Did a couple of pedal rebuilds!
Old 05-25-20, 10:43 AM
Tandem Tom
Quoted: 455 Post(s)
Liked 112 Times in 85 Posts
After a 4 day ride on the GAP I noticed a bit of clicking in my right pedal. Shimano M520's. So took a bit of time to rebuild them this morning. After a quick run to the bike shop,where I work part-time, I grab some bearings.
Cleaned, new grease and new bearings!
Tandem Tom is offline
Old 05-25-20, 10:49 AM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
Next time you over haul your hubs pull the axle-bearing out of the pedal and fill the housing with grease. When you install the bearing it will force out the old grease and leave behind the new clean grease.
When you adjusted the bearings I hope you had a little drag which means there is a necessary preload to the bearings.
davidad is offline
Old 05-26-20, 01:15 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
I remember rebuilding pedals many years ago and having trouble getting the bearing adjustment correct because the cone and locknut are inside the pedal body and cannot be held at the same time. Is there an easier way to do this, or do I just need to give it another try?
FastJake is offline
