 90% of time on roads, also sometimes starts on road races.
Sometimes also on gravel, forests roads, but it isn't nothing special, without mud etc.
I've already rode on Continental 4000S II 700x28c - light, fast, but not good for gravel.
I also rode on Gravelking SK 700x35c - very good on gravel, but I think too slow for road, road races.
So, I looking for someting between these. Which tires will the best? I done some search and interested in:
- Gravelking (non-SK) in 30c or 32c - should be faster on road, but still nice on gravel
- Specialized Roubaix Pro 30/32 - its for roads, but some poeple also use on gravel
- new Continental 5000 32c? But it's still full slick
BTW. I'm not interested in Schwalbe G-One tires - beacuse of quick wear.
There's always that balancing between anything road orientated is going to be horrible off road the second it's wet and anything that copes with that well is a compromise on the road.
I was running Vittoria Voyager Hypers most of last summer on roads / gravel but they became lethal when the rain arrived so swapped them out for GK SK's for the winter.as I didn't think the Non SK's would be much better than the Hypers off road when it's wet.
You haven't said what the max width you're looking for ??
Some other suggestions but they may be wider than you're after ..... Terreno either Wet or Dry, Specialized Crossroads ( friends running these on a Hybrid and he's bloomin quick on the road and copes with gravel / light mud), Hutchinson Overides.
Be interested to see what other suggestions come up with.
Quoted: 4560 Post(s)
Liked 2,802 Times
Continental Cyclocross Speed, 700x35, if your frame can handle that width.
The slightly wider Speed Ride (nominally 700x42, actually closer to 700x38) was my favorite all around hybrid tire for two years and I'll go back to them as soon as I get fenders wide enough for 'em. Fast rolling on pavement, smooth and secure on dry gravel and grass. Only fair on wet grass or in muddy conditions. The dimply file tread is very minimal. The tire is lightweight and rolls lighter than it seems like it would. Sidewalls are thin and it feels more supple than the modest specs indicate.
The Cyclocross Speed is the narrower version of the same tire, minus the extra puncture layer. It's the least aggressive tread of all the popular gravel and cyclocross tires, so it's well suited to mixed use on pavement and off-pavement in dry conditions. This review matches my experience exactly with the Speed Ride.
Quoted: 50 Post(s)
I think 700x30 or max 700x32c, no more - currently use GK SK 35mm and it's totally enough.
Continental Cyclocross Speed - yep, they are good, I rode with them about two years ago, but these tires are heavy (in comparison to GK non-SK or 5000).
Also btw, I'm not interested in tubeless.
Quoted: 1163 Post(s)
Liked 442 Times
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
You’ve already in way answered your own question. The Gravelking slicks, should be your choice. They are fantastic on roads, and they handle basic gravel road use. The SK’s are for more serious ‘off-road’ use but capable of decent road use when necessary. The slicks are the exact opposite. And as a user of the slicks, I can contest to their ability on gravel roads. On the blacktop, there is hardly a better tyre for the money than the gravelking slicks. I’ve owned a set of the challenge stranda bianca race 33’s, so I speak from experience here in that the two tyres are very similar. at normal retail prices, they are practically the same on paper. So much so, you could probably choose based on brand instead of function, and still end up with a good tyre. They both have basically 120 TPI casings, they have near identical tread patterns, and basically the same size. Where the gravelking pulls ahead, in my opinion, is that they are lighter (290g for 32mm vs 355g for 33mm challenge) and the incredible grip of panracers ZSG compound. As a bonus, the gravelkings can be found on sale quite often for $40USD or less, per tyre.
I had the same requirements. Like already mentioned, the Overide or the Continental SpeedRide/cyclecross are great choices. I use both mounted on different wheels.
Do you have a preference for one or the other, is one better on road one better off / if you ever hit mud ..... The Conti's seem quite appealing as we get quite a few thorns and they're promoting puncture protected.
Non omnino gravis
Pick whatever "happy medium" style tire-- that is, slick or file tread in the middle, knobs on the shoulders-- that suits you. There are a whole lot of them out there.
Challenge Chicane
Challenge Gravel Grinder
Clement X'PLOR USH
Continental Speed Ride
Hutchinson Overide
Kenda Happy Medium
Ritchey Speedmax
Vittoria Terreno Dry
As has been mentioned several times before, my recommendation is the 700x35 Hutchinson Overide. I have thousands upon thousands of miles on Overides, and they will go just about anywhere. Fairly durable as well, averaging over 3,000 miles per rear in mixed use.
Challenge Chicane
Clement X'PLOR USH
Hutchinson Overide
Kenda Happy Medium
Ritchey Speedmax
Think I just found the last pair of Continental Speed Rides that are available in the UK @ £12.99 a piece so happy days
I'll give the Overide the on road advantage because it is tubeless and possibly rolls a tiny bit better at 55+ psi but nothing any Strava results would show, it may only "feel" slightly faster because it is smoother tread. The tubeless if you buy into that is a huge plus for me. I've had staples, nails and other things in there and the tubeless did what it should and got me home. If the Overide or my desire was not for tubeless, I'd stick with the SpeedRide.
