Disc brakes are now the default on road bikes and no one cares
#401
Quoted: 3241 Post(s)
Liked 2,512 Times
Kool Stop is making disc pads now. I guess that means discs are indeed, mainstream.
#403
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
#405
Liked 2,512 Times
#406
Quoted: 365 Post(s)
Liked 418 Times
In my case, you're right, I don't care, much.
The aesthetics bother me a bit, I find the appearance of a bike with discs somewhat jarring, but I'm sure I'll get used to it. I've (mostly) gotten used to sloping top tubes, bulbous head tubes, big diameter frame tubes, aero rims, etc.
Personally, my single bikes have rim brakes and I've never had a problem stopping, but I don't ride huge mountains, I don't have carbon wheels, and in the wet I just slow down and I start braking earlier to compensate for wet rims.
I do like the mechanical disc brakes I have on our tandem. There was a learning process entailed in changing the disc brake pads, but even the first time didn't take any longer than changing/adjusting the canti brakes on my tourer.
#407
Quoted: 18883 Post(s)
Liked 10,646 Times
The most surprising thing about this entire thread is how many cyclists ride in flat places. Apparently we're talking flat like a pancake, not flat like a waffle. That makes me sad. All of you need to come out here and ride across the North Cascades this summer. After Washington Pass you get a 45 minute descent into wildflowers and great restaurants.
Likes For Seattle Forrest:
#408
Quoted: 1247 Post(s)
Liked 1,322 Times
#409
Liked 2,512 Times
How about the propensity for people to ride much smaller frames than in the past followed by extended seatposts, plenty of head tube spacers and riser stems. I have gotten used to Disc brakes but not the small frame thing. So many times I see people posting glamour shots of their bikes on this forum with stems cranked to the moon and I need to accept this is the new pretty.
Likes For noodle soup:
#411
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
On my end, I opted for a ML frame instead of a L for reasons of availability. According to the sizing chart, my height and inseam, I was in between the two sizes. My seatpost & stems are raised, but not as much as other cyclists I meet on roads.
Likes For Cypress:
Likes For eduskator:
#414
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I love the ISP...now. I didn't love it so much when I had to take a hacksaw to my brand new top-shelf frame module on three separate occasions to get the seat height set correctly
Quoted: 981 Post(s)
Liked 583 Times
Is there any adjustment on the seat clamp or is it a hit or miss kind of thing?
#416
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
The frame comes with a bunch of aluminum ISP spacers of every thickness. The idea is you cut it close to where you want it, then shim the ISP under the mast topper. I ended up cutting mine so close to where I wanted it that I sanded about 0.25 mm off of the post itself, covered the exposed carbon it in clear nail polish, and run it with no spacers. I'd say a person could make up about an inch with the spacers before it reaches the max-spacer mark. The topper is meant to rest on something, as the tiny pinch bolt on the topper is only meant to keep the topper and seat from flying off of the ISP or jiggling around when you hit bumps.
Liked 2,512 Times
It needs to be said. Those 2 bikes posted above don't look like Giant bikes at all. They both look average size, at best.
I know, don't quit my day job.
#418
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
A friend of mine was in the Navy many years ago. Whenever he'd get new orders, he'd have to make an itemized list of valuables for the moving company to cover potential losses/damage and to get an idea of what kind of container they'd need to request. At one point he put his "Giant bicycle" on the list and got a phone call from the moving company asking "exactly how big is this giant bicycle???"
Likes For Cypress:
#419
Liked 2,512 Times
#421
Liked 2,512 Times
#422
Quoted: 4717 Post(s)
Liked 1,882 Times
Agree. Pros also ride similar setups, which makes me believe that there is an advantage somewhere (most likely in performance).
Half that is acceptable.
#423
I buy the size that gives me a 10cm saddle to bar drop, with a -17 stem and no spacers. If I find the drop to be too much after I'm in my 70's, I can change to a -6 and get the bars 2cm higher.
#424
And three days ago Adam Yates blew the doors off of everyone at Jebel Hafeet on a disc-equipped Scott...
#425
Quoted: 3943 Post(s)
Liked 7,286 Times
