CO2 inflator. Which one?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
Are these all basically the same or is there something to look for
in the different ones?
Quoted: 964 Post(s)
Liked 1,451 Times
Why not just use a pump? They are so light & good these days! Back in the days where the choice you had was Adhoc Ventose, Silca Impero, or Zefal HP/X, sure a CO2 inflator made sense. Nowadays it's a different story.
The Lezyne micro floor drive, for example, fits inside my Berthoud bag and weighs 150g. The even smaller Road Drive weighs under 100g. The carbon ones compete with the weight of a CO2 inflator. Many of Lezyne's offerings have a classic look to them and won't spoil your c&v lookin ride anyway since they can go inside a bag. For the budget-minded, there is the Topeak Mini Morph, which weighs 175g or so. A lightweight CO2 setup (chuck & one cartridge) weighs about 50g. So you're saving the same amount of weight as ~ 1 shot of espresso by using co2 instead of a pump. Less if you carry two cartridges!! (and you probably should). Run outta gas and you're stranded. Freeze your valve stem from inflating too fast and mess things up, and you're stranded. Some also say it leaks out of the tube faster, although this is anecdotal.
My opinion: CO2 is for seltzer.
Likes For scarlson:
small ring
Quoted: 438 Post(s)
Liked 925 Times
Get a plastic one, or always use a gloved hand. Metal insta-freeze will burn your fingers.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Quoted: 677 Post(s)
Liked 460 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2199 Post(s)
Liked 4,615 Times
I bought one of those mini Road Drives last year, and have used it. I was impressed.
Likes For non-fixie:
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
I use the same one I've used for the last dozen years, a Planet Bike Air Kiss.
https://www.ebay.com/itm/36314246629...cAAOSwCMFaOKEV
Quoted: 1609 Post(s)
Liked 2,216 Times
I would like this one.
Silca EOLO III - C02 Regulator | Competitive Cyclist
Likes For oneclick:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Unless you're trying to place in your age group in a triathlon or more competitive than that, I don't see the point. I've pulled over to help out people that screwed up inflating with a CO2 cartridge maybe half a dozen times. You get one shot with a cartridge to get it right.
CO2 cartridges and bottled water, solutions in search of a problem. Air and water are free for the taking.
Likes For gugie:
Quoted: 2588 Post(s)
Liked 4,826 Times
I use a CO2 unit because it'll get me to 120psi at the side of the road. Thus far, I've not found a frame-fit pump that can get to that psi level. So, for me, CO2 actually does provide a solution to an extant problem for sure.
DD
DD
Quoted: 4560 Post(s)
Liked 2,802 Times
I carry CO2 kits on every bike in case I get a flat on group rides. I don't want other folks waiting for me, especially roadie groups -- they'll drop you at every intersection, so getting a flat that takes longer than 15 seconds to fix ensures a solo ride.
Kidding, I stopped riding with groups that have that attitude.
I carry CO2 as a courtesy to friends on group rides, or rides on brutally hot days so I'm not adding to the risk of heat exhaustion by using a pump. But so far I've never used any of my three different CO2 inflators, including a Planet Bike Red Zeppelin and two others I can't remember.
Every inflator will have some negative reviews. Often it's operator error. I've watched other cyclists using inflators incorrectly, or neglecting to check the tire for the thorn, glass, etc, that caused the first flat, then blaming the CO2 kit. So choose one based on detailed informed reviews by experienced cyclists.
Regarding mini-pumps, I have three: the shorty Topeak RaceRocket HP, longer RaceRocket HPX, and longish Blackburn Core Slim. All require 200-300 strokes to reach riding pressure -- not full 100 psi pressure, around 75 psi, enough for most folks to ride carefully with 700x23 tires.
I've heard some folks claim they get full inflation from a mini-pump with only 100 strokes. I smell meadow muffins. I doubt they actually counted their strokes or measured the pressure. I've counted every stroke, every flat, and it never takes less than 200 strokes even with the longer HPX and Core Slim. The shorty HP needs 250-300 strokes. Some mini-pumps have even less capacity per stroke.
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
Insignificant compared to the total time removing the wheel, removing the tire, finding the source of the flat, replacing the tube, mounting the tire, then under a minute to inflate (typical for me), put the wheel back on, check the brakes...
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,100 Times
My most recent flat was at a busy intersection, 90+ degrees and humid in the direct sun. I used a CO2 to get the flock outta there. That being said I carry a mini pump and almost never use the CO2. If you like your tires 90 psi or higher, get 16g cartridges.