In my opinion, if you were doing a long 50-50 gravel/road ride, the Overide would require two different pressures for best on road and off road performance to be ideal. It rolls better on road with more pressure but it gets very jarring on gravel there. The Speedride, no need, I run 40-50 in all conditions back and forth with no problem and no need to compensate. I've never used Compass tires but I describe the Speedride similar to how others describe them.
I used both the Speedride and the Overide in all situations, long multiple day gravel only rides, long 100 mile mixed terrain rides, and long all day pavement only rides.
I did go through several periods of getting flats with the Speedride. Most of my road riding is outside of the white line and I go through a lot of debris. I currently have tire liners in with my Speedrides and noticed no difference in supple/performance, they have maybe 4K miles on them. As for mud, neither are good but comparatively the Speedride is much better and I feel comfortable with it or at least it is predictable and I know what to expect and when it is going to let go, even worst case with panniers and a load. If I know there will be a lot of mud I'll skip the Overide but I've done it. I glide though as straight as possible and let the underlying ruts guide me and hold on.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
A brand that hasn’t had a mention is Teravail. I’ve not personally used any of their tyres, but they have a good reputation so far. They have several tires that could be of interest to the op. Anyone have any experience?
Both the rampart and the cannonball look like viable contenders.
https://teravail.com/
Quoted: 92 Post(s)
Liked 12 Times
I use these (32c) on my singlespeed cyclocross bike that sees mostly road. They perform quite well on crushed granite and smooth singletrack. Choppy, deep, or loose dirt aren't its strength, but I've never had to walk it. Bonus: they wear extremely well.
Continental Travel Contact .. it's A Trekking purposed tire for riding past the end of the paved roads .. 622 its in 37 & 42..
SOMA Shikoros!
Supple ride and anti-puncture casing built in.
I normally run Conti GP 4 seasons. Have 25mm on my road bike(which I have been doing gravel rides the last couple years). I pickup up an older CX bike and have been running the same tires in 32mm on it and have like it so far on my mostly road training rides so far. Did fine at the local mountain bike park last summer in dry conditions. I plan on riding that set up for the Oregon Triple Crown this year, although I may consider something slightly knobbed if we have a wet enough spring.
Advocatus Diaboli
Quoted: 4740 Post(s)
Liked 1,533 Times
I'd recommend Pirelli Cinturato in a 32c, mostly because these should be great, but hard to find anyone with some firsthand experience.
https://www.sigmasports.com/item/Pir...cher-Tyre/J0ZE
Quoted: 4806 Post(s)
Liked 3,933 Times
I don't do a ton of gravel/off road riding but I use Panaracer Paselas when I do. Good road tires; my go to for off-season and city riding so roughly half my annual miles and as long as I use big enough, quite good off-road tires. (I rode the gnarly Trask River Trail across the Oregon coast range on a 37c front and 35c rear and they ruled. (And I was one of the few of the dozen of us to not flat at all.) I won't claim Paselas could do that ride day in and day out or even more than once, but once was plenty for this body! I've also used smaller Paselas (most of my bikes won't take those big ones) on a lot of more mild gravel.
Edit: the Paselas come in 23, 25 28, 32, 35 and 37c.
Ben
Ben
Quoted: 4227 Post(s)
Liked 2,488 Times
I like my Continental Contact Plus is 700x32mm. Very good on pavement and gravel/dirt paths.
Challenge clinchers stretch. A lot. I am still running but probably soon retiring a Parigi Roubaix, nominally 27mm, originally 29mm, that is now over 32mm. Had a set of Grifo XS, sold under a different name now, nominally 33, mounted at 32, retired at 36. Otherwise a great tire. Would be happy to use again. I got mine very cheap, holding out for that again.
Consider Compass/Rene Herse. Not cheap. At any width they are very fast. With low pressure and enough rubber they will grip at times you don't expect grip. Not for mud, not for singletrack. They will stretch too, but it's like any other Panaracer tire on that count.
Non omnino gravis
I feel the same way about Overides. The USH were on my list for several years, but I can get the Hutchinsons about $10 cheaper, and they're 35s instead of 32s. I had them sitting in my cart many times.
junior
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times
The OP mentioned road racing. Ugh. A do-it-all tire? Obviously there will always be compromises. What kind of gravel are you talking about? Lack of details leaves so much in the air. No matter, everyone has their favorites, and it seems you're looking for something in the 30s for width. I have little experience, since i've only taken up gravel last year, though i ride a lot on pavement to get to my gravel/dirt/offroad areas. and tire widths in the high 30s are not what I'm interested in. I ride manily 70% pavement, 30% gravel/dirt/fire road. Here's my modern experience:
I bought a pair of WTB Riddlers 700cx37 for my hybrid, as an intro to gravel riding. Fine tires for both pavement and gravel.
My new bike came with Clement MSO XPlor 700c x40. Also great tires for both pavement and gravel. Actually, fantastic. Yes, now found under the Donnelly name.
I now have a set of 650b wheels, and I'm using Teravail Cannonballs in the light and supple 650bx47 size. The Clements and the Teravails are both set up tubeless. I do not experience, or unaware, of any serious compromises when played with on pavement. But again, not really good for road racing. I haven't raced since the 80s! and i don't group ride, mainly with one buddy, who is also riding with a similar set up (GravelKings SK)
eric/fresno, ca.
eric/fresno, ca.
