Retro roadies- old frames with STI's or Ergos
#7351
Quoted: 4233 Post(s)
Liked 2,948 Times
I love the bikes pictured, and what y'all have done.
This is the best place to ask:
Is there a "retro" appearing brifter? I mean gum hoods, brake cables coming out the top, but with hidden shifters?
If so, that would be really cool, to have a completely CV bike but keeping both hands on the bars when riding in a group.
I looked around on ebay and don't see anything, partly because what name would I search for?
"gum brifter"?
" sorta old school lever"?
"gum brifter"?
Likes For himespau:
#7352
Hudz makes a replacement cover for many types of integrated brake/shift levers. One of the cover colors that they offer (is often harder to find than most) is called Bordeaux Gold. It almost looks like a gum lever. When I finally get around to doing my next build, I'm going to be putting those on a set of campagnolo ergos with the aluminum levers to get as close as I can to a retro-ish look.
#7353
Quoted: 293 Post(s)
Liked 218 Times
I passed on the original 8 speed Campy Stratos groupset and Mavic Cosmos wheelset, replaced the quill stem and original bars and seatpost. now it sports a new FSA headset, Deda 100mm stem and 42cm Deda bars, carbon Ritchey seatpost, Vuelta wheelset with Mavic Yksion Elite tires and Shimano 105 groupset. Rides like a rocket.
Likes For greg3rd48:
#7355
Quoted: 1609 Post(s)
Liked 2,590 Times
#7356
Keener splendor
Flip your stem and rotate your bars down so the levers aren't pointing at the sky. It will increase the stack to the bars for you.
#7357
Quoted: 293 Post(s)
Liked 218 Times
You are right. I did feel like I was riding too high. I will flip the stem and try it out. Thanks!
#7358
Sunshine
Quoted: 10956 Post(s)
Liked 7,485 Times
I have an 87 prelude and an 88 premis, both tenax, and the seat tube is quite literally slammed and squished into the bottom bracket shell to fit with the down tube(vs being mitered/coped to fit inside the shell with joining tubes).
Any chance you happened to look at the joining method of your Prologue? I know the Prologue is Panasonic built with Prestige tubing, vs Greenville built with Tenax tubing like the rest of the upper tier of bikes, but just curious if the slam and squish build method was used for the highest level bikes too(with Prestige or SL tubing).
#7359
Sunshine
Liked 7,485 Times
I might have to make a whole thread for this one at some point - but this seems like the place to show off the whip I've most been enjoying so far this summer!
Ryffranck, hand built in Sherbrooke, Québec. Columbus EL OS. 'Freuler' style geo w/extended HT and ST ('dropped' TT). R8000 Ultegra w/H+Son Archetypes.
Rides nice.
Rides nice.
#7360
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I've been meaning to ask this about other member's upper tier late 80s schwinn road bikes, but keep forgetting.
#7361
Quoted: 378 Post(s)
Liked 1,409 Times
Battaglin
Haven't played in a while, that's for sure. Member @cpsqlrwn did me a solid on selling me this, and I'm fairly certain it's a climber for my future.
10-sp Centaur triple, Aerohead rims, and all the usual suspects. Went to Xpedo Thrust 7 pedals because they're cool. Finished it, finally.
#7362
Quoted: 767 Post(s)
Liked 1,898 Times
Beautiful bike! Pedals look great on it.
#7363
Sunshine
Liked 7,485 Times
Since I don't want to disassemble my Prologue again, I will have to look at pictures I took of it, as well as my Peloton (same top level Panasonic build, same exact lugs--not kidding), to see if I took any. Nothing stood out to me when I did look at it, which usually means the tubes all go straight into the lugs with no mitering--they just don't protrude into free space very far at all. Seems to be pretty standard on other high end frames. No squishing--plenty of clearance for bottom brackets.
This is the inside of the Premis shell. I get that fitting the tubes by mitering is extra time and therefore cost, but wasn't sure if the late 80s Japanese built frames went that extra step due to higher quality/qc/different process.
#7364
My Cyclops, built in Vernon (BC) by Mike Mulholland, is remarkably similar with lugged HT and ST extensions!
It's not as though I've sought out this construction style/feature - just so happens that these were the bikes by these builders that came available to me in a suitable size...
#7365
Liked 2,024 Times
Ha, yeah disassembly is well past reasonable.
#7366
Quoted: 378 Post(s)
Liked 1,409 Times
Yes.
Tires-perfect
Colors-perfect
Setup-perfect.
The C24 is one of my favorite all-time wheels.
That is capital Nice. Clean. Smooth. Executed with vision and class.
Tires-perfect
Colors-perfect
Setup-perfect.
Likes For RobbieTunes:
Likes For Cycle Tourist:
#7369
Quoted: 378 Post(s)
Liked 1,409 Times
STI/Ergo's on an old bike.....
This conversation actually occurred during a recent group ride.
"Why put 11sp DA on an old bike?" (1988 Centurion)
"Why put 11sp DA on an new bike?"
"Because it works."
"Well, (duh) there you go."
One of the guys in the group is from Ireland, and splits his time between a 7900 BMC and a 9000 Dogma.
He was riding along, and just grinned. I showed up later on a Bob Jackson, and he said "you are sick."
"Because it works."
#7370
Liked 2,024 Times
"Because it works."
"Because it works."
Thank you, BTW, for your extremely kind compliments of my Prologue!! It was certainly an execution of a vision (as you pointed out). I may be a pound over my fully mechanical 7900 setup's weight (with a lighter quill adapter and lighter, older Vittoria tires) at 20.5 fully dressed, but this looks even better to me, and of course the shift levers feel wonderful and shift sublimely. Lower gearing while still being able to brain fart a 53-28 big-big combo without issue. More black to make the tan wall Corsas pop (I am in love), and of course the C24s--or their immediate, incremental-improvement predecessors, of which I own two (this pair included) and nearly snagged a third, all because people are finally dumping their high-end 10-speed wheels.
Your Battaglin looks great, and is the exact same frame (assuming SLX) as my taller version...minus the missing original fork on mine....and the good paint, of which mine lacks....and the booger weld at the drive-side rear dropout/chainstay....
#7371
Quoted: 378 Post(s)
Liked 1,409 Times
The Irish lad is a fan of C & V. He has the kids/mortgage/race of rats thing going, and he’s still a hammer. Enough so his bikes show it. Met him in a paceline while I was on a Raleigh Competition and a week later on an Ironman. He laughs every time.
In an odd way, he has his vicarious grip on C&V thru me, and when the paceline takes off, I just tell him “mow ‘em down.” He grins and obliges.
#7373
Quoted: 767 Post(s)
Liked 1,898 Times
Love this thread!
So many great builds here, so many members with great skills and excellent attention to detail. No reason why these old frames can't be "rejuvenated" as well with fresh new mechanicals (or electronics!). It's very encouraging to see what others do with their visions. @RiddleOfSteel, that Prologue is a perfect representation of how refined a build like this could be.
I've got an '89 Puch - Columbus Cromor tubing - that rides so nice. I don't expect the Suntour Accushift stuff on it to be problem-free forever. When the time comes to start replacing parts, it'll get a modern group. I went that way with my Ironman, and it gets ridden the most for that reason.
#7374
Quoted: 378 Post(s)
Liked 1,409 Times
Dual cult member.
Love this thread!
