Gravel bike on the road
#78
Quoted: 1218 Post(s)
Liked 298 Times
Location/roads is everything and plays a huge part in selection, but If I could only have 1 bike the RDO would be a heavy contender.
#79
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
You guys see the niner RLT reviews by Clint on youtube?
pretty detailed, but very infomational.
He started with his CX bike,
Then got the Steel RLT. He never bonded with it. Sounds like it wasn'r really fast enough for the group rides he did. sold it and kept riding the CX bike.
Then he got the carbon RLT RDO. He totally fell in love with that. The cush of the Steel, Speed of the CX bike (actually faster in a lot of circumstances).
If he could only have one of the 3, clearly the carbon RLT RDO is his solution. I guess for the money, it should be.
#80
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Fox has the AX fork for gravel bikes that has 40mm of travel. They're extremely expensive and I've never seen one or talked to anyone who has ridden one.
https://www.cxmagazine.com/firs-ride...-fork-float-32
I had seen something about that fork but had forgotten it. That would be really nice for bikepacking along the Pinhotti and similar.
-Tim-
#81
Liked 298 Times
First impressions of the RDO, was omg this bike is way better than a large majority of the road bikes on the market. I was riding Rival on stans grails G'one tubeless. Don't take this next statement lightly because the RDO is damn smooth. I think Clint is wrong when he says the RDO has the cush of the steel.
I can see why he opted for the carbon RDO though. I'd make the same choice in his position.
I am torn, but given my average speed for this bike will be around 16 mph, I'll take the steel. Of course I was already in the market for more cush and 650b, but not now. I think the 853 steel RLT, on extralight Barlow Pass, or 700x38 Gravelking slicks is my answer.
biggest question will be on the build, Sram 1x, or the new clutched Shimano with Absoluteblack compact gravel 46/30 ovals.
#82
Liked 415 Times
I chose 2x because I needed the high speed and tight gear spacing required for a fast group ride on the road. But if my speeds were under 30mph and I wasn't trying to hang on to a paceline (i.e. if I could pick my own speed), I think 1x would be fine. I don't shift the front rings much - generally 36t on my own, and 46t with a paceline.
#83
Liked 298 Times
I know, tough decision right?
I am actually curious now on this topic. I found the G'ones tubeless to roll well but still have some draggy feeling to them on tarmac. I wonder just how fast a Niner RDO can be with a 35/38 Compass tire on pavement. the RDO is lively! the only things holding it back, were motor, and tires.
#84
- Soli Deo Gloria -
Liked 736 Times
I felt like 35 mm Schwalbe G-One tires set up tubeless roll as well as the older generation 25 mm Vittoria Rubino Slicks. The G-One's, or any high end tire for that matter, perform best when paired with a light wheel.
The Absolute Black rings are really interesting and I'd love to hear from someone who tried them in the real world.
#85
Liked 415 Times
Personally, I find that G-Ones roll fast – they probably have between 15-20 watts rolling resistance, which is pretty darn good.
I do find that they are slightly heavy – when doing a fast road ride I am on slick tires that are about 300g lighter (pair), even if they have similar rolling resistance (about 17watts each). That and about 300gr savings in wheel weight makes for a fast bike.
#86
Liked 298 Times
Oval choice, also plays a part in a my new geared bike 1x/2x choice. 1x allows for the running of an oval without the shifting headache.
at the same time.... DI2 is awesome. would I give up di2 for a 1x... no! would di2 make a difference in the oval shifting, yes. you'll get the exact same torque / movement time and again. do I want di2 on a bike that would see over nights? weekend trips? all winter riding? probably not....
the other quirk I do not like about them is higher rpm gets weird like at 100+ its harder to spin. I often hit 120-130 on SS with the 48t round. I can't spin that fast with the 50t oval. but the 50T oval climbs and tractors into headwind advantages far outweigh the disadvantage of me not being able to spin the oval as fast.
I also have a 32t oval on my 29er hardtail that is XT 10 speed 11-36. the advantages of the oval on climbing, is enough for me to not bother with sunrace or a one up conversion. (west/central Ohio, and Scioto trails Great Seal state park Scioto trails Chillicothe Ohio area.)
#87
Liked 298 Times
speaking of tires and roll resistance...... I did not check the psi difference between the steel RLT and the RDO. Even though both were set up on grail wheels same G'one tire tubeless. I do recall the rep telling me when I took off on the RDO that the pressure was good for the road. not checking the pressure difference was probably a hindsight on my part as for comparing the 2 bikes. In my opinion, a lb or 2 can change everything on comfort.
#88
- Soli Deo Gloria -
Liked 736 Times
When you say oval, do you mean Absolute Black or a different brand?
As an aside, I'd still like to ride a Jamis Renegade Elite. I tried to buy one sight unseen and would have purchased without so much as test ride but could not find one anywhere, not even one of the dumbed down "Performance Exclusive" models at Performance Bike. This bike looks like a great value. I say this as a happy owner of a Di2 Niner RLT 9 RDO. I'd still really like to ride the Jamis.
-Tim-
-Tim-
#89
Liked 298 Times
As an aside, I'd still like to ride a Jamis Renegade Elite. I tried to buy one sight unseen and would have purchased without so much as test ride but could not find one anywhere, not even one of the dumbed down "Performance Exclusive" models at Performance Bike. This bike looks like a great value. I say this as a happy owner of a Di2 Niner RLT 9 RDO. I'd still really like toride also own and ride the Jamis.
-Tim-
-Tim-
I fixed your quote for you. and you are welcome.
