DT Swiss hub upgrade benefit
faster downhill
what is the advantage/disadvantage to upgrading dt swiss hub from 18t ratchet to 36t or even 54t on a road bike?
Quoted: 1975 Post(s)
Liked 232 Times
On a road bike there is very little benefit since the transition between freewheeling and pedaling isn't nearly as often and the need for immediate low crankspeed engagement is rare. But it makes a cooler sound.
Quoted: 20810 Post(s)
Liked 9,456 Times
It's all about that sound.
faster downhill
Liked 9,456 Times
edit -
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
My kid just had this done on his mountain bike, and thinks it is a major improvement. My guess is that at least part of it is expectation bias, augmented by the "improved" sound effects. (It is quite significantly louder -- louder than my Chris Bling hub now.) A rep at Sea Otter did this for him, as part of a hub maintenance tutorial. You also get a "lifetime" supply of their grease. Basically, you want something approaching a molecular monolayer, i.e., as thin an application as possible.
Edit: The same kid says for a road bike it probably would not change anything, but increase the friction slightly.
Quoted: 4717 Post(s)
Liked 1,882 Times
it's probably not super important, but I found the engagement of the 18t to be annoying. I was much happier after switching to the 54t .It is noisy if that bothers you
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I switched from the 18 to 36. Overall I feel the hub is pretty quiet as compared to my older roval brand hubs and not much louder than the 18t. $100 star ratchet upgrade, mostly for the sake of upgrading is a tough call. Faster engagement for sure but as others have said it isn't something that is going to make a huge difference.
Chases Dogs for Sport
And if you want any of them to be louder, just don't grease them! They're all whisper-quiet for the first 200 miles after an application of DT's "special" pink grease! (Have I mentioned that the only thing I dislike about my DT Swiss ratchets is the maintenance interval?)
Over 7500 miles on my 240 rear hub and I've likely only regreased it a handful of times and it still rides like new. I'd find something else to worry about.
In the past, I've had wheelsets go 20,000 and 30,000 miles with zero maintenance. Never had to be disassembled. But then, the hubs weren't DT Swiss.
So, you're telling me I have nothing to worry about in the first year. I really didn't expect to have problems in year one. But in time, things start to wear out when you tear them down and put them back together enough times. Especially if they are stiction fit.
Liked 1,882 Times
You are wasting your time worrying about the longevity of DT Swiss hubs.
