Disk brake wheel - repetitive removal / mounting
Disk brake wheel - repetitive mounting / dismounting
Hi,
I have a question about road bikes with disk brakes (I use rim brakes for the moment): How do disk brakes behave in case of repetitive mounting / dismounting of the front wheel, for transportation inside the car? Do they need special care and adjustments each time, or are they as simple to mount / dismount, as rim brakes?
Thanks
Thanks
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Never a problem with the one bike I own with a front disc brake and which must have the front wheel removed to carry the bike on a roof rack.
The bike with thru-axles? The caliper lines up with the disc perfectly every time. I don’t plan on having another bike with both discs and QRs.
Likes For ted_major:
Quoted: 1572 Post(s)
Liked 643 Times
That’s been my experience. I have one bike with discs and quick releases, and I think maybe once I’ve been able to reinstall the front wheel without the brake rubbing. Just about every time the wheel comes off, I have to re-align the caliper.
Hold the bike upright while you thread the disc onto the brake caliper and the axle into the fork ends. Set the bike down until the axle bottoms in the fork ends, tighten the QR and you'll be good to go.
Bikes: Trek Marlin 6 29r - Scattanti road bike w carbon fork - Trek 6500 - Univega Alpina 503 - Specialized Sworks M4 made in USA
Quoted: 90 Post(s)
Liked 103 Times
I do lots of one way riding then enjoy lunch with the wife. I remove the front wheel and roll the bike in the back of the mini van. Never an issue with the hyd brakes.
My best guess as to the root cause is that I use Nitto Randonneur bars, which have a traditional round bend instead of modern ergo bars that angle backwards in a straight line. I suspect an ergo bar would leave room for more lever travel, so that I have to adjust the pads close to the disc (which gives me a nice, firm lever feel) and there just isn’t any room for even the tiniest misalignment without caliper rub.
Quoted: 576 Post(s)
Liked 1,001 Times
I do that, but the caliper still rubs almost every time I reinstall the front wheel. I’ve gone through several sets of calipers, all of which behaved the same way. The bike in question is a 2016 GT Grade, which came w/ TRP HY-RD brakes (and Shimano 105 brifters). I went through a couple of pairs of those under warranty because it was impossible to adjust them so that they wouldn’t bottom out on the handlebars. TRP eventually sent me a pair of Spyre calipers, which worked w/o bottoming out, but like the HY-RDs needed re-aligning every time I took the front wheel off. Those were eventually replaced with Yokozuna Motokos, which worked great, but still required caliper re-alignment.
I do that too (it takes 4 revolutions for this bike). Still can’t get the disc & caliper to stay aligned. Mostly I just don’t take the wheels off.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I've never not had to realign the caliper everytime I remove my front wheel for transport. It only takes a second to loosen the caliper, lightly squeeze the brake and retighten, but it's still a pain in the arse.