#90
Quoted: 1975 Post(s)
Liked 232 Times
My SuperX is every bit as fast as Bianchi 928 endurance bike on the road with the same tires FWIW, with the right geometry and frame construction cross/gravel bikes can be excellent at certain things but not excel at them all. Its stiffer and twitchier than most would like for long gravel rides and not as stable at speeds. Feels like a fat tired crit bike
#91
Bikes: 1990 Specialized Hardrock Sport, 2007 Pinarello Galileo 105, 2014 Raleigh Cadent 2, 2017 Jamis Renegade Expert
Quoted: 36 Post(s)
Back on the topic at hand, my Renegade has never worn thin, light road tires. I briefly had the stock tires, then Schwalbe G-One Allround 38c, then WTB Riddler 37c, and I just put on some Donnelly Strada USH 40c tires. I have some friends of similar ability and when we ride gravel and they have their CX/gravel bikes there's generally parity. On my better days I can drop them and vice-versa. When we're riding hard (not race-level hard) on pavement I can keep up, but it's work, and they can gap me on the steepest climbs on their road bikes. They've told me on numerous occasions they'd love to see what I could do with a road wheelset or a "proper" road bike. I myself am very curious to see how my Renegade would ride with some light carbon wheels and 28c tires.
#92
Liked 415 Times
28mm tires reduces the trail slightly making the bike more agile, and of course the steering is much more precise with 28mm tires.
#93
IS it all the tires
It seems to me 90% of the responses end up being all about the tires. I also find it funny how so many people bash on hybrids. Funny because a gravel bike is much like a hybrid bike. It is a compromise largely built on tire type and handle bar type along with slightly tweaked geometry. Your hybrids range from cruisers to essentially flat bar road bikes with tires anywhere between 28 and 45 mm. Your gravel bikes range from stuff like the specialized diverge which I am see being sold with what amount to 30 mm slicks to toughroad gx with 38mm plus nobby wheels. Yet many who love gravel bikes as a go anywhere option will tell you even a performance hybrid is crap because it doesn't do anything well but is a compromise. Isn't that what a gravel bike is? A compromise it won't be as fast on the road as a dedicated road bike nor will it come anywhere close to handling anything but the tamest xc trails. Hey I love them all but I find the difference in opinions on hybrids and gravel bikes to be funny. About tires I put 35 mm clements on my 29er vs my maxxis ikons (2.25) and gained no speed at all but it sure made the ride rougher. Tempted by gravel bikes but I think that would be scary down some rocky rooted downhills in the northeast. Oh well N+1
#94
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
My “gravel” bike is a Soma Fog Cutter, which has a fairly road-like geo (compared to other gravel bikes) but can take 42mm tires.
Running 35-38mm Compass tires, I never miss my old skinny-tired road bike, even on long rides with no dirt roads.
IMO gravel bikes are just road bikes that don’t suck on gravel.
#95
Gravel bikes come with a huge variety of frame designs. Some are 29ers in disguise, some are just hybrids with drop bars, and some are just road bikes with enough extra room for bigger tires. My personal 'gravel' bike is about 1 mph slower for the same effort as my current road bike. The road bike is 5 pounds lighter and has 25mm vs 36mm tires. I recently switched back to the Clement 36 mm MSO's my Jamis Renegade came with since I found no advantage with a 32 mm road tire other than cornering feel, and it sucked on our gravel. I ride to our gravel; so I ride 12-16 miles of road before hitting gravel usually.
#96
Quoted: 92 Post(s)
Liked 12 Times
I would personally not opt for 25s or 28s on a gravel bike, even if I was only using it for road. A pair of 32c Panaracer Gravel Kings, with their high thread count and nearly slick tread pattern, will make your ride SO much more comfortable, and whatever perceived friction drawback is negligible at best. Since you've got the clearance, take advantage of it!
#97
Liked 415 Times
Depends what you are doing. If I am doing a 20-30mph group ride (peaking ~40), tire weight makes a difference. I do ride 28 and 32mm tires - not a huge difference - although the 28s are ligher and and more aero (at 40mph, that helps!). My goal is not to get dropped, lol. And 28mm GP S4000 are super cush, and measure out at 31mm on on my 22mm (ID) rims. light and fast.
If I'm riding solo, 32mm works fine (although with these specific conti tires, 28 and 32mm are not that different). Agreed - with my 28mm tires that measure 27mm (4mm narrower than the GP4S in 28mm) - well that is a bit narrow.
I saw a guy in front of me with super narrow tires. I laughed when I realized he was running 25mm tires (on narrow rims) where I had the same tire in 28mm tires and wider rims - huge difference in width on this tire.
#98
Liked 298 Times
Pfft I get dropped with a 25c on those kind of rides. So.... I might as well just run a 38c slick.. haha
#99
Liked 415 Times
True, lol.
In the velodrome, if I get dropped I can catch back on 15 seconds later.
Funny though, Although I have tried many times, I don't think I have ever successfully done it. If I blow up, I certainly don't have the reserve for that kind of power jump.
#100
How well does your gravel bike on a very good condition flat road ?
I have a nice deal on a gravel bike, i won't do gravel a lot tho.
If you put 28's (or even 25 if they fit in) on a gravel bike, does it make it equivalent to a real road bike ?
Roads are quite bumpy where i live so i would gain in confort, but when i'm in a city the roads are clean, will I lose speed compared to a real road bike?
thanks
thanks
Nicholas L
General Cycling Discussion
19
03-27-20 10:04 AM
jzsoup
20
01-24-17 10:36 AM
