Identifying and fixing a Bianchi bike!
Old 06-28-20, 11:29 PM
AnotherFlower
I have an old Bianchi which I believe is a 1985 (?) Nuovo alloro or torfeo. Any help identifying it would be amazing.
As of right now, it's in rough shape. While not overly bike-savvy, I want to make this bike my own.
As such, I'm in need of help looking for suggestions on what to fix, replace, or upgrade on the bike
bike.
I believe I am going to have to replace the wheels as they aren't straight. They are 700 x 25c and am not sure if there is a specific type of tire/rim that is require for rear. The brake and gear cable is rusted heavily in some areas and will probably be replaced as well. In addition, I think new brake pads are needed, but am also unsure if a specific brake pad is required for different bike tires.
AnotherFlower is offline
Old 06-29-20, 04:33 AM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac, 196? Torpado Professional
Quoted: 814 Post(s)
Liked 341 Times in 239 Posts
First, get up to ten posts, spread over two days, and then you can post pictures. To get your posts, tell us, in different posts, not all in one post...
- how you got the bike
- where you live
- how tall you are
- male or female
And stuff like that that you think might prove of interest, or help, to us.
Now get busy with those posts and then let's see your Bianc?i. Does it look like this one that I found at the dump last summer..?
randyjawa is online now
Old 06-29-20, 07:51 AM
AnotherFlower
I'll get on those posts!
The bike is very similar to the one in your picture. Frame and handset look identical in shape, however my frame is black instead of blue. I cannot see clearly in the picture, but my bike also comes with brown/tan non-aero hoods as well.
Otherwise the brakes, gear system (12 gears total I think?) and pedals also look identical
Old 06-29-20, 08:08 AM
T-Mar
Quoted: 3313 Post(s)
Liked 730 Times in 561 Posts
It's definitely not a Nuovo Alloro or Trofeo. Those were mid-range, Italian models. The subject bicycle is an upper entry level Japanese manufactured model based on the Ishiwata Magny tubing and Shimano Z-series components. The presence of the chrome fork suggests a Canadian market model. Era is circa 1984 -1985. Depending on the exact year, it could be either a Bici II or one of the Strada variants. The serial number will tell us the exact year.
Too many photos for an assist. Link to OP's photos: https://www.bikeforums.net/g/user/521674
T-Mar is offline
Old 06-29-20, 10:57 AM
AnotherFlower
There is a sticker that says Ishikawa Magny and lots of Shimano parts. Where should I find a serial number and/or what other identifying features can be used to distinguish between whether it may be a Bici II or Strada variant?
Old 06-29-20, 11:03 AM
T-Mar
The serial number would typically be stamped on the underside of the bottom bracket shell or near the bottom of the seat tube.
T-Mar is offline
Old 06-29-20, 01:00 PM
jdawginsc
Edumacator
Quoted: 276 Post(s)
Liked 165 Times in 111 Posts
I think you hit it. I seem to remember a Speciale model that seems to have been around this bike's level?
What is wrong with me...I can't stop! 1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl somethingorother, 1980s Vanni Losa Cassani thingy, 19something Massi blob...
jdawginsc is offline
