Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Mimicking bike setup between different frames
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 02-22-20, 11:00 AM
rmwesley
Quoted: 22 Post(s)
Liked 15 Times in 13 Posts
Hi,
I've got three different frames (Cube Agree, Genesis Equilibrium, Rose Xeon) which are all nominally "medium" but obviously differ a bit in seat tube angle, frame stack, frame reach, BB height etc.
The setup on the Cube feels really comfortable so I'm thinking about trying to do what I can to mimic it to the other two.
I can't match everything because of the basic differences between the frames, so out of all the different things I could tweak or tune what would you say are the most important measurements to try and replicate exactly. Is it handlebar stack and reach? Or is it better to try and get a happy compromise across the standard set of frame sizing measurements.
Thanks in advance.
rmwesley is offline
Old 02-22-20, 12:24 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3886 Post(s)
Liked 1,938 Times in 1,383 Posts
It should be relatively easy to duplicate saddle position w/r to BB and pedal axle, Also almost always easy to duplicate reach, though reach isn't necessarily distance from anything, rather it's the angle your upper arm makes with your torso when using the same bar grip. Thus stack has an influence on measured reach if you see what I mean. IOW if your arm angle remains constant, you can draw an arc with it's center being the top of the saddle and along this arc will be your combination of stack and reach.
Results matter
Carbonfiberboy is offline
Old 02-23-20, 10:37 AM
rmwesley
Quoted: 22 Post(s)
Thanks for the reply. I think I’ve figured out a reasonable compromise. I like the idea of drawing arcs from the BB and from the saddle.
rmwesley is offline