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah, same. As a teenager, I once went on a club ride on my dad's Guerciotti with a Road Morph strapped to the frame. Got a lot of weird looks until everybody was out of CO2 cartridges!
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
If you can't decide, there's this:
Mountain Pipe
Gets your tire decently hard with CO2. By hand, can get enough pressure to make it home fine (not designed to reach full road bike pressures by hand). A nice feature is that a CO2 cartridge, empty or full, serves as a handle for pumping manually, which helps with the ergonomics.
Native connection is Presta but comes with Schraeder adapter.
Mountain Pipe
seńor miembro
Liked 6,491 Times
In summary
Use a portable/frame pump if you ...
- dislike paying for air
- are He-Man
- can show off a sweet matching frame pump
- ride on fat tires
- stop to help the helpless
- like criticizing those who use CO2.
use a CO2 if you ...
- ride when it's hot
- are weak
- are in an age appropriate triathlon
- have no mo room
- ride 23-25mm tires
- don't flat much
- know what you're doing
- are into firearms
- enjoy a bigger landfill
- need a good reason to keep riding when someone asks if you have a frame pump.
- are He-Man
- ride on fat tires
- are weak
- have no mo room
- don't flat much
- are into firearms
Likes For SurferRosa:
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 956 Times
I have a CO2 set up on each bike. I find it much quicker to get back on the road. Since I'm cheap, I buy the CO2 cartridges in bulk for a buck or two each. The two things I look for are a knob to control the flow and I also like to be able to thread the CO2 dispenser onto the presta valve. I find with both of these features I can control the flow, prevent freezing, and it just works.
If I have a slow leak, I can top off the tire in 10-15 seconds and get back on the road (great for a lunch time ride). I have no issues with a small pump, it just takes more time and that's not what I want to spend my time on.
To each their own.
Mike
To each their own.
Mike
Liked 4,826 Times
Realized I didn't answer the OP's question, but went along with the tangent instead!
I use a 16oz. Spin Doctor Quick Shot. It cost me nothing because I found it at the side of my local MUP, but it's got some features I feel make it a better item than the little twist-adaptor type I had origially. The head has a nice flick-locking lever to lock it onto the valve (exactly like a quality floor pump), and a locking device to stave off inadvertent discharge if you accidentally depress the trigger. Because it has 8 vents at the bottom, there is a tiny bit of exposure to the bare metal of the cartridge, but the plastic thickness is such that skin-to-metal contact is virtually impossible.
Again, my only issue with frame pumps is they can't come close to the psi levels I require. Oh, and the reason I run high pressures: sick of snakebite flats, I began running higher pressures and experienced a massive reduction in flats. Don't have to tell me twice...
DD
DD
Liked 2,216 Times
See that grey container with the black top? Tools, rag, 3 Co2 cartridges with head, tire levers, Expired ID, patch kit.
IMG_20180930_085551 on Flickr
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
I carry a Zefal XP frame pump (I am very much not a fan of mini-pumps), a CO2 adapter and at least two cartridges. I use the pump to get started and the CO2 to finish it off. If I screw it up and waste all available CO2, I can still pump the tire up to acceptable pressure, although it's annoying. If I do it right and don't waste all available CO2, I can get the tire up to my preferred pressure without busting my chops with the pump.
And if a dog tries to go ankle-biter on me (which I admit has not happened in a long time, but it has happened), Mr. Zefal, vigorously applied, provides a strong incentive for Mr. Pooch to cease and desist. The last time I used the Zefal as a dog taming device, the dog had just gone after a rider about 150 yards ahead of me, and I watched him (the dog, not the rider) retreat up his farmhouse driveway and crouch into the "ready to go" position. As he started to run back down the driveway to get me, I held the Zefal in my hand and showed it to him. He immediately stopped and retreated back up the driveway again, giving me the stink-eye all the while. It sure seemed like he had been on the receiving end of a frame pump before and did not care to repeat the experience. You may not be able to teach an old dog new tricks, but sometimes you can get him to cease and desist an unacceptable old one.
Likes For bikingshearer:
Quoted: 405 Post(s)
Liked 430 Times
CO2 cartridges are for pellet guns. (Especially the Crosman 2240 pistol, which is one of the greatest things ever.)
--Shannon
Likes For ShannonM:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Liked 2,216 Times
"There is not now, was not then, and will not be in the future a better device for putting air into" a pellet gun that a pump action that can control velocity, limited by strength of the shooter. "Nothing else works anywhere near as well." Competition pellet guns are hand pumped.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Portland Design Works: Shiny Object.
